代码如下:
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %drn", file, line) */
/* Infinite loop */
while(1)
#endif
调试用的。在stm32f10x_conf.h文件中,有如下宏定义
* @brief The assert_param macro is used for function's parameters check.
* @param expr: If expr is false, it calls assert_failed function which reports
* the name of the source file and the source line number of the call
* that failed. If expr is true, it returns no value.
* @retval None
#define assert_param(expr) ((expr) ? (void)0: assert_failed((uint8_t *)__FILE__, __LINE__))
/* Exported functions ------------------------------------------------------- */
void assert_failed(uint8_t* file, uint32_t line);
#else
#define assert_param(expr) ((void)0)
#endif /* USE_FULL_ASSERT */
如果你定义了USE_FULL_ASSERT
就可以在assert_failed,加入:
printf("Wrong parameters value: file %s on line %drn", file, line);
就可以使用assert_param(expr) 来判断当前参数是够正确,如果不正确,就会打印出错的文件,以及出错的行。
这样就可以方面调试信息了。
关键字:stm32 main函数 参数『本文转载自网络,版权归原作者所有,如有侵权请联系删除』
