1.如果内核镜像是压缩的,需要解压缩,引导的第一步是从解压缩开始:archarmbootcompressedhead.S
2.解压缩之后,内核镜像已经存在于ARM中了,下面开始运行,内核开始运行是从/arch/arm/kernel/head.S开始的,入口代码为:
1 2 3 4 5 6 7 8 | .arm __HEAD ENTRY(stext) THUMB(adrr9,BSYM(1f))@KernelisalwaysenteredinARM. THUMB(bxr9)@IfthisisaThumb-2kernel, THUMB(.thumb)@switchtoThumbnow. THUMB(1:) |
这是由/arch/arm/kernel/vmlinux.lds.S决定的。告诉我们入口点为stext.
1 2 | OUTPUT_ARCH(arm) ENTRY(stext) |
3.顺序执行head.S的代码。
1 2 3 4 5 6 7 8 | ldrr13,=__switch_data@addresstojumptoafter @mmuhasbeenenabled adrlr,BSYM(1f)@return(PIC)address movr8,r4@setTTBR1toswapper_pg_dir ARM(addpc,r10,#PROCINFO_INITFUNC) THUMB(addr12,r10,#PROCINFO_INITFUNC) THUMB(movpc,r12) 1:b__enable_mmu |
代码line1将__switch_data的地址赋给r13,在__enable_mmu(代码line8)执行成功后跳转到__switch_data执行。
因为是.arm环境,所以执行代码ARM(addpc,r10,#PROCINFO_INITFUNC),即跳转到__cpu_flush执行。
1 2 3 4 | /arch/arm/kernel/head.S mrcp15,0,r9,c0,c0@getprocessorid bl__lookup_processor_type@r5=procinfor9=cpuid movsr10,r5@invalidprocessor(r5=0)? |
r10中保存的是proc_info结构体的startaddress.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 | archarmincludeasmProcinfo.h structproc_info_list{ unsignedintcpu_val; unsignedintcpu_mask; unsignedlong__cpu_mm_mmu_flags;/*usedbyhead.S*/ unsignedlong__cpu_io_mmu_flags;/*usedbyhead.S*/ unsignedlong__cpu_flush;/*usedbyhead.S*/ constchar*arch_name; constchar*elf_name; unsignedintelf_hwcap; constchar*cpu_name; structprocessor*proc; structcpu_tlb_fns*tlb; structcpu_user_fns*user; structcpu_cache_fns*cache; }; |
1 2 | include/generated/asm-offsets.h #definePROCINFO_INITFUNC16 |
4.__cpu_flush
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 | arch/arm/mm/proc-v7.S __v7_ca9mp_proc_info: .long0x410fc090 .long0xff0ffff0 __v7_proc__v7_ca9mp_setup .macro__v7_procinitfunc,mm_mmuflags=0,io_mmuflags=0,hwcaps=0 ALT_SMP(.longPMD_TYPE_SECT|PMD_SECT_AP_WRITE|PMD_SECT_AP_READ| PMD_SECT_AF|PMD_FLAGS_SMP|mm_mmuflags) ALT_UP(.longPMD_TYPE_SECT|PMD_SECT_AP_WRITE|PMD_SECT_AP_READ| PMD_SECT_AF|PMD_FLAGS_UP|mm_mmuflags) .longPMD_TYPE_SECT|PMD_SECT_AP_WRITE| PMD_SECT_AP_READ|PMD_SECT_AF|io_mmuflags W(b)initfunc __v7_ca5mp_setup: __v7_ca9mp_setup: movr10,#(1< b1f __v7_ca7mp_setup: __v7_ca15mp_setup: movr10,#0 |
不同架构的CPU,针对的文件不同,对于ARMV7架构的cpu而言,对应的为proc-v7.S。从code中可以看出,其对应俄proc_info为__v7_ca9mp_proc_info,所以偏移16后,就是执行跳转代码b1f。
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 | __CPUINIT /* *__v7_setup * *InitialiseTLB,Caches,andMMUstatereadytoswitchtheMMU *on.Returninr0thenewCP15C1controlregistersetting. * *ThisshouldbeabletocoverallARMv7cores. * *Itisassumedthat: *-cachetyperegisterisimplemented */ __v7_ca5mp_setup: __v7_ca9mp_setup: movr10,#(1< b1f __v7_ca7mp_setup: __v7_ca15mp_setup: movr10,#0 1: #ifdefCONFIG_SMP ALT_SMP(mrcp15,0,r0,c1,c0,1) ALT_UP(movr0,#(1< tstr0,#(1< orreqr0,r0,#(1< orreqr0,r0,r10@EnableCPU-specificSMPbits mcreqp15,0,r0,c1,c0,1 #endif __v7_setup: |
5.__v7_setup->__enable_mmu->__turn_mmu_on
1 2 3 4 5 6 7 8 | __turn_mmu_on: movr0,r0 mcrp15,0,r0,c1,c0,0@writecontrolreg mrcp15,0,r3,c0,c0,0@readidreg movr3,r3 movr3,r3 movpc,r13 ENDPROC(__turn_mmu_on) |
r13保存的是__switch_data的地址,movpc,r13跳转到__switch_data.
6.__mmap_switched
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 | .type__switch_data,%object __switch_data: .long__mmap_switched .long__data_loc@r4 .long_data@r5 .long__bss_start@r6 .long _end @ r7 |
