//常用操作宏定义
#define set_E1() (E1=1) //1片选M
#define set_E2() (E2=1) //1片选S
#define set_A0() (A0=1) //1数据
#define set_WR() (_WR=1) //1读
#define clr_E1() (E1=0) //0
#define clr_E2() (E2=0) //0
#define clr_A0() (A0=0) //0命令
#define clr_WR() (_WR=0) //0写
//液晶显示控制命令表
#define disp_off 0xAE //显示关闭
#define disp_on 0xAF //显示打开
#define disp_start_line 0xC0 //显示起始地址(后5位-表示0-31行)
#define page_addr_set 0xB8 //页地址设置(0~3)
#define col_addr_set 0x00 //列地址设置(0~61)
#define status_busy 0x80 //0=ready
#define mode_write 0xEE //写模式
#define dynamic_driver 0xA4 //动态驱动
#define adc_select 0xA0 //clockwise
#define clk32 0xA9 //刷新时钟设置1/32
#define clk16 0xA8 //刷新时钟设置1/16
#define reset 0xE2 //软件复位
////新的驱动着重在简化代码,这样外部可调用的函数为:系统初始化,清屏,判忙标志////
////ASCII和汉字混合输出函数,RAM buffer数据显示输出(一般用于输出数字)//////////
#include
#include
#define uchar unsigned char
#define uint unsigned int
#define NOP() _nop_();
uchar dot_buffer[32]; //点阵缓存区
uchar disp_buffer[4]; //ram数据显示缓存区
void lcd_init(void); //LCD初始化
void lcd_clr(void); //LCD清屏
void wait_ready(void); //等待ready
void draw_bmp(uchar col,uchar layer,uchar width,uchar *bmp);
//点阵码显示输出
void disp_one_ascii(uchar col,uchar layer,uchar ascii_code,uchar mode);
//单个ascci码输出(ascii_code为ascii编码)
void disp_ram_data(uchar col,uchar layer,uchar n,uchar mode);
//ram数据(数字)显示输出
void dprintf(uchar col,uchar layer,uchar *buf,uchar mode);
//通用混合字串显示
typedef struct data_gb16 //汉字字模数据结构
uchar index[2];
uchar zimo[32];
struct data_gb16 code hz16[] =
"延", 0x00,0x84,0xC4,0xA4,0x94,0x8C,0x00,0xE4,
0x04,0x04,0xFC,0x42,0x63,0x42,0x00,0x00,
0x80,0x44,0x28,0x10,0x2C,0x43,0x40,0x4F,
0x48,0x48,0x4F,0x48,0x4C,0x68,0x20,0x00,
"时", 0x00,0xFC,0x84,0x84,0x84,0xFE,0x14,0x10,
0x90,0x10,0x10,0x10,0xFF,0x10,0x10,0x00,
0x00,0x3F,0x10,0x10,0x10,0x3F,0x00,0x00,
0x00,0x23,0x40,0x80,0x7F,0x00,0x00,0x00
uchar code ascii[] = {
//前面0x20(32个)ASCII码为控制命令 //本程序中不用
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//
0x00,0x00,0x38,0xFC,0xFC,0x38,0x00,0x00,//!
0x00,0x00,0x00,0x0D,0x0D,0x00,0x00,0x00,
0x00,0x0E,0x1E,0x00,0x00,0x1E,0x0E,0x00,//"
0x20,0xF8,0xF8,0x20,0xF8,0xF8,0x20,0x00,//#
0x02,0x0F,0x0F,0x02,0x0F,0x0F,0x02,0x00,
0x38,0x7C,0x44,0x47,0x47,0xCC,0x98,0x00,//$
0x03,0x06,0x04,0x1C,0x1C,0x07,0x03,0x00,
0x30,0x30,0x00,0x80,0xC0,0x60,0x30,0x00,//%
0x0C,0x06,0x03,0x01,0x00,0x0C,0x0C,0x00,
0x80,0xD8,0x7C,0xE4,0xBC,0xD8,0x40,0x00,//&
0x07,0x0F,0x08,0x08,0x07,0x0F,0x08,0x00,
0x00,0x10,0x1E,0x0E,0x00,0x00,0x00,0x00,//'
0x00,0x00,0xF0,0xF8,0x0C,0x04,0x00,0x00,//(
0x00,0x00,0x03,0x07,0x0C,0x08,0x00,0x00,
0x00,0x00,0x04,0x0C,0xF8,0xF0,0x00,0x00,//)
0x00,0x00,0x08,0x0C,0x07,0x03,0x00,0x00,
0x80,0xA0,0xE0,0xC0,0xC0,0xE0,0xA0,0x80,//*
0x00,0x02,0x03,0x01,0x01,0x03,0x02,0x00,
0x00,0x80,0x80,0xE0,0xE0,0x80,0x80,0x00,//+
0x00,0x00,0x00,0x03,0x03,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//,
0x00,0x00,0x10,0x1E,0x0E,0x00,0x00,0x00,
0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x00,//-
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//.
0x00,0x00,0x00,0x0C,0x0C,0x00,0x00,0x00,
0x00,0x00,0x00,0x80,0xC0,0x60,0x30,0x00,///
0x0C,0x06,0x03,0x01,0x00,0x00,0x00,0x00,
0xF8,0xFC,0x04,0xC4,0x24,0xFC,0xF8,0x00,//0
0x07,0x0F,0x09,0x08,0x08,0x0F,0x07,0x00,
0x00,0x10,0x18,0xFC,0xFC,0x00,0x00,0x00,//1
0x00,0x08,0x08,0x0F,0x0F,0x08,0x08,0x00,
0x08,0x0C,0x84,0xC4,0x64,0x3C,0x18,0x00,//2
0x0E,0x0F,0x09,0x08,0x08,0x0C,0x0C,0x00,
0x08,0x0C,0x44,0x44,0x44,0xFC,0xB8,0x00,//3
0x04,0x0C,0x08,0x08,0x08,0x0F,0x07,0x00,
0xC0,0xE0,0xB0,0x98,0xFC,0xFC,0x80,0x00,//4
0x00,0x00,0x00,0x08,0x0F,0x0F,0x08,0x00,
0x7C,0x7C,0x44,0x44,0xC4,0xC4,0x84,0x00,//5
0xF0,0xF8,0x4C,0x44,0x44,0xC0,0x80,0x00,//6
0x07,0x0F,0x08,0x08,0x08,0x0F,0x07,0x00,
0x0C,0x0C,0x04,0x84,0xC4,0x7C,0x3C,0x00,//7
0x00,0x00,0x0F,0x0F,0x00,0x00,0x00,0x00,
0xB8,0xFC,0x44,0x44,0x44,0xFC,0xB8,0x00,//8
0x38,0x7C,0x44,0x44,0x44,0xFC,0xF8,0x00,//9
0x00,0x08,0x08,0x08,0x0C,0x07,0x03,0x00,
0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,//:
0x00,0x00,0x00,0x06,0x06,0x00,0x00,0x00,
0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,//;
0x00,0x00,0x08,0x0E,0x06,0x00,0x00,0x00,
0x00,0x80,0xC0,0x60,0x30,0x18,0x08,0x00,//<
0x00,0x00,0x01,0x03,0x06,0x0C,0x08,0x00,
0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x00,//=
0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x00,
0x00,0x08,0x18,0x30,0x60,0xC0,0x80,0x00,//>
0x00,0x08,0x0C,0x06,0x03,0x01,0x00,0x00,
0x18,0x1C,0x04,0xC4,0xE4,0x3C,0x18,0x00,//?
0xF0,0xF8,0x08,0xC8,0xC8,0xF8,0xF0,0x00,//@
0x07,0x0F,0x08,0x0B,0x0B,0x0B,0x01,0x00,
0xE0,0xF0,0x98,0x8C,0x98,0xF0,0xE0,0x00,//A
0x0F,0x0F,0x00,0x00,0x00,0x0F,0x0F,0x00,
0x04,0xFC,0xFC,0x44,0x44,0xFC,0xB8,0x00,//B
0x08,0x0F,0x0F,0x08,0x08,0x0F,0x07,0x00,
0xF0,0xF8,0x0C,0x04,0x04,0x0C,0x18,0x00,//C
0x03,0x07,0x0C,0x08,0x08,0x0C,0x06,0x00,
0x04,0xFC,0xFC,0x04,0x0C,0xF8,0xF0,0x00,//D
0x08,0x0F,0x0F,0x08,0x0C,0x07,0x03,0x00,
0x04,0xFC,0xFC,0x44,0xE4,0x0C,0x1C,0x00,//E
0x08,0x0F,0x0F,0x08,0x08,0x0C,0x0E,0x00,
0x04,0xFC,0xFC,0x44,0xE4,0x0C,0x1C,0x00,//F
0x08,0x0F,0x0F,0x08,0x00,0x00,0x00,0x00,
0xF0,0xF8,0x0C,0x84,0x84,0x8C,0x98,0x00,//G
0x03,0x07,0x0C,0x08,0x08,0x07,0x0F,0x00,
0xFC,0xFC,0x40,0x40,0x40,0xFC,0xFC,0x00,//H
0x00,0x00,0x04,0xFC,0xFC,0x04,0x00,0x00,//I
0x00,0x00,0x08,0x0F,0x0F,0x08,0x00,0x00,
0x00,0x00,0x00,0x04,0xFC,0xFC,0x04,0x00,//J
0x07,0x0F,0x08,0x08,0x0F,0x07,0x00,0x00,
0x04,0xFC,0xFC,0xC0,0xF0,0x3C,0x0C,0x00,//K
0x08,0x0F,0x0F,0x00,0x01,0x0F,0x0E,0x00,
0x04,0xFC,0xFC,0x04,0x00,0x00,0x00,0x00,//L
0xFC,0xFC,0x38,0x70,0x38,0xFC,0xFC,0x00,//M
0xFC,0xFC,0x38,0x70,0xE0,0xFC,0xFC,0x00,//N
0xF0,0xF8,0x0C,0x04,0x0C,0xF8,0xF0,0x00,//O
0x03,0x07,0x0C,0x08,0x0C,0x07,0x03,0x00,
0x04,0xFC,0xFC,0x44,0x44,0x7C,0x38,0x00,//P
0xF8,0xFC,0x04,0x04,0x04,0xFC,0xF8,0x00,//Q
0x07,0x0F,0x08,0x0E,0x3C,0x3F,0x27,0x00,
0x04,0xFC,0xFC,0x44,0xC4,0xFC,0x38,0x00,//R
0x08,0x0F,0x0F,0x00,0x00,0x0F,0x0F,0x00,
0x18,0x3C,0x64,0x44,0xC4,0x9C,0x18,0x00,//S
0x06,0x0E,0x08,0x08,0x08,0x0F,0x07,0x00,
0x00,0x1C,0x0C,0xFC,0xFC,0x0C,0x1C,0x00,//T
0xFC,0xFC,0x00,0x00,0x00,0xFC,0xFC,0x00,//U
0xFC,0xFC,0x00,0x00,0x00,0xFC,0xFC,0x00,//V
0x01,0x03,0x06,0x0C,0x06,0x03,0x01,0x00,
0xFC,0xFC,0x00,0x80,0x00,0xFC,0xFC,0x00,//W
0x03,0x0F,0x0E,0x03,0x0E,0x0F,0x03,0x00,
0x0C,0x3C,0xF0,0xC0,0xF0,0x3C,0x0C,0x00,//X
0x0C,0x0F,0x03,0x00,0x03,0x0F,0x0C,0x00,
0x00,0x3C,0x7C,0xC0,0xC0,0x7C,0x3C,0x00,//Y
0x1C,0x0C,0x84,0xC4,0x64,0x3C,0x1C,0x00,//Z
0x0E,0x0F,0x09,0x08,0x08,0x0C,0x0E,0x00,
0x80,0x80,0x80,0x80,0xe0,0xC0,0x80,0x00,//->0x5b(自定义显示字符)
0x01,0x01,0x01,0x01,0x07,0x03,0x01,0x00
//0x5c开始可以加入其他的自定义字符
//调用方式:void send_mi(uchar instuction)
//函数说明:发指令instruction到主窗口(内函数,私有,用户不能直接调用)
void send_mi(uchar instruction)
clr_E2(); //关S
set_E1(); //开M
wait_ready();
clr_A0(); //指令
clr_WR(); //写触发
NOP();
lcd_data = instruction; //指令码
NOP();
clr_E1(); //关M
//调用方式:void OutMD(uchar i)
//函数说明:发数据data到主窗口(内函数,私有,用户不能直接调用)
void send_md(uchar c)
clr_E2(); //关S
set_E1(); //开M
wait_ready();
set_A0(); //数据
clr_WR(); //写触发
NOP();
lcd_data = c; //数据
NOP();
clr_E1(); //关M
//调用方式:void send_si(uchar instruction)
//函数说明:发指令instruction到从窗口(内函数,私有,用户不能直接调用)
clr_E1(); //关M
set_E2(); //开S
wait_ready();
clr_A0(); //指令
clr_WR(); //写触发
NOP();
lcd_data=instruction; //指令码
NOP();
clr_E2(); //关S
//调用方式:void send_sd(uchar data)
//函数说明:发数据data到从窗口(内函数,私有,用户不直接调用)
void send_sd(uchar c)
clr_E1();
set_E2();
wait_ready();
set_A0(); //数据
clr_WR(); //写触发
lcd_data = c;
NOP();
clr_E2();
//等待ready:等待LCD内部操作完成
// DDRA = 0x00; //PA口输入
clr_A0(); //指令
set_WR(); //读
NOP();
while(lcd_data & status_busy); //读入LCD状态,1=忙,一直等待LCD内部操作完成
// DDRA = 0xff; //重新置PA口输出
//调用方式:void lcd_init(void)
//函数说明:122x32LCD初始化,开机后仅调用一次
void lcd_init(void)
send_mi(reset); //复位m-left,s-right
send_si(reset);
send_mi(disp_off); //关闭显示
send_si(disp_off);
send_mi(dynamic_driver); //动态驱动
send_si(dynamic_driver);
send_mi(clk32); //1/32占空比
send_si(clk32);
send_mi(adc_select); //clockwise
send_si(adc_select);
send_mi(mode_write); //写模式
send_si(mode_write);
send_mi(col_addr_set);
send_mi(disp_start_line); //归回零列,设定显示起始行首
send_si(col_addr_set);
send_si(disp_start_line);
send_mi(disp_on); //开显示
send_si(disp_on);
//调用方式:void lcd_clr(void)
//函数说明:清屏
void lcd_clr(void)
uchar i, page;
for (page=0;page<4;page++)
send_mi(page_addr_set|page);
send_si(page_addr_set|page);
send_mi(0); //主窗口设置为0列
send_si(0); //从窗口设置为0列
for (i=0;i<62;i++)
send_md(0x00);
send_sd(0x00);
//调用方式:void set_page(uchar page)
//函数说明:同时设置主(右)从(左)显示页为0-3页
//调用方式:void SetAddress(uchar address)
//函数说明:同时设置主(右)从(左)列地址为0-61列
void set_address(uchar address)
send_mi(address&0x7F); //&0x7F,考虑到防止越限
send_si(address&0x7F);
//调用方式:void putchar_l(uchar c)
//函数说明:在右页(从窗口)当前地址画一个字节(8点)
send_md(c);
//调用方式:void putchar_r(uchar c)
//函数说明:在左页(主窗口)当前地址画一个字节(8点)
send_sd(c);
//调用方式:void draw_bmp(uchar col,uchar layer,uchar width,uchar *bmp)
//函数说明:画一个图,横坐标是col,layer表示上下层,width是图形的宽,高固定16
// bmp是图形指针
// 使用zimo21软件,采用纵向取模下高位得到bmp数据。
// col 图型的起始位置0~121
// layer 图形的位置(Y坐标)0-下半部分 非0-上半部分
// width 图形宽度8,16可选
// bmp 图形数据指针
uchar x;
uchar address; //address表示显存的物理地址
uchar p=0;
uchar page=0;
uchar window=0; //page表示上下两页,window表示左右窗口(0左,1右)
if (layer) page=2; //左-主窗口,右-从窗口
for (x=col; x
set_page(page); //上层数据输出
set_address(address);
if (window)
putchar_r(bmp[p]);
else
putchar_l(bmp[p]);
set_page(page+1); //下层数据输出
set_address(address); //列保持不变
if (window)
putchar_r(bmp[p+width]);
else
putchar_l(bmp[p+width]);
p++;
//函数:void disp_one_ascii(uchar col,uchar layer,uchar ascii_code)
//说明:显示单个ASCII码col-列;layer-上下行:1-上,0-下;ascii_code:所要显示德ASCCII码
uchar i;
for(i=0;i<16;i++) //ASCII码显示占用16个字节
if(mode)dot_buffer[i]=~ascii[(ascii_code-0x20)*16 + i];
else dot_buffer[i]= ascii[(ascii_code-0x20)*16 + i];
draw_bmp(col,layer,8,dot_buffer);
//函数:void disp_ram_data(uchar col,uchar layer,uchar n,uchar mode)
//说明:显示小于4个的十进制数字//修改缓冲区的大小可以扩展显示
while(n--)
if(mode)disp_one_ascii(col,layer,disp_buffer[n]+0x30,1);
else disp_one_ascii(col,layer,disp_buffer[n]+0x30,0);
col += 8;
//函数:void dprintf(uchar col,uchar layer,uchar *ptr,uchar mode)
//说明:ASCII(8*16) 和 汉字(16*16)显示函数
uchar c1,c2;
uchar i,j,k;
uchar ulen;
//uchar ucol,ulayer,umode;
uchar ucol,ulayer;
ulen = 0;
ucol = col;
ulayer = layer;
while (ptr[ulen]!= 0)ulen++; //探测字串长度
i=0;
while(i
c1 = ptr[i];
c2 = ptr[i+1];
//ASCII字符与汉字内码的区别在于128做分界;大于128的为汉字码
if(c1 <=128) //ASCII
if(mode)disp_one_ascii(ucol,ulayer,c1,1);
else disp_one_ascii(ucol,ulayer,c1,0);
ucol+=8;
i++; //ASCII码的处理
else //中文
for(j=0;j
if((c1 == hz16[j].index[0]) && (c2 == hz16[j].index[1]))
break;
for(k=0;k<32;k++)
{ if(mode)dot_buffer[k]=~hz16[j].zimo[k];
else dot_buffer[k]= hz16[j].zimo[k];
draw_bmp(ucol,ulayer,16,dot_buffer);
ucol+=16;
i+=2; //中文的处理
void main(void)
uchar i;
uint j;
// DDRC=0xF0; //C口高四位为输出控制端口
// DDRA=0xFF; //A口为数据线(一般为输出,仅在读LCD状态时为输入)
for(i=0;i<10;i++)for(j=1;j;j++); //开机延时
lcd_init();
lcd_clr();
dprintf(10,1,"I AM CHINESE!",0); //说明/在up 行从第10列开始显示/正常显示
disp_ram_data(10,0,2,1); //说明/在dowm行从第10列开始显示/反白显示
while(1);
