/* 选择BANK1-BORSRAM1 连接 TFT,地址范围为0X60000000~0X63FFFFFF
* FSMC_A16 接LCD的DC(寄存器/数据选择)脚
* 16 bit => FSMC[24:0]对应HADDR[25:1]
* 寄存器基地址 = 0X60000000
* RAM基地址 = 0X60020000 = 0X60000000+2^16*2 = 0X60000000 + 0X20000 = 0X60020000
* 当选择不同的地址线时,地址要重新计算。
//#define Bank1_LCD_D ((u32)0x60020000) //Disp Data ADDR
//#define Bank1_LCD_C ((u32)0x60000000) //Disp Reg ADDR
/*选定LCD指定寄存器*/
//#define LCD_WR_REG(index) ((*(__IO u16 *) (Bank1_LCD_C)) = ((u16)index))
/*将LCD中的index寄存器设置为val值*/
//#define LCD_WR_CMD(index,val) do{(*(__IO u16 *) (Bank1_LCD_C)) = ((u16)index); (*(__IO u16 *) (Bank1_LCD_D)) = ((u16)(val));}while(0)
/*往LCD GRAM写入数据*/
//#define LCD_WR_Data(val) ((*(__IO u16 *) (Bank1_LCD_D)) = ((u16)(val)))
void ILI9341_LCD_Init(void);
/**********FSMC**********/
* 函数名:LCD_GPIO_Config
* 描述 :根据FSMC配置LCD的I/O
* 输入 : 无
* 输出 :无
* 举例 :无
* 注意 :无
void LCD_GPIO_Config(void)
/* 使能FSMC时钟*/
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC, ENABLE);
/* 使能FSMC对应相应管脚时钟*/
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE , ENABLE);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
/* 配置LCD背光控制管脚*/
//GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
//GPIO_Init(GPIOD, &GPIO_InitStructure);
/* 配置LCD复位控制管脚*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 ;
/* 配置FSMC相对应的数据线,FSMC-D0~D15: PD 14 15 0 1,PE 7 8 9 10 11 12 13 14 15,PD 8 9 10*/
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_8 | GPIO_Pin_9 |
GPIO_Pin_10 | GPIO_Pin_14 | GPIO_Pin_15;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 |
GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 |
GPIO_Pin_15;
GPIO_Init(GPIOE, &GPIO_InitStructure);
/* 配置FSMC相对应的控制线
* PD4-FSMC_NOE :LCD-RD
* PD5-FSMC_NWE :LCD-WR
* PD7-FSMC_NE1 :LCD-CS
* PD11-FSMC_A16 :LCD-DC
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 ;
/* tft control gpio init */
//GPIO_SetBits(GPIOD, GPIO_Pin_13); // 背光打开
//GPIO_ResetBits(GPIOE, GPIO_Pin_1); // RST = 1
//GPIO_SetBits(GPIOD, GPIO_Pin_4); // RD = 1
// GPIO_SetBits(GPIOD, GPIO_Pin_5); // WR = 1
// GPIO_SetBits(GPIOD, GPIO_Pin_7); // CS = 1
GPIO_SetBits(GPIOD, GPIO_Pin_3); // RST = 1
// GPIO_SetBits(GPIOD, GPIO_Pin_6);
* 函数名:LCD_FSMC_Config
* 描述 :LCD FSMC 模式配置
* 输入 : 无
* 输出 :无
* 举例 :无
* 注意 :无
void LCD_FSMC_Config(void)
FSMC_NORSRAMInitTypeDef FSMC_NORSRAMInitStructure;
FSMC_NORSRAMTimingInitTypeDef p;
p.FSMC_AddressSetupTime = 0x02; //地址建立时间
p.FSMC_AddressHoldTime = 0x00; //地址保持时间
p.FSMC_DataSetupTime = 0x05; //数据建立时间
p.FSMC_BusTurnAroundDuration = 0x00;
p.FSMC_CLKDivision = 0x00;
p.FSMC_DataLatency = 0x00;
p.FSMC_AccessMode = FSMC_AccessMode_B; // 一般使用模式B来控制LCD
FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM1;
FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_NOR;
FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;
FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;
FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p;
FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;
FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
/* 使能 FSMC Bank1_SRAM Bank */
FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE);
* 函数名:LCD_Rst
* 描述 :LCD 软件复位
* 输入 : 无
* 输出 :无
* 举例 :无
* 注意 :无
void LCD_Rst(void)
GPIO_ResetBits(GPIOD, GPIO_Pin_3);
SysTickDelay(100);
SysTickDelay(100);
void Lcd_data_start(void)
LCD_WR_REG(0X2C);
* 函数名:Lcd_init_conf
* 描述 :LCD寄存器初始配置
* 输入 : 无
* 输出 :无
* 举例 :无
* 注意 :无
void Lcd_init_conf(void)
LCD_WR_REG(0xCF);
LCD_WR_Data(0x00);
LCD_WR_Data(0x81);
LCD_WR_Data(0x30);
LCD_WR_REG(0xED);
LCD_WR_Data(0x64);
LCD_WR_Data(0x03);
LCD_WR_Data(0x12);
LCD_WR_Data(0x81);
LCD_WR_REG(0xE8);
LCD_WR_Data(0x85);
LCD_WR_Data(0x10);
LCD_WR_Data(0x78);
LCD_WR_REG(0xCB);
LCD_WR_Data(0x39);
LCD_WR_Data(0x2C);
LCD_WR_Data(0x00);
LCD_WR_Data(0x34);
LCD_WR_Data(0x02);
LCD_WR_REG(0xF7);
LCD_WR_Data(0x20);
LCD_WR_REG(0xEA);
LCD_WR_Data(0x00);
LCD_WR_Data(0x00);
LCD_WR_REG(0xB1);
LCD_WR_Data(0x00);
LCD_WR_Data(0x1B);
LCD_WR_REG(0xB6);
LCD_WR_Data(0x0A);
LCD_WR_Data(0xA2);
LCD_WR_REG(0xC0);
LCD_WR_Data(0x35);
LCD_WR_REG(0xC1);
LCD_WR_Data(0x11);
LCD_WR_REG(0xC5);
LCD_WR_Data(0x45);
LCD_WR_Data(0x45);
LCD_WR_REG(0xC7);
LCD_WR_Data(0xA2);
LCD_WR_REG(0xF2);
LCD_WR_Data(0x00);
LCD_WR_REG(0x26);
LCD_WR_Data(0x01);
LCD_WR_REG(0xE0); //Set Gamma
LCD_WR_Data(0x0F);
LCD_WR_Data(0x26);
LCD_WR_Data(0x24);
LCD_WR_Data(0x0B);
LCD_WR_Data(0x0E);
LCD_WR_Data(0x09);
LCD_WR_Data(0x54);
LCD_WR_Data(0xA8);
LCD_WR_Data(0x46);
LCD_WR_Data(0x0C);
LCD_WR_Data(0x17);
LCD_WR_Data(0x09);
LCD_WR_Data(0x0F);
LCD_WR_Data(0x07);
LCD_WR_Data(0x00);
LCD_WR_REG(0XE1); //Set Gamma
LCD_WR_Data(0x00);
LCD_WR_Data(0x19);
LCD_WR_Data(0x1B);
LCD_WR_Data(0x04);
LCD_WR_Data(0x10);
LCD_WR_Data(0x07);
LCD_WR_Data(0x2A);
LCD_WR_Data(0x47);
LCD_WR_Data(0x39);
LCD_WR_Data(0x03);
LCD_WR_Data(0x06);
LCD_WR_Data(0x06);
LCD_WR_Data(0x30);
LCD_WR_Data(0x38);
LCD_WR_Data(0x0F);
LCD_WR_REG(0x36);
LCD_WR_Data(0x08);
LCD_WR_REG(0X2A);
LCD_WR_Data(0x00);
LCD_WR_Data(0x00);
LCD_WR_Data(0x00);
LCD_WR_Data(0xEF);
LCD_WR_REG(0X2B);
LCD_WR_Data(0x00);
LCD_WR_Data(0x00);
LCD_WR_Data(0x01);
LCD_WR_Data(0x3F);
LCD_WR_REG(0x3a); // Memory Access Control
LCD_WR_Data(0x55);
LCD_WR_REG(0x11); //Exit Sleep
SysTickDelay(120);
LCD_WR_REG(0x29); //display on
LCD_WR_REG(0x2c);
* 函数名:LCD_Init
* 描述 :LCD 控制 I/O 初始化
* LCD FSMC 初始化
* LCD 控制器 HX8347 初始化
* 输入 : 无
* 输出 :无
* 举例 :无
* 注意 :无
void TFT_Draw_Point(u16 x,u8 y,u16 color)
LCD_WR_REG(0X2A);
LCD_WR_Data(x>>8);
LCD_WR_Data(x&0xFF);
LCD_WR_REG(0X2B);
LCD_WR_Data(0x00);
LCD_WR_Data(y);
LCD_WR_REG(0x2C);//开始写
LCD_WR_Data(color);
unsigned long i;
LCD_GPIO_Config();
LCD_FSMC_Config();
LCD_Rst();
Lcd_init_conf();
Lcd_data_start();
for(i=0; i {
LCD_WR_Data(0xF800);
TFT_Draw_Point(319,120,0x07E0);
