原理图:
程序清单:
/****************************************Copyright (c)**************************************************
**--------------File Info-------------------------------------------------------------------------------
** File name: main.c
** Last modified Date: 2011-04-27
** Last Version: 1.0
** Descriptions: The main() function example template
** Created by: lxliu
** Created date: 2011-04-27
** Version: 1.0
** Descriptions: The original version
** Modified by:
** Modified date:
** Version:
** Descriptions:
#include "config.h"
void DelayNS(uint32 dly)
uint32 i;
for(;dly>0;dly--)
for(i=0;i<50000;i++);
int main (void)
uint32 i; //循环变量
uint32 LED = (1<<18); //P1[25:18]控制LED,初值指向LED1
uint32 BEEP = (1<<7); //P0.7控制蜂鸣器,低电平蜂鸣器蜂鸣
PINSEL2 = PINSEL2 & (~0x08); //P1[25:16]设置为GPIO功能
PINSEL0 = 0x00000000; //P0[15:0]设置为GPIO功能
IO0DIR = BEEP; //设置BEEP控制口为输出
IO0SET = BEEP; //蜂鸣器停止蜂鸣
while(1)
for(i=0;i<8;i++) //8个LED
IO1DIR = LED; //当前的LED设置为输出
IO1SET = LED; //当前的LED熄灭
DelayNS(100); //延时
IO1CLR = LED; //当前的LED点亮
DelayNS(100); //延时
LED =(LED<<1); //左移一位,
IO0CLR = BEEP; //8个LED点亮一遍后,蜂鸣器蜂鸣
DelayNS(100); //延时
DelayNS(500); //延时
LED = (1<<18); //为LED赋初值
return 0;
** End Of File
