* (C) Copyright 2002-2006
* Wolfgang Denk, DENX Software Engineering, wd@denx.de.
* Sysgo Real-Time Solutions, GmbH
* Marius Groeger
* See file CREDITS for list of people who contributed to this
* project.
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License as
* published by the Free Software Foundation; either version 2 of
* the License, or (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 59 Temple Place, Suite 330, Boston,
* MA 02111-1307 USA
* To match the U-Boot user interface on ARM platforms to the U-Boot
* standard (as on PPC platforms), some messages with debug character
* are removed from the default U-Boot build.
* Define DEBUG here if you want additional info as shown below
* printed upon startup:
* U-Boot code: 00F00000 -> 00F3C774 BSS: -> 00FC3274
* IRQ Stack: 00ebff7c
* FIQ Stack: 00ebef7c
* /lib_arm/board.c 主要完成了一些初始化的操作,最重要的是有start_armboot函数
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#ifdef CONFIG_GENERIC_MMC
#include
#endif
#undef DEBUG
#ifdef CONFIG_DRIVER_SMC91111
#include "../drivers/net/smc91111.h"
#endif
#ifdef CONFIG_DRIVER_LAN91C96 /* 关于网卡的定义 */
#include "../drivers/net/lan91c96.h"
#endif
DECLARE_GLOBAL_DATA_PTR; /* 声明全局数据指针 */
void nand_init (void);
void onenand_init(void);
ulong monitor_flash_len;
#ifdef CONFIG_HAS_DATAFLASH
extern int AT91F_DataflashInit(void);
extern void dataflash_print_info(void);
#endif
#ifndef CONFIG_IDENT_STRING /* 没有定义CONFIG_IDENT_STRING,定义其为空 */
#define CONFIG_IDENT_STRING ""
#endif
const char version_string[] = /* 版本字符串 */
U_BOOT_VERSION CONFIG_IDENT_STRING;
#ifdef CONFIG_DRIVER_CS8900 /* 定义了CS8900网卡,获取网络地址 */
extern int cs8900_get_enetaddr (uchar * addr);
#endif
#ifdef CONFIG_DRIVER_RTL8019
extern void rtl8019_get_enetaddr (uchar * addr);
#endif
#if defined(CONFIG_HARD_I2C) ||
defined(CONFIG_SOFT_I2C)
#include
#endif
* Begin and End of memory area for malloc(), and current "brk"
* 分配内存
static ulong mem_malloc_start = 0;
static ulong mem_malloc_end = 0;
static ulong mem_malloc_brk = 0;
/* 内存分配初始化 */
static void mem_malloc_init (ulong dest_addr)
mem_malloc_start = dest_addr;
mem_malloc_end = dest_addr + CFG_MALLOC_LEN;
mem_malloc_brk = mem_malloc_start;
memset ((void *) mem_malloc_start, 0,
mem_malloc_end - mem_malloc_start);
/* 所分配内存区的brk指针调整 */
void *sbrk (ptrdiff_t increment)
ulong old = mem_malloc_brk;
ulong new = old + increment;
if ((new < mem_malloc_start) || (new > mem_malloc_end)) {
return (NULL);
mem_malloc_brk = new;
return ((void *) old);
char *strmhz(char *buf, long hz)
long l, n;
long m;
n = hz / 1000000L;
l = sprintf (buf, "%ld", n);
m = (hz % 1000000L) / 1000L;
if (m != 0)
sprintf (buf + l, ".%03ld", m);
return (buf);
* Coloured LED functionality
* May be supplied by boards if desired
void __coloured_LED_init (void) {}
void coloured_LED_init (void)
__attribute__((weak, alias("__coloured_LED_init")));
void __red_LED_on (void) {}
void red_LED_on (void)
__attribute__((weak, alias("__red_LED_on")));
void __red_LED_off(void) {}
void red_LED_off(void) __attribute__((weak, alias("__red_LED_off")));
void __green_LED_on(void) {}
void green_LED_on(void) __attribute__((weak, alias("__green_LED_on")));
void __green_LED_off(void) {}
void green_LED_off(void)__attribute__((weak, alias("__green_LED_off")));
void __yellow_LED_on(void) {}
void yellow_LED_on(void)__attribute__((weak, alias("__yellow_LED_on")));
void __yellow_LED_off(void) {}
void yellow_LED_off(void)__attribute__((weak, alias("__yellow_LED_off")));
* Init Utilities *
* Some of this code should be moved into the core functions,
* or dropped completely,
* but let's get it working (again) first...
#if 0
typedef struct global_data {
bd_t *bd; // 与板子相关的结构,见下面
unsigned long flags; // 指示标志,如设备已经初始化标志等
unsigned long baudrate; // 波特率
unsigned long have_console; /* serial_init() was called */
unsigned long reloc_off; /* Relocation Offset,重定位偏移,一般为0 */
unsigned long env_addr; /* Address of Environment struct ,存放环境变量结构的地址*/
unsigned long env_valid; /* 环境参数CRC检验有效标志 */
#ifdef CONFIG_VFD // 我们一般没有配置这个,这个是frame buffer的首地址
unsigned long fb_base; /* base address of frame buffer,显存缓存区 基址*/
#endif
void **jt; /* jump table ,保存着些函数的入口地址,在common/Exports.c中进行填充*/
} gd_t;
typedef struct bd_info {
int bi_baudrate; /* serial console baudrate ,串口波特率 */
unsigned long bi_ip_addr; /* IP Address ,IP地址*/
unsigned char bi_enetaddr[6]; /* Ethernet adress ,以太网MAC地址*/
struct environment_s *bi_env; /* 环境变量地址指针 */
ulong bi_arch_number; /* unique id for this board 架构号码*/
ulong bi_boot_params; /* where this board expects params启动参数 */
struct /* RAM configuration */
ulong start; /* RAM的起始地址 */
ulong size; /* RAM的大小 */
} bi_dram[CONFIG_NR_DRAM_BANKS];
} bd_t;
#endif
/* 初始化波特率 */
static int init_baudrate (void)
char tmp[64]; /* long enough for environment variables */
int i = getenv_r ("baudrate", tmp, sizeof (tmp));
gd->bd->bi_baudrate = gd->baudrate = (i > 0)
? (int) simple_strtoul (tmp, NULL, 10)
: CONFIG_BAUDRATE;
return (0);
/* 打开屏幕背光 */
static void open_backlight(void)
unsigned int reg;
//open backlight. GPF3_5=1
reg = readl(GPF3CON);
reg = reg & ~(0xf<<20) | (0x1<<20);
writel(reg,GPF3CON);
reg = readl(GPF3PUD);
reg = reg & ~(0x3<<10) | (0x2<<10);
writel(reg,GPF3PUD);
reg = readl(GPF3DAT);
reg |= (0x1<<5);
writel(reg,GPF3DAT);
* GPC1_1: GPRS_PWR_EN
* GPJ0_4: CDMAPWR
* GPJ0_1: GSM_RST
* GPJ0_6: GSM_ON_OFF
/* 打开GPRS */
static void open_gprs(void)
unsigned int i;
unsigned int reg;
//step0: init gpio
reg = readl(GPC1CON);
reg = reg & ~(0xf<<4) | (0x1<<4); //set GPC1_1 to output and enable pullup
writel(reg,GPC1CON);
reg = readl(GPC1PUD);
reg = reg & ~(0x3<<2) | (0x2<<2);
writel(reg,GPC1PUD);
reg = readl(GPJ0CON);
reg = reg & ~(0xf<<4) | (0x1<<4); //set GPJ0_1 to output and enable pullup
writel(reg,GPJ0CON);
reg = readl(GPJ0PUD);
writel(reg,GPJ0PUD);
reg = reg & ~(0xf<<16) | (0x1<<16); //set GPJ0_4 to output and enable pullup
reg = reg & ~(0x3<<8) | (0x2<<8);
reg = reg & ~(0xf<<24) | (0x1<<24); //set GPJ0_6 to low level and enable pullup
reg = reg & ~(0x3<<12) | (0x2<<12);
reg = readl(GPJ0DAT);
reg &= ~(0x1<<6);
writel(reg,GPJ0DAT);
//step1: disable reset
reg &= ~(0x1<<1);
//step2: enable GPRS power(4.2V to GPRS module)
reg = readl(GPC1DAT);
reg |= (0x1<<1);
writel(reg,GPC1DAT);
//step3: enable CDMAPWR(4.2V to GC864)
reg |= (0x1<<4);
for(i=0;i<100;i++)
udelay(1000);
//step4: power on GC864
reg |= (0x1<<6);
for(i=0;i<1000/*2000*/;i++)
udelay(1000);
reg &= ~(0x1<<6);
/* 一些显示函数。显示IRQ_STACK_START等的地址_armboot_start, _bss_start, _bss_end 这些值 */
static int display_banner (void)
printf("**********************************************************n");
printf ("************* %s *************n", vers
