内核版本:linux-2.6.32.2
实验平台:mini2440
1. 添加平台设备支持
首先需要在mach-mini2440.c中包含头文件
/* DM9000AEP 10/100 ethernet controller */
#define MACH_MINI2440_DM9000_BASE (S3C2410_CS4 + 0x300)
static struct resource mini2440_dm9000_resource[] = {
[0] = {
.start = MACH_MINI2440_DM9000_BASE,
.end = MACH_MINI2440_DM9000_BASE + 3,
.flags = IORESOURCE_MEM,
[1] = {
.start = MACH_MINI2440_DM9000_BASE + 4,
.end = MACH_MINI2440_DM9000_BASE + 7,
[2] = {
.start = IRQ_EINT7,
.end = IRQ_EINT7,
.flags = IORESOURCE_IRQ | IORESOURCE_IRQ_HIGHEDGE,
* The DM9000 has no eeprom, and it's MAC address is set by
* the bootloader before starting the kernel.
static struct dm9000_plat_data mini2440_dm9000_platdata = {
.flags = (DM9000_PLATF_16BITONLY | DM9000_PLATF_NO_EEPROM),
static struct platform_device mini2440_device_eth = {
.name = "dm9000",
.id = -1,
.num_resources = ARRAY_SIZE(mini2440_dm9000_resource),
.resource = mini2440_dm9000_resource,
.dev = {
.platform_data = &mini2440_dm9000_platdata,
38
最后需要将dm9000这个平台设备添加到mini2440_devices这个平台设备数组里面,这样才能完成平台设备的注册。
static struct platform_device *mini2440_devices[] __initdata = {
&mini2440_device_eth,
2. dm9000驱动修改
drivers/net/dm9000.c这个驱动并不是为mini2440做准备的,需要做一些修改。
包含相关头文件:
#if defined(CONFIG_ARCH_S3C2410)
#include
#endif
修改dm9000片选总线时序:
static int __init
dm9000_init(void)
unsigned int oldval_bwscon = *(volatile unsigned int *)S3C2410_BWSCON;
unsigned int oldval_bankcon4 = *(volatile unsigned int *)S3C2410_BANKCON4;
*((volatile unsigned int *)S3C2410_BWSCON) =
(oldval_bwscon & ~(3<<16)) | S3C2410_BWSCON_DW4_16 | S3C2410_BWSCON_WS4 | S3C2410_BWSCON_ST4;
*((volatile unsigned int *)S3C2410_BANKCON4) = 0x1f7c;
#endif
在dm9000_probe函数中还需要给dm9000设置一个mac地址。
static int __devinit
dm9000_probe(struct platform_device *pdev)
memcpy(ndev->dev_addr, "x08x90x90x90x90x90", 6);
if (!is_valid_ether_addr(ndev->dev_addr))
dev_warn(db->dev, "%s: Invalid ethernet MAC address. Please "
"set using ifconfign", ndev->name);
3. 配置内核
Device Drivers --->
[*] Network device support --->
[*] Ethernet (10 or 100Mbit) --->
DM9000 support
(4) DM9000 maximum debug level
4. 编译下载,启动开发板
5. 启动网络设备
内核配置好之后,需要手动启动网络设备,使用如下命令:
ifconfig eth0 172.20.11.41 netmask 255.255.255.0 up
如下图所示:
或者将上面的命令写入到启动脚本中,还可以使用ifconfig命令来停止网络设备:
ifconfig eth0 down
