* 文件名:timer.h
#ifndef _TIMER_H
#define _TIMER_H
#define SYS_MCLK 11059200 //系统主时钟
#define FOSC 11059200 //晶振频率
#define USING_T0
#define USING_STC15_T2
#ifdef USING_T0
extern uint8_t tmr0LowByte, tmr0HighByte;
void tmr0_init(uint8_t ms);
#endif
#ifdef USING_T1
extern uint8_t tmr1LowByte, tmr1HighByte;
void tmr1_init(uint8_t ms);
#endif
#ifdef USING_T2
void tmr2_init(uint8_t ms);
#endif
#ifdef USING_STC15_T2
void stc15_tmr2_init(uint8_t ms);
#endif
#endif
* 文件名:timer.c
#include
#include "stdint.h"
#include "timer.h"
* 定时器0
#ifdef USING_T0
void tmr0_init(uint8_t ms) { //!!8bits
uint32_t tmp; //小心溢出
tmp = ms * SYS_MCLK / 12 / 1000;
tmp = 65536 - tmp;
tmr0LowByte = (uint8_t)tmp;
tmr0HighByte = (uint8_t)(tmp >> 8);
AUXR &= 0x7F; //定时器时钟12T模式
TMOD &= 0xF0;
TMOD |= 0x01;
TL0 = tmr0LowByte;
TH0 = tmr0HighByte;
EA = 1;
ET0 = 1;
TR0 = 1;
#endif
#ifdef USING_T1
void tmr1_init(uint8_t ms) { //!!8bits
uint32_t tmp;
tmp = 65536 - tmp;
tmr1LowByte = (uint8_t)tmp;
tmr1HighByte = (uint8_t)(tmp >> 8);
AUXR &= 0xBF;
TMOD &= 0x0F;
TMOD |= 0x10;
TL1 = tmr1LowByte;
TH1 = tmr1HighByte;
EA = 1;
ET1 = 1;
TR1 = 1;
#endif
#ifdef USING_T2
* 89系列单片机定时器2初始化
* 定时器模式:16位自动重载
* 定时器时钟:12T(FOSC/12)
void tmr2_init(uint8_t ms) {
tmp = 65536 - tmp;
T2MOD = 0x00; //初始化模式寄存器
T2CON = 0x00; //初始化控制寄存器
TL2 = (uint8_t)tmp; //设置定时器初值
TH2 = (uint8_t)(tmp >> 8);
RCAP2L = TL2; //设置定时器重载值
RCAP2H = TH2;
EA = 1; //!!!
ET2 = 1; //!!!
TR2 = 1;
#endif
* stc15系列单片机定时器2初始化
* 定时器模式:16位自动重载
void stc15_tmr2_init(uint8_t ms) {
tmp = 65536 - tmp;
AUXR &= 0xFB; //定时器时钟12T模式
T2L = (uint8_t)tmp; //设置定时器初值
T2H = (uint8_t)(tmp >> 8);
EA = 1; //!!!
IE2 |= 0x04; //!!!开定时器2中断
AUXR |= 0x10; //定时器2开始计时
#endif
