#include
#include
#include
#include
typedef unsigned char uchar;
typedef unsigned short ushort;
typedef unsigned int uint;
#define DataPort P0
sbit SCL=P2^6;
sbit SDA=P2^5;
sbit LCM_RS = P3^7;
sbit LCM_RW = P3^6;
sbit LCM_EN = P3^5;
sbit LCD12864_PSB = P1^5;
sbit LCD12864_RSET = P1^3;
// 定义MPU6050内部地址
#define SMPLRT_DIV 0x19 //陀螺仪采样率,典型值:0x07(125Hz)
#define CONFIG 0x1A //低通滤波频率,典型值:0x06(5Hz)
#define GYRO_CONFIG 0x1B //陀螺仪自检及测量范围,典型值:0x18(不自检,2000deg/s)
#define ACCEL_CONFIG 0x1C //加速计自检、测量范围及高通滤波频率,典型值:0x01(不自检,2G,5Hz)
#define ACCEL_XOUT_H 0x3B
#define ACCEL_XOUT_L 0x3C
#define ACCEL_YOUT_H 0x3D
#define ACCEL_YOUT_L 0x3E
#define ACCEL_ZOUT_H 0x3F
#define ACCEL_ZOUT_L 0x40
#define TEMP_OUT_H 0x41
#define TEMP_OUT_L 0x42
#define GYRO_XOUT_H 0x43
#define GYRO_XOUT_L 0x44
#define GYRO_YOUT_H 0x45
#define GYRO_YOUT_L 0x46
#define GYRO_ZOUT_H 0x47
#define GYRO_ZOUT_L 0x48
#define PWR_MGMT_1 0x6B //电源管理,典型值:0x00(正常启用)
#define WHO_AM_I 0x75 //IIC地址寄存器(默认数值0x68,只读)
#define SlaveAddress 0xD0 //IIC写入时的地址字节数据,+1为读取
uchar dis[4];
int dis_data;
//整数转字符串
void lcd_printf(uchar *s,int temp_data)
if(temp_data<0)
temp_data=-temp_data;
*s='-';
else *s=' ';
*++s =temp_data/100+0x30;
temp_data=temp_data%100; //取余运算
*++s =temp_data/10+0x30;
temp_data=temp_data%10; //取余运算
*++s =temp_data+0x30;
void delay(unsigned int k)
unsigned int i,j;
for(i=0;i { for(j=0;j<121;j++); } } void WaitForEnable(void) { DataPort=0xff; LCM_RS=0;LCM_RW=1;_nop_(); LCM_EN=1;_nop_();_nop_(); while(DataPort&0x80); LCM_EN=0; } void WriteCommandLCM(uchar CMD) { WaitForEnable(); LCM_RS=0;LCM_RW=0;_nop_(); DataPort=CMD;_nop_(); LCM_EN=1;_nop_();_nop_();LCM_EN=0; } void WriteDataLCM(uchar dataW) { WaitForEnable(); LCM_EN=0;LCM_RS=1;LCM_RW=0;_nop_(); DataPort=dataW;_nop_(); LCM_EN=1;_nop_();LCM_EN=0;_nop_(); } void LcdPos_xy(unsigned char x,unsigned char y) { unsigned char pos; switch(x) { case 1:pos=0x80+y-1;break; case 2:pos=0x90+y-1;break; case 3:pos=0x88+y-1;break; case 4:pos=0x98+y-1;break; default:pos=0x80+y-1;break; } WriteCommandLCM(pos|0x80); } void DisplayListChar(uchar X,uchar Y,uchar *DData) { LcdPos_xy(X,Y); while(*DData) { WriteDataLCM(*DData++); } } void InitLcd() { LCD12864_PSB = 1;//并行通信 LCD12864_RSET = 0; delay(10); LCD12864_RSET = 1; WriteCommandLCM(0x30); delay(5); WriteCommandLCM(0x30); delay(5); WriteCommandLCM(0x18); delay(5); WriteCommandLCM(0x10); delay(5); WriteCommandLCM(0x01); delay(5); WriteCommandLCM(0x06); delay(5); WriteCommandLCM(0x0c); delay(5); DisplayListChar(1,2,"加速度"); DisplayListChar(1,6,"角速度"); DisplayListChar(2,1,"X:"); DisplayListChar(3,1,"Y:"); DisplayListChar(4,1,"Z:"); } void Delay5us() { _nop_();_nop_();_nop_();_nop_(); _nop_();_nop_();_nop_();_nop_(); _nop_();_nop_();_nop_();_nop_(); _nop_();_nop_();_nop_();_nop_(); _nop_();_nop_();_nop_();_nop_(); _nop_();_nop_();_nop_();_nop_(); } //************************************** //I2C起始信号 //************************************** void I2C_Start() { SDA = 1; //拉高数据线 SCL = 1; //拉高时钟线 Delay5us(); //延时 SDA = 0; //产生下降沿 Delay5us(); //延时 SCL = 0; //拉低时钟线 } //************************************** //I2C停止信号 //************************************** void I2C_Stop() { SDA = 0; //拉低数据线 SCL = 1; //拉高时钟线 Delay5us(); //延时 SDA = 1; //产生上升沿 Delay5us(); //延时 } //************************************** //I2C发送应答信号 //入口参数:ack (0:ACK 1:NAK) //************************************** void I2C_SendACK(bit ack) { SDA = ack; //写应答信号 SCL = 1; //拉高时钟线 Delay5us(); //延时 SCL = 0; //拉低时钟线 Delay5us(); //延时 } //************************************** //I2C接收应答信号 //************************************** bit I2C_RecvACK() { SCL = 1; //拉高时钟线 Delay5us(); //延时 CY = SDA; //读应答信号 SCL = 0; //拉低时钟线 Delay5us(); //延时 return CY; } //************************************** //向I2C总线发送一个字节数据 //************************************** void I2C_SendByte(uchar dat) { uchar i; for (i=0; i<8; i++) //8位计数器 { dat <<= 1; //移出数据的最高位 SDA = CY; //送数据口 SCL = 1;
