参数配置:
开发板型号TX2440; 一个像素点采用16位表示; LCD屏幕分辨率 480*272; 液晶模块型号:BL43014_SPEC;图像的内容以C语言数组的形式保存在bmp.c文件中。
*版权所有(C)2015,ZJU
*文件名称:lcd.c
*内容摘要:关于lcd的配置
*其它说明:开发板型号: TX2440
* led显示尺寸 480 x 272
液晶模块型号:BL43014_SPEC
*当前版本:V1.0
*作 者:Frank
*完成日期:2015.12.20
#define GPCCON (*(volatile unsigned long *)0x56000020)
#define GPDCON (*(volatile unsigned long *)0x56000030)
#define GPGCON (*(volatile unsigned long *)0x56000060)
//LCD控制寄存器定义
#define LCDCON1 (*(volatile unsigned long *)0x4D000000)
#define LCDCON2 (*(volatile unsigned long *)0x4D000004)
#define LCDCON3 (*(volatile unsigned long *)0x4D000008)
#define LCDCON4 (*(volatile unsigned long *)0x4D00000C)
#define LCDCON5 (*(volatile unsigned long *)0x4D000010)
#define LCDSADDR1 (*(volatile unsigned long *)0x4D000014)
#define LCDSADDR2 (*(volatile unsigned long *)0x4D000018)
#define LCDSADDR3 (*(volatile unsigned long *)0x4D00001C)
#define TPAL (*(volatile unsigned long *)0x4D000050)
/*以下宏定义的值参考所使用的LCD液晶模块的芯片手册*/
#define VSPW 9
#define VBPD 7
#define LINEVAL 271
#define VFPD 7
#define CLKVAL 4 // 10 = 100 / ((CLKVAL+1)*2)
#define HSPW 40
#define HBPD 39
#define HOZVAL 479
#define HFPD 4
unsigned short LCDBUFFER[272][480]; //定义一个LCD图像缓存空间
extern unsigned char bmp[90200];
typedef unsigned char U8;
typedef unsigned short int U16;
typedef unsigned int U32;
*函数名称:Lcd_Port_Init()
*功能描述:LCD端口初始化
*其他说明:配置LCD用到的GPIO端口
*创建日期:2015.12.20
void Lcd_Port_Init(void)
GPDCON = 0xaaaaaaaa;
GPCCON = 0xaaaaaaaa;
*函数名称:Lcd_Control_Init()
*功能描述:LCD控制寄存器初始化
*其他说明:配置LCD用到的控制寄存器
*创建日期:2015.12.20
void Lcd_Control_Init(void)
LCDCON1 = (CLKVAL << 8) | (0x3 << 5) | (0xC << 1) | (0 << 0);
LCDCON2 = (VBPD << 24) | (LINEVAL << 14) | (VFPD << 6) | (VSPW);
LCDCON3 = (HBPD << 19) | (HOZVAL << 8) | (HFPD);
LCDCON4 = HSPW;
// LCDCON5 = (1 << 11) | (1 << 9) | (1 << 8) | (1 << 0);
LCDCON5 = (1 << 11) | (1 << 9) | (1 << 8);
LCDSADDR1 = (((unsigned int)LCDBUFFER >> 22) << 21) | (((unsigned int)LCDBUFFER >> 1) & 0x1fffff);
LCDSADDR2 = (((unsigned int)LCDBUFFER + 272*480*2) >> 1) & 0x1fffff;
LCDSADDR3 = (0 << 11) | (480*2 / 2);
TPAL = 0;
*函数名称:Lcd_Init()
*功能描述:LCD初始化
*其他说明:
*创建日期:2015.12.20
void Lcd_Init()
Lcd_Port_Init();
Lcd_Control_Init();
/*打开LCD电源*/
GPGCON |= (0x3 << 8);
LCDCON5 |= (1 << 3);
/*使能LCD控制器*/
LCDCON1 |= 1;
*函数名称:point()
*功能描述:在lcd上画一个点
*其他说明:
*创建日期:2015.12.20
void Point(unsigned int x, unsigned int y, unsigned int color)
unsigned int red, green, blue;
red = (color >> 19) & 0x1f;
green = (color >> 10) & 0x3f;
blue = (color >> 3) & 0x1f;
/*采用5:6:5的模式表示一个RGB*/
LCDBUFFER[y][x] = (unsigned short)((red << 11) | (green << 5) | blue);
*函数名称:Paint_Bmp(U16,U16,U16,U16,U8)
*功能描述:LCD显示一幅图像
*输入参数:(x0,y0)图像显示第一个点的坐标; high图像的高度
wide图像的宽度; bmp存储图像的数组
*其他说明:
*创建日期:2015.12.20
void Paint_Bmp(U16 x0, U16 y0, U16 wide, U16 high, const U8 *bmp)
unsigned short x, y;
unsigned short c;
unsigned int p = 0;
for (y=y0; y { for (x=x0; x { c = bmp[p] | (bmp[p+1]<<8); /*一个像素点由16位表示,bmp[p] 表示低8位,bmp[p+1]表示高8位*/ if ((x<480) && (y<272)) { LCDBUFFER[y][x] = c; } p = p + 2; } } } /******************************************************************* *函数名称:Lcd_Test() *功能描述:LCD测试函数 *其他说明: *创建日期:2015.12.20 *******************************************************************/ void Lcd_Test(void) { int x; /* for (x=0; x<480; ++x) { Point(x++, 150, 0xff0000); } */ Paint_Bmp(0,0,220,220,bmp); } 需要注意的几点: 1、宏定义的值需要参考使用的LCD液晶模块的芯片手册(TX2440使用的LCD是BL43014_SPEC) 图1 BL43014_SPEC Input Time Table 2、液晶模块的Vsync和Hsync的时序与S3C2440芯片手册上的相反,所以LCDCON5中bit8和bit9需要设置为1。 图2 BL43014_SPEC Vertical Input Timing 图3 TFT LCD Timing Example( S3C2440 Datasheet)
