#define uchar unsigned char
#define uint unsigned int //宏定义
#define ulint unsigned long int //宏定义
void delay(uint time);
void Timer_init();
void Timer0(unsigned long int us);
uint pwm_valu=500;
sbit dj=P1^0;
void main()
Timer_init(); //定时器初始化
Timer0(31); //通过一个定时值进入定时循环
while(1)
pwm_valu=550; //
delay(2000);
pwm_valu=2500; //
delay(2000); //
pwm_valu=1000; //
delay(2000); //
pwm_valu=2000; //
delay(2000); //
pwm_valu=1500; //
delay(2000);
//软件延时
uint i,j;
for(i=0;i<1000;i++)
for(j=0;j
//定时器0初始化
void Timer_init()
P1M1=0;
P1M0=0XFF;
EA=1; //开总中断
AUXR|=0xC0; //T0,T1工作在1T
TMOD|= 0x11; //T0工作在方式1,16位
ET0 = 1; //开定时器0中断
//定时器0定时函数
void Timer0(unsigned long int us) //定时器定时函数
unsigned long int valu;
valu=us*12; //工作在1T
valu=valu;
valu=0xffff-valu; //
TH0=valu>>8;
TL0=(valu<<8)>>8;
TR0 = 1;//T0开始工作
t0 中断 中断
void T0zd() interrupt 1
static uchar num=1;
switch(num) //
case 1:
dj=1;
Timer0(pwm_valu);//
} break;
case 2:
dj=0;// pwm1变低
Timer0(2500-pwm_valu);//
} break;
case 3:
Timer0(2500);//
} break;
case 4:
Timer0(2500);//
} break;
case 5:
Timer0(2500);//
} break;
case 6:
Timer0(2500);//
} break;
case 7:
Timer0(2500);//
} break;
case 8:
Timer0(2500);//
} break;
case 9:
Timer0(2500);//
num=0;
} break;
default:break;
num++;
