#include
#define uchar unsigned char
#define uint unsigned int
#define add 0xaa
__CONFIG(0x3B31);
const uchar ee_data[]={1,2,3,4,5,6};
uchar read_data[6];
const uchar table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delay(uint x);
void init();
void didi(uchar num);
void disp(uchar num1,uchar num2,uchar num3,uchar num4,uchar num5,uchar num6);
void write();
void read();
void main()
init();
write();
delay(100);
read();
while(1)
disp(read_data[0],read_data[1],read_data[2],read_data[3],read_data[4],read_data[5]);
void delay(uint x)
uint a,b;
for(a=x;a》0;a--)
for(b=110;b》0;b--);
void init()
TRISD=0;
TRISA=0;
TRISE0=0;
//ADCON1=0x07;
RE0=0;
PORTD=0;
PORTA=0;
TRISC=0xff;
SSPSTAT=0x80;
SSPCON=0x38;
SSPCON2=0;
SSPADD=0x09;
void write()
uchar i;
SSPIF=0;
SEN=1;
while(!SSPIF);
SSPIF=0;
SSPBUF=0xA0;
while(!SSPIF);
SSPIF=0;
SSPBUF=add;
while(!SSPIF);
SSPIF=0;
for(i=0;i《6;i++)
SSPBUF=ee_data[i];
while(!SSPIF);
SSPIF=0;
PEN=1;
while(!SSPIF);
SSPIF=0;
void read()
uchar i;
SSPIF=0;
SEN=1;
while(!SSPIF);
SSPIF=0;
SSPBUF=0xA0;
while(!SSPIF);
SSPIF=0;
SSPBUF=add;
while(!SSPIF);
SSPIF=0;
SSPIF=0;
RSEN=1;
while(!SSPIF);
SSPIF=0;
SSPBUF=0xA1;
while(!SSPIF);
SSPIF=0;
for(i=0;i《6;i++)
RCEN=1;
while(!SSPIF);
read_data[i]=SSPBUF;
while(!SSPIF);
SSPIF=0;
if(i》=5)
ACKDT=1;
else
ACKDT=0;
ACKEN=1;
while(!SSPIF);
SSPIF=0;
PEN=1;
while(!SSPIF);
SSPIF=0;
uchar di_num;
for(di_num=num;di_num》0;di_num--)
RE0=1;
delay(50);
RE0=0;
delay(20);
本文引用地址: http://www.21ic.com/app/mcu/201812/786472.htm
PORTD=table[num1];//显示第一个数码管
PORTA=0x20;//0010 0000
delay(2);
PORTD=table[num2];//显示第二个数码管
PORTA=0x10;//0001 0000
delay(2);
PORTD=table[num3];//显示第三个数码管
PORTA=0x08;//0000 1000
delay(2);
PORTD=table[num4];//显示第四个数码管
PORTA=0x04;//0000 0100
delay(2);
PORTD=table[num5];//显示第五个数码管
PORTA=0x02;//0000 0010
delay(2);
PORTD=table[num6];//显示第六个数码管
PORTA=0x01;//0000 0001
delay(2);
关键字:PIC单片机 IIC通信『本文转载自网络,版权归原作者所有,如有侵权请联系删除』
