之所以说是驱动移植是因为之前已经在TQ210、AM335x两个平台上移植过了,因此,仅需要少量修改就可以将驱动移植到imx6q。下面开始触摸驱动移植。
DTS编写
参考其它DTS的i2c设备写法,我们可以添加如下内容:
&i2c1 {
clock-frequency = <100000>;
pinctrl-names = "default";
pinctrl-0 = ;
status = "okay";
gt811@5d {
compatible = "gt811,gt811_ts";
reg = <0x5d>;
interrupt-parent = ;
interrupts = <9 2>;
gpios = ;
touchscreen-size-x = <800>;
touchscreen-size-y = <480>;
touchscreen-swap = <1>;
touchscreen-revert-x = <1>;
touchscreen-revert-y = <1>;
添加以上内容后重新编译并烧写DTB。
驱动编写
其实移植AM335x的时候就是以DTB方式移植的,因此,除内核api变更的部分需要修改一下,其它代码基本是不需要修改的。驱动代码如下(不含event上报代码):
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
struct gt811_ts_platdata
u32 size_x;
u32 size_y;
u32 size_p;
u32 swap;
u32 revert_x;
u32 revert_y;
u32 reset_pin;
u32 interrupt_pin;
u32 ponits_max;
struct i2c_client *client;
struct input_dev *input;
struct work_struct work;
static const struct of_device_id gt811_ts_of_match[] = {
{ .compatible = "gt811,gt811_ts", .data = NULL },
static int i2c_write_bytes(struct i2c_client *client, uint8_t *data, int len){
struct i2c_msg msg;
msg.flags=!I2C_M_RD;
msg.addr=client->addr;
msg.len=len;
msg.buf=data;
return i2c_transfer(client->adapter,&msg, 1);
static int i2c_read_bytes(struct i2c_client *client, uint8_t *buf, int len){
struct i2c_msg msgs[2];
msgs[0].flags=!I2C_M_RD;
msgs[0].addr=client->addr;
msgs[0].len=2;
msgs[0].buf=&buf[0];
msgs[1].flags=I2C_M_RD;
msgs[1].addr=client->addr;
msgs[1].len=len-2;
msgs[1].buf=&buf[2];
return i2c_transfer(client->adapter,msgs, 2);
static void gt811_ts_handler(struct work_struct *work)
struct gt811_ts_platdata *pdata = container_of(work, struct gt811_ts_platdata, work);
struct device *dev = &pdata->client->dev;
uint8_t buffer[36] = {0x07, 0x21, 0};
struct input_mt_pos pos[5];
int slots[5], slot;
uint8_t count, index, flags, position;
buffer[0] = 0x0f;
buffer[1] = 0xff;
if (i2c_write_bytes(pdata->client,buffer,2) < 0) {
dev_err(dev, "Failed to write wakeup message.n");
goto reenable_irq;
buffer[0] = 0x07;
buffer[1] = 0x21;
if (i2c_read_bytes(pdata->client, buffer, sizeof(buffer)) < 0) {
dev_err(dev, "Failed to read touch message.n");
goto reenable_irq;
buffer[0] = 0x80;
buffer[1] = 0x00;
if (i2c_write_bytes(pdata->client, buffer, 2) < 0) {
dev_err(dev, "Failed to write sleep message.n");
goto reenable_irq;
buffer[25] = buffer[19];
buffer[19] = 0;
flags = buffer[2]&0x1f;
count = 0;
for (index = 0; index < 5 && flags; ++index, flags >>= 1) {
if (!(flags&0x1)) {
continue;
if (index < 3) {
position = 4 + index * 5;
else{
position = 25 + (index - 3) * 5;
pos[count].x = (buffer[position] << 8) | buffer[position + 1];
pos[count].y = (buffer[position + 2] << 8) | buffer[position + 3];
slots[count] = index;
if(pdata->swap) {
swap(pos[count].x, pos[count].y);
if(pdata->revert_x){
pos[count].x = pdata->size_x - pos[count].x;
if(pdata->revert_y){
pos[count].y = pdata->size_y - pos[count].y;
++count;
// 在这个位置添加event上报代码
reenable_irq:
enable_irq(pdata->client->irq);
static irqreturn_t gt811_ts_isr(int irq, void *dev_id)
struct gt811_ts_platdata* pdata = (struct gt811_ts_platdata*)dev_id;
disable_irq_nosync(pdata->client->irq);
schedule_work(&pdata->work);
return IRQ_HANDLED;
static int gt811_ts_initilize(struct i2c_client *client)
struct device *dev = &client->dev;
struct gt811_ts_platdata *pdata = (struct gt811_ts_platdata*)i2c_get_clientdata(client);
int status = 0, count = 0;
uint8_t version[4] = {0x7, 0x17, 0};
uint8_t config[] = {
0x06,0xA2,
0x12,0x10,0x0E,0x0C,0x0A,0x08,0x06,0x04,0x02,0x00,0xE2,0x53,0xD2,0x53,0xC2,0x53,
0xB2,0x53,0xA2,0x53,0x92,0x53,0x82,0x53,0x72,0x53,0x62,0x53,0x52,0x53,0x42,0x53,
0x32,0x53,0x22,0x53,0x12,0x53,0x02,0x53,0xF2,0x53,0x0F,0x13,0x40,0x40,0x40,0x10,
0x10,0x10,0x0F,0x0F,0x0A,0x35,0x25,0x0C,0x03,0x00,0x05,0x20,0x03,0xE0,0x01,0x00,
0x00,0x34,0x2C,0x36,0x2E,0x00,0x00,0x03,0x19,0x03,0x08,0x00,0x00,0x00,0x00,0x00,
0x14,0x10,0xEC,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0D,0x40,
0x30,0x3C,0x28,0x00,0x00,0x00,0x00,0xC0,0x12,0x01
config[62] = 480 >> 8;
config[61] = 480 & 0xff;
config[64] = 800 >> 8;
config[63] = 800 & 0xff;
if (!gpio_is_valid(pdata->reset_pin)) {
dev_err(dev, "The reset pin number is invalid.n");
return -EINVAL;
count = 3;
while (count--) {
gpio_direction_output(pdata->reset_pin, 0);
msleep(10);
gpio_direction_output(pdata->reset_pin, 1);
msleep(100);
if (i2c_read_bytes(client, version, sizeof(version)) < 0) {
dev_err(dev, "Failed to get the version of GT811, try again...n");
status = -ENODEV;
else {
dev_info(dev, "Gt811 detected, version(%04x)...n", (version[2]<<8)|version[3]);
status = 0;
break;
if (status) {
return status;
count = 3;
while (count--) {
if (i2c_write_bytes(client, config, sizeof(config)) < 0) {
dev_err(dev, "Failed to configure the GT811, try again...n");
status = -EINVAL;
else {
dev_info(dev, "Gt811 configue succeedn");
status = 0;
break;
return status;
static struct gt811_ts_platdata *gt811_ts_parse_devtree(struct i2c_client *client)
struct device_node *node;
struct gt811_ts_platdata *pdata;
enum of_gpio_flags flags;
node = dev->of_node;
if (!node) {
dev_err(dev, "The of_node is NULL.n");
return ERR_PTR(-ENODEV);
pdata = devm_kzalloc(dev, sizeof(struct device_node), GFP_KERNEL);
if (!pdata) {
dev_err(dev, "No enough memory left.n");
return ERR_PTR(-ENOMEM);
pdata->reset_pin = of_get_gpio_flags(node, 0, &flags);
if (pdata->reset_pin < 0) {
dev_err(dev, "Get RST pin failed!n");
return ERR_PTR(-EINVAL);
if (of_property_read_u32(node, "touchscreen-size-x", &pdata->size_x )) {
dev_err(dev, "Failed to get the touch screen x size.n");
if (of_property_read_u32(node, "touchscreen-size-y", &pdata->size_y)) {
dev_err(dev, "Failed to get the touch screen y size.n");
if (of_property_read_u32(node, "touchscreen-size-p", &pdata->size_p)) {
pdata->size_p = 255;
if (of_property_read_u32(node, "touchscreen-swap", &pdata->swap)) {
pdata->swap = 1;
if (of_property_read_u32(node, "touchscreen-revert-x", &pdata->revert_x)) {
pdata->revert_x = 1;
if (of_property_read_u32(node, "touchscreen-revert-y", &pdata->revert_y)) {
pdata->revert_y = 1;
return pdata;
static int gt811_ts_probe(struct i2c_client *client, const struct i2c_device_id *id)
struct gt811_ts_platdata *pdata = dev_get_platdata(dev);
int error = 0;
if (!of_match_device(of_match_ptr(gt811_ts_of_match), dev)) {
dev_err(dev, "Failed to match.n");
return -EINVAL;
if (!pdata) {
pdata = gt811_ts_parse_devtree(client);
if (IS_ERR(pdata)) {
dev_err(dev, "Get device data from device tree failed!n");
error = -EINVAL;
goto failed_exit;
pdata->client = client;
i2c_set_clientdata(client, pdata);
error = devm_gpio_request_one(&client->dev, pdata->reset_pin,
GPIOF_OUT_INIT_HIGH, "gt811_rst_pin");
if (error < 0) {
dev_err(dev, "Failed to request gt811 reset pinn");
return error;
input = devm_input_allocate_device(dev);
if (!input) {
dev_err(dev, "Failed to allocate input devicen");
error = -ENOMEM;
goto pdata_free;
pdata->input = input;
input->name = client->name;
input->id.bustype = BUS_I2C;
input->id.product = 0xBEEF;
input->id.vendor =0xDEAD;
input->dev.parent = &client->dev;
__set_bit(EV_KEY, input->evbit);
__set_bit(EV_ABS, input->evbit);
__set_bit(BTN_TOUCH, input->keybit);
input_set_abs_params(input, ABS_X, 0, pdata->size_x, 0, 0);
input_set_abs_params(input, ABS_Y, 0, pdata->size_y, 0, 0);
input_set_abs_params(input, ABS_MT_POSITION_X, 0, pdata->size_x, 0, 0);
input_set_abs_params(input, ABS_MT_POSITION_Y, 0, pdata->size_y, 0, 0);
error = input_mt_init_slots(input, 5, INPUT_MT_DIRECT | INPUT_MT_DROP_UNUSED);
if (error) {
dev_err(dev, "Failed to initialize the multi-touch slots.n");
goto input_free;
input_set_drvdata(input, pdata);
error = input_register_device(input);
if (error) {
dev_err(dev, "Register input de
