错误 __builtin_avr_delay_cycles expects an integer constant.
经过查找发现是头文件版本更新所致。delay.h文件214行说明如下:
Note: The new implementation of _delay_us(double __us) with
__builtin_avr_delay_cycles(unsigned long) support is not backward compatible.
User can define __DELAY_BACKWARD_COMPATIBLE__ to get a backward compatible delay.
Also, the backward compatible
algorithm will be chosen if the code is compiled in a freestanding
environment (GCC option c -ffreestanding), as the math functions
required for rounding are not available to the compiler then.
这样解决方法就明显了,新的定义和之前的不兼容,
因此调用延时文件#include
例如:
#define F_CPU 8000000UL
#include
#define __DELAY_BACKWARD_COMPATIBLE__
#include
