单片机源程序如下:
#include
void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);
void ConfigTimer0(unsigned int ms);
unsigned char IntToString(unsigned char *str, int dat);
extern bit Start18B20();
extern bit Get18B20Temp(int *temp);
extern void InitLcd1602();
bit DHT_Start();
void aj (void);
bit DHT_ByteRead(unsigned char *dat);
sbit K1=P1^4; ///引脚声明
sbit K2=P1^5;
sbit K3=P1^6;
sbit K4=P1^7;
sbit M1=P1^0;
sbit M2=P1^1;
sbit M3=P1^2;
sbit M4=P1^3;
sbit D1=P2^7;
sbit D2=P2^6;
sbit KD1=P2^3;
sbit KD2=P2^4;
///////////////////////////// 数组命名
int SD,WD,x,xx,SDC,WDC,PWM1,PWM2;
int KK1,KK2;
int wdg=40,wdd=20,sdg=80,sdd=60;
bit SZ,JB;
bit flag1s = 0; //1s定时标志
unsigned char T0RH = 0; //T0重载值的高字节
unsigned char T0RL = 0; //T0重载值的低字节
///////////////////////////////// 延时子程序
void delay ()
x=99999;
while(x--);
void main() ////////////////主程序
bit tmp;
unsigned char str[12];
unsigned char DHT[5];
////初始化///////////////////////
EA = 1; //开总中断
ConfigTimer0(10); //T0定时10ms
InitLcd1602(); //初始化液晶
M1=0; M1=0;M2=0;M3=0;D1=0;D2=0;
DHT_Start();
delay();
delay();
delay();
delay();
while (1)
LcdShowStr(0, 0, "WD"); //显示到液晶屏上
LcdShowStr(0, 1, "SD"); //显示到液晶屏上
LcdShowStr(5, 0, "H"); //显示到液晶屏上
LcdShowStr(5, 1, "H"); //显示到液晶屏上
LcdShowStr(9, 0, "L"); //显示到液晶屏上
LcdShowStr(9, 1, "L"); //显示到液晶屏上
if (flag1s) //每秒更新一次温度
str[0] = (wdg/10)%10 + '0'; //十位转为ASCII码
str[1] = (wdg%10) + '0'; //个位转为ASCII
str[2] = '
