开发环境:mplab 3.45 harmony 1.09 xc32 1.42
源代码下载:/zixunimg/eeworldimg/download.csdn.net/detail/zn2857/9712707
源代码分析:
void APP_Tasks ( void )
/* Check the application's current state. */
switch ( appData.state )
/* Application's initial state. */
case APP_STATE_INIT:
bool appInitialized = true;
if (appInitialized)
/* Open the USART Driver for USART1 Client */
appData.drvUartHandle = DRV_USART_Open( DRV_USART_INDEX_0,DRV_IO_INTENT_READWRITE );
appData.state = APP_STATE_CHECK_DRVR_STATE;
break;
case APP_STATE_CHECK_DRVR_STATE:
/* Check the USART1 driver handler */
if (appData.drvUartHandle == DRV_HANDLE_INVALID )
/* Set the uart state to Ready */
appData.state = APP_STATE_INIT;
return;
DRV_USART_ByteReceiveCallbackSet(DRV_USART_INDEX_0, (DRV_USART_BYTE_EVENT_HANDLER)Uart_LoopBack);
appData.state = APP_STATE_IDLE;
break;
case APP_STATE_SERVICE_TASKS:
uint8_t numBytes = 0;
while( numBytes < 1 )
numBytes++;
if( !(DRV_USART_TRANSFER_STATUS_TRANSMIT_FULL & DRV_USART_TransferStatus(appData.drvUartHandle)) )
DRV_USART_WriteByte(appData.drvUartHandle, temp);
break;
case APP_STATE_IDLE:
break;
/* TODO: implement your application state machine.*/
/* The default state should never be executed. */
default:
/* TODO: Handle error in application's state machine. */
break;
