* (C) Copyright 2000-2003
* Wolfgang Denk, DENX Software Engineering, wd@denx.de.
* See file CREDITS for list of people who contributed to this
* project.
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License as
* published by the Free Software Foundation; either version 2 of
* the License, or (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 59 Temple Place, Suite 330, Boston,
* MA 02111-1307 USA
* Misc boot support
#include
#include
#include
/* Allow ports to override the default behavior */
__attribute__((weak))
unsigned long do_go_exec (ulong (*entry)(int, char *[]), int argc, char *argv[])
return entry (argc, argv);
int do_go (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[])
ulong addr, rc;
int rcode = 0;
if (argc < 2) {
cmd_usage(cmdtp);
return 1;
/************* farsight **************/
char *commandline = getenv("bootargs");
// 获取内核参数数据结构地址
struct param_struct *lht_params=(struct param_struct *)0x20000100;
printf("setup linux parameters at 0x20000100n");
memset(lht_params,0,sizeof(struct param_struct));
// 传递物理内存页大小
lht_params->u1.s.page_size=4096;
// 传递物理内存页数
lht_params->u1.s.nr_pages=0x10000000>>12;
// 传递内核参数
memcpy(lht_params->commandline,commandline,strlen(commandline)+1);
printf("linux command line is: "%s"n",commandline);
// 获取内核启动地址argv[1]="20008000"
addr = simple_strtoul(argv[1], NULL, 16);
printf ("## Starting application at 0x%08lX ...n", addr);
/************** farsight *************/
__asm__(
"ldr r1, =1826n" // 传递machine type id(arch number)
// 关闭TLB/icache
"mov ip, #0n"
"mcr p15, 0, ip, c8, c7, 0n"
"mcr p15, 0, ip, c7, c5, 0n"
"mcr p15, 0, ip, c7, c5, 6n"
"mcr p15, 0, ip, c7, c10, 4n"
"mcr p15, 0, ip, c7, c5, 4n"
// 关闭mmu
"mrc p15, 0, ip, c1, c0, 0n"
"bic ip, ip, #0x00002000n"
"bic ip, ip, #0x00000007n"
"orr ip, ip, #0x00000002n"
"orr ip, ip, #0x00000800n"
"bic ip, ip, #0x00001000n"
"mcr p15, 0, ip, c1, c0, 0n"
// 跳转到内核
"mov pc, %[zImage]n"
// 清空流水线
"nopn"
:[zImage]"r"(addr)
:"r1"
/**************** farsight ************/
* pass address parameter as argv[0] (aka command name),
* and all remaining args
rc = do_go_exec ((void *)addr, argc - 1, argv + 1);
if (rc != 0) rcode = 1;
printf ("## Application terminated, rc = 0x%lXn", rc);
return rcode;
U_BOOT_CMD(
go, CONFIG_SYS_MAXARGS, 1, do_go,
"start application at address 'addr'",
"addr [arg ...]n - start application at address 'addr'n"
" passing 'arg' as arguments"
extern int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]);
U_BOOT_CMD(
reset, 1, 0, do_reset,
"Perform RESET of the CPU",
