以下是主要代码:
1.led.c
#define GPBCON (volatile unsigned long*)0x56000010
#define GPBDAT (volatile unsigned long*)0x56000014
void led_init()
*(GPBCON) = 0x400;
void led_off()
*(GPBDAT) = 0x7ff;
void led_on()
*(GPBDAT) = 0x0;
2.interrupt.c
/*interrupt registes*/
#define SRCPND (volatile unsigned long *)0x4A000000
#define INTMOD (volatile unsigned long *)0x4A000004
#define INTMSK (volatile unsigned long *)0x4A000008
#define PRIORITY (volatile unsigned long *)0x4A00000c
#define INTPND (volatile unsigned long *)0x4A000010
#define INTOFFSET (volatile unsigned long *)0x4A000014
#define SUBSRCPND (volatile unsigned long *)0x4A000018
#define INTSUBMSK (volatile unsigned long *)0x4A00001c
#define EINTMASK (volatile unsigned long *)0x560000a4
#define EINTPEND (volatile unsigned long *)0x560000a8
void init_irq()
// 在EINTMASK寄存器中使能它们
*(EINTMASK) &= (~(1<<8)) & (~(1<<11)) & (~(1<<13)) & (~(1<<14));
// EINT8_23使能
*(INTMSK) &= ~(1<<5);
__asm__(
/*开中断*/
"mrs r0,cpsrn"
"bic r0, r0, #0x80n"
"msr cpsr_c, r0n"
void handle_int()
/*读取产生中断的源*/
unsigned long value = *(EINTPEND) & ((1<<8)|(1<<11)|(1<<13)|(1<<14));
switch(value)
case (1<<8): //K1
led_on();
break;
case (1<<11): //K2
led_off();
break;
case (1<<13): //K3
led_on();
break;
case (1<<14): //K4
led_off();
break;
default:
break;
/* 中断清除 相应的位 1 */
*(EINTPEND) = value;
*(SRCPND) = 1 << 5;
*(INTPND) = 1 << 5;
3.button.c
#define GPGCON (volatile unsigned long *)0x56000060
* K1,K2,K3,K4对应GPG0、GPG3、GPG5、GPG6
#define GPG0_int (0x2<#define GPG3_int (0x2<#define GPG5_int (0x2<#define GPG6_int (0x2<
#define GPG0_msk (3<#define GPG3_msk (3<#define GPG5_msk (3<#define GPG6_msk (3<
void button_init()
*(GPGCON) &= ~(GPG0_msk | GPG3_msk | GPG5_msk | GPG6_msk);
*(GPGCON) |= GPG0_int | GPG3_int | GPG5_int | GPG6_int;
@以上代码仅供参考。
/******************************** Stay hungry, Stay foolish. @Rocky ********************************/
关键字:初始化 中断按键 2440『本文转载自网络,版权归原作者所有,如有侵权请联系删除』
