Coder : Farman
Date : 2018-01-02
参考了厂家的TM1637数据手册,在此表示感谢。
#include
#include "Delay.h"
sbit I2C_SCL = P2^1; //定义模拟IIC总线的时钟线
sbit I2C_SDA = P2^0; //定义模拟IIC总线的数据线
#define TM1637_BRIGHTNESS 7 // 0 - 7
void I2C_delay()
nop_();
void I2C_start()
I2C_SCL = 1;
I2C_SDA = 1;
I2C_delay();
I2C_SDA = 0; // 时钟线设置为常态,低电平。
I2C 总线写1个字节
不包含应答位的检测
void I2C_write_byte(char byte_to_write)
unsigned char i;
for(i=0; i<8; i++)
I2C_SCL = 0;
I2C_SDA = byte_to_write & 0x01;
I2C_delay();
I2C_SCL = 1;
I2C_delay();
I2C_SCL = 0;
I2C_delay();
byte_to_write >>= 1;
return;
void I2C_check_ack()
// I2C 检查应答位,实际未检查,只发送了应答位时钟,认为TM1637工作正常
I2C_SCL = 0;
I2C_delay();//在第八个时钟下降沿之后延时5us,开始判断ACK 信号
while(I2C_SDA)
I2C_SCL = 1;
I2C_delay();
I2C_SCL=0;
void I2C_send_ack()
I2C_SDA = 0;
I2C_delay();
I2C_SCL = 1;
I2C_delay();
I2C_SCL = 0;
I2C_delay();
I2C_SDA = 1;
I2C_delay();
void I2C_stop()
I2C_SCL = 0;
I2C_delay();
I2C_SDA = 0;
I2C_delay();
I2C_SCL = 1;
I2C_delay();
I2C_SDA = 1;
// TM1637模块操作函数
void TM1637_write_command_byte(unsigned char command)
I2C_start();
I2C_write_byte(command);
I2C_check_ack();
I2C_stop();
// bright : 0 - 7
void TM1637_display_switch_and_bright(bit enable_display, unsigned char bright)
TM1637_write_command_byte(0x80 + (enable_display ? 0x08 : 0x00) + bright);
void TM1637_write_display_bytes(unsigned char first_addr,
unsigned char bytes_to_write[],
unsigned char num_of_bytes)
unsigned char i;
I2C_start();
I2C_write_byte(0x40);
I2C_check_ack();
I2C_stop();
I2C_start();
I2C_write_byte(0xC0 + first_addr);
I2C_check_ack();
for(i=0; i { I2C_write_byte(bytes_to_write[i]); I2C_check_ack(); } I2C_stop(); } // addr: 0 - 5 void TM1637_write_display_byte(unsigned char addr, unsigned char segments) { I2C_start(); I2C_write_byte(0x40 + addr); I2C_check_ack(); I2C_stop(); I2C_start(); I2C_write_byte(0xC0 + addr); I2C_check_ack(); I2C_write_byte(segments); I2C_check_ack(); I2C_stop(); } code unsigned char TM1637_SEG_TAB[] = { 0x3F // 00111111 0 ,0x06 // 00000110 1 ,0x5B // 01011011 2 ,0x4F // 01001111 3 ,0x66 // 01100110 4 ,0x6d // 01101101 5 ,0x7d // 01111101 6 ,0x07 // 00000111 7 ,0x7F // 01111111 8 ,0x6F // 01101111 9 ,0x77 // 01110111 A ,0x7C // 01111100 b ,0x39 // 00111001 C ,0x5E // 01011110 d ,0x79 // 01111001 E ,0x71 // 01110001 F }; void TM1637_show_digit(unsigned char pos, unsigned char digit, bit with_dot) { TM1637_write_display_byte(pos, TM1637_SEG_TAB[digit] | (with_dot ? 0x20 : 0x00)); } void TM1637_init() { unsigned char i; TM1637_display_switch_and_bright(1, TM1637_BRIGHTNESS); for(i=0; i<6; i++) { TM1637_write_display_byte(i, 0xFF); } Delay200ms(); for(i=0; i<6; i++) { TM1637_write_display_byte(i, 0x00); } Delay200ms(); for(i=0; i<6; i++) { TM1637_write_display_byte(i, 0xFF); } Delay200ms(); for(i=0; i<6; i++) { TM1637_write_display_byte(i, 0x00); } Delay200ms(); } void TM1637() { unsigned char seg; unsigned char i, j; TM1637_init(); while(1) { for(i=0; i<16; i++) { for(j=0; j<6; j++) { TM1637_show_digit(j, i, 0); } Delay1s(); } } }
