单片机源程序如下:
;* File:FFT v1.0 *
;* Date:2015-10-22 *
;* Version:1.0 *
;* Author:Ben *
;* Wechat:feeling1791 *
// Configuration Mask Definitions
#define CONFIG_ADDR 0x2007
// Oscillator
#define EXTCLK 0x3FFF // External RC Clockout
#define EXTIO 0x3FFE // External RC No Clock
#define INTCLK 0x3FFD // Internal RC Clockout
#define INTIO 0x3FFC // Internal RC No Clock
#define EC 0x3FFB // EC
#define HS 0x3FFA // HS
#define XT 0x3FF9 // XT
#define LP 0x3FF8 // LP
// Watchdog Timer
#define WDTEN 0x3FFF // On
#define WDTDIS 0x3FF7 // Disabled / SWDTEN control
// Power Up Timer
#define PWRTDIS 0x3FFF // Off
#define PWRTEN 0x3FEF // On
// Master Clear Enable
#define MCLREN 0x3FFF // MCLR function is enabled
#define MCLRDIS 0x3FDF // MCLR functions as IO
// Code Protect
#define UNPROTECT 0x3FFF // Code is not protected
#define CP 0x3FBF // Code is protected
// Data EE Read Protect
#define DUNPROTECT 0x3FFF // Do not read protect EEPROM data
#define CPD 0x3F7F // Read protect EEPROM data
// Brown Out Detect
#define BORDIS 0x3CFF // BOD and SBOREN disabled
#define SWBOREN 0x3DFF // SBOREN controls BOR function (Software control)
#define BORXSLP 0x3EFF // BOD enabled in run, disabled in sleep, SBOREN disabled
#define BOREN 0x3FFF // BOD Enabled, SBOREN Disabled
// Internal External Switch Over Mode
#define IESOEN 0x3FFF // Enabled
#define IESODIS 0x3BFF // Disabled
// Monitor Clock Fail-safe
#define FCMEN 0x3FFF // Enabled
#define FCMDIS 0x37FF // Disabled
// Low Voltage Programming
#define LVPDIS 0x2FFF // Disabled
#define LVPEN 0x3FFF // Enabled
// In-Circuit Debugger Mode
#define DEBUGEN 0x1FFF // Enable ICD2 debugging
#define DEBUGDIS 0x3FFF // Disable ICD2 debugging
#define CONFIG_ADDR2 0x2008
// Brown-out Reset Voltage
#define BORV21 0x3EFF // 2.1 Volts
#define BORV40 0x3FFF // 4.0 Volts
// Flash Memory Write Protection
#define WP0 0x3DFF // Protect 0h-0FFh
#define WP1 0x3BFF // Protect lower half of flash
#define WP2 0x39FF // Protect all of flash
#include
__CONFIG(INTIO&WDTDIS&PWRTDIS&MCLREN&BOREN&LVPDIS&DUNPROTECT&DEBUGDIS&UNPROTECT&IESOEN&FCMEN);
#define LOG_NUMBER 5
unsigned char AD_count;
const unsigned char BRTable[32] = {0,16,8,24,4,20,12,28,2,18,10,26,6,22,14,30,
1,17,9,25,5,21,13,29,3,19,11,27,7,23,15,31};
const char SIN_TAB[32] =
{ 0 ,25 ,49 ,71 ,90 ,106 ,117 ,125 ,127 ,
125 ,117 ,106 ,90 ,71 ,49 ,25 ,0 ,
-25 ,-49 ,-71 ,-90 ,-106 ,-117 ,-125 ,-127 ,
-125 ,-117 ,-106 ,-90 ,-71 ,-49 ,-25 };
const char COS_TAB[32] =
{127 ,125 ,117 ,106 ,90 ,71 ,49 ,25 ,0 ,
-125 ,-117 ,-106 ,-90 ,-71 ,-49 ,-25 ,0 ,
25 ,49 ,71 ,90 ,106 ,117 ,125 };
unsigned char disp_time;
unsigned char Led_scan_count;
bit AD_readed_flag = 0;
bit AD_getonce_flag = 0;
bank3 const unsigned char Disp_Number[8]={0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff};//0-7
bank3 const unsigned char Disp_peak[8]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};//0-7
bank3 unsigned char led_num[16];
bank2 unsigned char MAIN_TAB[16];
bank1 unsigned char PEAK_TAB[16];
bank3 unsigned char Peak_speed[16];
bank1 int Fft_Real[32];
bank2 int Fft_Image[32];
unsigned int FFT_value;
void delay_1ms(void)
unsigned int i;
for(i = 0;i < 65;i++);
void delay_ms(unsigned int n)
unsigned int i;
for(i = 0;i < n;i++)
delay_1ms();
void disp(void) //2ms scan 16 segment
PORTD = 0xff;
PORTC = 0xff;
switch(Led_scan_count)
case 1:
PORTB = led_num[0] ;
RD0 = 0;
break;
case 2:
PORTB = led_num[1];
RD1 = 0;
break;
case 3:
PORTB = led_num[2] ;
RD2=0;
