调光基于12c5a60s2程序:
#include
//#include
#include
#include
#include
#define uchar unsigned char
#define uint unsigned int
#define FSCLK 11059200
#define Number 29
unsigned char Receive,i;
unsigned int n,flag;
unsigned char Receive_table[15];
#define RELOAD_COUNT 0xFA
sbit LED0=P0^2;
sbit DAI = P3^2;
sbit k1=P2^0;
sbit k2=P2^1;
sbit k3=P2^2;
sbit k4=P2^3;
sbit k5=P2^4;
sbit k6=P2^5;
sbit k7=P2^6;
sbit k8=P2^7;
sbit p13=P1^3;
uint speed = 0;
uchar flag_clr = 0;
uchar Table_R[8]={ 0, 0,255, 0,255,255,255,0};
uchar Table_G[8]={255, 0, 0,255, 0,255,255,0};
uchar Table_B[8]={ 0,255, 0,255,255, 0,255,0};
uchar code Table[256] = {
0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,
20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,
40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,
60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,
80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,
100,101,102,103,104,105,106,107,108,109,110,111,112,113,114,115,116,117,118,119,
120,121,122,123,124,125,126,127,128,129,130,131,132,133,134,135,136,137,138,139,
140,141,142,143,144,145,146,147,148,149,150,151,152,153,154,155,156,157,158,159,
160,161,162,163,164,165,166,167,168,169,170,171,172,173,174,175,176,177,178,179,
180,181,182,183,184,185,186,187,188,189,190,191,192,193,194,195,196,197,198,199,
200,201,202,203,204,205,206,207,208,209,210,211,212,213,214,215,216,217,218,219,
220,221,222,223,224,225,226,227,228,229,230,231,232,233,234,235,236,237,238,239,
240,241,242,243,244,245,246,247,248,249,250,251,252,253,254,255
unsigned char CCAPOH,ID;
float res0,res1;
** 函数功能 :延时函数
** 函数说明 :利用软件延时,占用CPU,经调试最小单位大约为1ms
** 入口参数 :time:需要延时的时间,单位ms
** 出口参数 :无
void Delay_ms(uint time)
uint i,j;
for(i = 0;i < time;i ++)
for(j = 0;j < 930;j ++);
void ms_delay(unsigned int t)
unsigned int i,j;
for(i=t;i>0;i--)
for(j=110;j>0;j--);
void us_delay(unsigned int t)
while(t--);
void rst()
uint s;
DAI=0;
for(s=0;s<1000;s++);
{_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();}
void Delay_Fash (uint x) // 1ms Delay
uint t;
t = 0;
while (x--)
for (t = 0; t < 5000; t++);
void Delay(uint x) // 1ms Delay
uint t;
t = 0;
while (x--)
for (t = 0; t < 330; t++);
/*uart初始化*/
void Uart_Init()//使用独立的波特率发生器(STC12C560S2或带有独立波特率发生器//、//的单片机均可)
SCON=0x50; //设置为串行口以方式1工作,8位异步通讯,允许接收中断。
PCON=0x80; //SMOD波特率选择位为1,SMOD=1.
BRT=0xfa;//波特率9600 256-晶振频率/波特率x16=BRT
AUXR=0x11; //T0、T1不12分频,速度是89C51的12倍,启动独立波特率//发生器,每个时钟计数一次
//设置串口1的波特率发生器为独立波特率发生器,
// AUXR1=0x80; //切换到P1口
ES=1; //开启串口中断
EA=1; //开启总中断
void Send_Uart(unsigned char value){//向WIFI模块发送数据
ES=0;
TI=0;
SBUF=value;//发送完后TI变1
while(!TI);
TI=0;
ES=1;
/*给esp8266发送指令*/
void ESP8266_Set(unsigned char *puf)
while(*puf){
Send_Uart(*puf);
us_delay(5);
puf++;
us_delay(5);
Send_Uart('r');
us_delay(5);
Send_Uart('n');
ms_delay(20000);
void code0()
DAI=1;
_nop_();
DAI=0;
_nop_(); _nop_();_nop_();_nop_();
void code1()
DAI=1;
DAI=0;
_nop_();_nop_(); _nop_(); _nop_();
//打开灯
void bright()
{ unsigned int j;
for(j=0;j<720;j++)code1();
//关闭灯函数
void dark()
{ unsigned int j;
for(j=0;j<720;j++)code0();
void send_2811_24bits(uchar dat1,uchar dat2,uchar dat3)
uchar a;
// uchar b;
for(a=0;a<8;a++) //dat1
if(dat1&0x80)
code1();
else
code0();
dat1=dat1<<1;
for(a=0;a<8;a++) //dat2
if(dat2&0x80)
code1();
else
code0();
dat2=dat2<<1;
for(a=0;a<8;a++) //dat3
if(dat3&0x80)
code1();
else
