8x8LED点阵原理
当 MR 为高电平,OE 为低电平时,数据在 SHCP 上升沿进入移位寄存器,在
STCP 上升沿输出到并行端口。
74595 的数据端:
QA–QH: 八位并行输出端,可以直接控制数码管的 8 个段。
QH’: 级联输出端。我将它接下一个 595 的 SI 端。
SI: 串行数据输入端。74595 的控制端说明:
/SCLR(10 脚): 低点平时将移位寄存器的数据清零。通常我将它接 Vcc。
SCK(11 脚):上升沿时数据寄存器的数据移位。 QA–>QB–>QC–>…–>QH;下
降沿移位寄存器数据不变。(脉冲宽度: 5V 时,大于几十纳秒就行了。)
RCK(12 脚):上升沿时移位寄存器的数据进入数据存储寄存器,下降沿时存储寄
存器数据不变。通常我将 RCK 置为低点平,当移位结束后,在 RCK 端产生一
个正脉冲( 5V 时,大于几十纳秒就行了。我通常都选微秒级),更新显示数据。
# include
#include
typedef unsigned int u16;
typedef unsigned char u8;
sbit SER=P3^4;
sbit CLK=P3^5;
sbit SRCLK=P3^6;
u8 code ledwidth[][8]={{0x00,0x00,0x3e,0x41,0x41,0x41,0x3e,0x00}, //0
{0x00,0x00,0x00,0x00,0x21,0x7f,0x01,0x00}, //1
{0x00,0x00,0x27,0x45,0x45,0x45,0x39,0x00}, //2
{0x00,0x00,0x22,0x49,0x49,0x49,0x36,0x00}, //3
{0x00,0x00,0x0c,0x14,0x24,0x7f,0x04,0x00}, //4
{0x00,0x00,0x72,0x51,0x51,0x51,0x4e,0x00}, //5
{0x00,0x00,0x3e,0x49,0x49,0x49,0x26,0x00}, //6
{0x00,0x00,0x40,0x40,0x40,0x4f,0x70,0x00}, //7
{0x00,0x00,0x36,0x49,0x49,0x49,0x36,0x00}, //8
{0x00,0x00,0x32,0x49,0x49,0x49,0x3e,0x00}, //9
{0x00,0x00,0x7F,0x48,0x48,0x30,0x00,0x00}, //P
{0x00,0x00,0x7F,0x48,0x4C,0x73,0x00,0x00}, //R
{0x00,0x00,0x7F,0x49,0x49,0x49,0x00,0x00}, //E
{0x00,0x00,0x3E,0x41,0x41,0x62,0x00,0x00}, //C
{0x00,0x00,0x7F,0x08,0x08,0x7F,0x00,0x00}, //H
{0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00}, //I
{0x00,0x7F,0x10,0x08,0x04,0x7F,0x00,0x00}, //N
{0x00,0x12,0x14,0x78,0x14,0x12,0x00,0x00}, //大
{0x00,0x08,0x12,0x01,0xFF,0x00,0x10,0x08}, //小
{0x7F,0x41,0x5D,0x55,0x5D,0x41,0x7F,0x00}, //回
{0x7C,0x48,0x48,0xFF,0x48,0x48,0x7C,0x00}}; //中
u16 ledlength[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
void delay_ms(u16 i)
while(i--);
void send(u8 n)
u8 i;
CLK=0;
SRCLK=0;
for(i=0;i<8;i++)
SER=n>>7;
n<<=1;
SRCLK=0;
SRCLK=1;
CLK=1;
int main()
u16 n,i,j=0;
while(1)
for(i=0;i<100;i++)
for(n=0;n<8;n++)
P0=ledlength[n];
send(ledwidth[j][n]);
delay_ms(50);
P0=0xff;
send(0x00);
j++;
j%=21;
return 0;
