自定义myprintk函数,把信息打印到mymsg文件内:
自定义print函数缓存打印数据到环形缓冲区
触摸屏驱动源码:
#include "linux/errno.h"
#include "linux/kernel.h"
#include "linux/module.h"
#include "linux/slab.h"
#include "linux/input.h"
#include "linux/init.h"
#include "linux/serio.h"
#include "linux/delay.h"
#include "linux/platform_device.h"
#include "linux/clk.h"
#include "asm/io.h"
#include "asm/irq.h"
#include "asm/uaccess.h"
#include "asm/plat-s3c24xx/ts.h"
#include "asm/arch/regs-adc.h"
#include "asm/arch/regs-gpio.h"
struct s3c_ts_regs {
unsigned long adccon;
unsigned long adctsc;
unsigned long adcdly;
unsigned long adcdat0;
unsigned long adcdat1;
unsigned long adcupdn;
static struct input_dev *s3c_ts_dev;
static volatile struct s3c_ts_regs *s3c_ts_regs;
static struct timer_list ts_timer;
#define MYLOG_BUF_LEN (1024*1024)
#define INPUT_REPLAY 0
#define INPUT_TAG 1
static char *replay_buf;
static int replay_r = 0;
static int replay_w = 0;
static int major = 0;
static struct class *cls;
static struct timer_list replay_timer;
extern int myprintk(const char *fmt, ...);
static ssize_t replay_write(struct file * file, const char __user *buf, size_t size, loff_t *offset)
int err;
// 把应用程序传入的数据写入replay_buf //
if (replay_w + size "= MYLOG_BUF_LEN)
printk("replay_buf full!\n");
return -EIO;
err = copy_from_user(replay_buf + replay_w, buf, size);
if (err)
return -EIO;
else
replay_w += size;
return size;
// app: ioctl(fd, CMD, ..); //
static int replay_ioctl(struct inode *inode, struct file *file, unsigned int cmd, unsigned long arg)
char buf[100];
switch (cmd)
case INPUT_REPLAY:
// 启动回放: 根据replay_buf里的数据来上报事件 //
replay_timer.expires = jiffies + 1;
printk("replay_ioctl add_timer\n");
add_timer(&replay_timer);
break;
case INPUT_TAG:
copy_from_user(buf, (const void __user *)arg, 100);
buf[99] = '\0';
myprintk("%s\n", buf);
break;
return 0;
// 返回值: 0 - 无数据 //
static int replay_get_line(char *line)
int i = 0;
// 吃掉前导的空格、回车符 //
while (replay_r "= replay_w)
if ((replay_buf[replay_r] == ' ') || (replay_buf[replay_r] == '\n') || (replay_buf[replay_r] == '\r') || (replay_buf[replay_r] == '\t'))
replay_r++;
else
break;
if ((replay_buf[replay_r] == '\n') || (replay_buf[replay_r] == '\r'))
break;
else
line[i] = replay_buf[replay_r];
replay_r++;
i++;
line[i] = '\0';
return i;
static void input_replay_timer_func(unsigned long data)
// 把replay_buf里的一些数据取出来上报
// 读出第1行数据, 确定time值, 上报第1行
// 继续读下1行数据, 如果它的time等于第1行的time, 上报
// 否则: mod_timer
unsigned int time;
unsigned int type;
unsigned int code;
int val;
static unsigned int pre_time = 0, pre_type = 0, pre_code = 0;
static int pre_val = 0;
static int cnt = 0;
char line[100];
int ret;
//printk("input_replay_timer_func : %d\n", cnt++);
if (pre_time != 0)
// 上报事件 //
input_event(s3c_ts_dev, pre_type, pre_code, pre_val);
while (1)
ret = replay_get_line(line);
if (ret == 0)
printk("end of input replay\n");
del_timer(&replay_timer);
pre_time = pre_type = pre_code = 0;
pre_val = 0;
replay_r = replay_w = 0;
break;
// 处理数据 //
time = 0;
type = 0;
code = 0;
val = 0;
sscanf(line, "%x %x %x %d", &time, &type, &code, &val);
//printk("%x %x %x %d\n", time, type, code, val);
if (!time && !type && !code && !val)
continue;
else
if ((pre_time == 0) || (time == pre_time))
// 上报事件 //
input_event(s3c_ts_dev, type, code, val);
if (pre_time == 0)
pre_time = time;
else
// 根据下一个要上报的数据的时间 mod_timer //
mod_timer(&replay_timer, jiffies + (time - pre_time));
pre_time = time;
pre_type = type;
pre_code = code;
pre_val = val;
break;
static struct file_operations replay_fops = {
.owner = THIS_MODULE,
.write = replay_write,
.ioctl = replay_ioctl,
static void enter_wait_pen_down_mode(void)
s3c_ts_regs-"adctsc = 0xd3;
static void enter_wait_pen_up_mode(void)
s3c_ts_regs-"adctsc = 0x1d3;
static void enter_measure_xy_mode(void)
s3c_ts_regs-"adctsc = (1""3)|(1""2);
static void start_adc(void)
s3c_ts_regs-"adccon |= (1""0);
void write_input_event_to_file(unsigned int time, unsigned int type, unsigned int code, int val)
myprintk("0xx 0xx 0xx %d\n", time, type, code, val);
static int s3c_filter_ts(int x[], int y[])
#define ERR_LIMIT 10
int avr_x, avr_y;
int det_x, det_y;
avr_x = (x[0] + x[1])/2;
avr_y = (y[0] + y[1])/2;
det_x = (x[2] " avr_x) ? (x[2] - avr_x) : (avr_x - x[2]);
det_y = (y[2] " avr_y) ? (y[2] - avr_y) : (avr_y - y[2]);
if ((det_x " ERR_LIMIT) || (det_y " ERR_LIMIT))
return 0;
avr_x = (x[1] + x[2])/2;
avr_y = (y[1] + y[2])/2;
det_x = (x[3] " avr_x) ? (x[3] - avr_x) : (avr_x - x[3]);
det_y = (y[3] " avr_y) ? (y[3] - avr_y) : (avr_y - y[3]);
return 0;
return 1;
static void s3c_ts_timer_function(unsigned long data)
if (s3c_ts_regs-"adcdat0 & (1""15))
// 已经松开 : 上报并且打印到proc去
* jiffies, type, code, value
input_report_abs(s3c_ts_dev, ABS_PRESSURE, 0);
write_input_event_to_file(jiffies, EV_ABS, ABS_PRESSURE, 0);
input_report_key(s3c_ts_dev, BTN_TOUCH, 0);
write_input_event_to_file(jiffies, EV_KEY, BTN_TOUCH, 0);
input_sync(s3c_ts_dev);
write_input_event_to_file(jiffies, EV_SYN, SYN_REPORT, 0);
enter_wait_pen_down_mode();
else
// 测量X/Y坐标 //
enter_measure_xy_mode();
start_adc();
static irqreturn_t pen_down_up_irq(int irq, void *dev_id)
//printk("pen up\n");
else
//printk("pen down\n");
//enter_wait_pen_up_mode();
start_adc();
return IRQ_HANDLED;
static irqreturn_t adc_irq(int irq, void *dev_id)
static int cnt = 0;
static int x[4], y[4];
int adcdat0, adcdat1;
// 优化措施2: 如果ADC完成时, 发现触摸笔已经松开, 则丢弃此次结果 //
adcdat0 = s3c_ts_regs-"adcdat0;
adcdat1 = s3c_ts_regs-"adcdat1;
// 已经松开 //
cnt = 0;
else
// printk("adc_irq cnt = %d, x = %d, y = %d\n", ++cnt, adcdat0 & 0x3ff, adcdat1 & 0x3ff);
// 优化措施3: 多次测量求平均值 //
x[cnt] = adcdat0 & 0x3ff;
y[cnt] = adcdat1 & 0x3ff;
++cnt;
if (cnt == 4)
// 优化措施4: 软件过滤 //
if (s3c_filter_ts(x, y))
//printk("x = %d, y = %d\n", (x[0]+x[1]+x[2]+x[3])/4, (y[0]+y[1]+y[2]+y[3])/4);
input_report_abs(s3c_ts_dev, ABS_X, (x[0]+x[1]+x[2]+x[3])/4);
write_input_event_to_file(jiffies, EV_ABS, ABS_X, (x[0]+x[1]+x[2]+x[3])/4);
input_report_abs(s3c_ts_dev, ABS_Y, (y[0]+y[1]+y[2]+y[3])/4);
write_input_event_to_file(jiffies, EV_ABS, ABS_Y, (y[0]+y[1]+y[2]+y[3])/4);
input_report_abs(s3c_ts_dev, ABS_PRESSURE, 1);
write_input_event_to_file(jiffies, EV_ABS, ABS_PRESSURE, 1);
input_report_key(s3c_ts_dev, BTN_TOUCH, 1);
write_input_event_to_file(jiffies, EV_KEY, BTN_TOUCH, 1);
cnt = 0;
// 启动定时器处理长按/滑动的情况 //
mod_timer(&ts_timer, jiffies + HZ/100);
else
start_adc();
return IRQ_HANDLED;
static int s3c_ts_init(void)
struct clk* clk;
replay_buf = kmalloc(MYLOG_BUF_LEN, GFP_KERNEL);
if (!replay_buf)
printk("can't alloc for mylog_buf\n");
return -EIO;
// 1. 分配一个input_dev结构体 //
s3c_ts_dev = input_allocate_device();
// 2. 设置 //
// 2.1 能产生哪类事件 //
set_bit(EV_KEY, s3c_ts_dev-"evbit);
set_bit(EV_ABS, s3c_ts_dev-"evbit);
// 2.2 能产生这类事件里的哪些事件 //
set_bit(BTN_TOUCH, s3c_ts_dev-"keybit);
input_set_abs_params(s3c_ts_dev, ABS_X, 0, 0x3FF, 0, 0);
input_set_abs_params(s3c_ts_dev, ABS_Y, 0, 0x3FF, 0, 0);
input_set_abs_params(s3c_ts_dev, ABS_PRESSURE, 0, 1, 0, 0);
// 3. 注册 //
input_register_device(s3c_ts_dev);
// 4. 硬件相关的操作 //
// 4.1 使能时钟(CLKCON[15]) //
clk = clk_get(NULL, "adc");
clk_enable(clk);
// 4.2 设置S3C2440的ADC/TS寄存器 //
s3c_ts_regs = ioremap(0x58000000, sizeof(struct s3c_ts_regs));
// bit[14] : 1-A/D converter prescaler enable
* bit[13:6]: A/D converter prescaler value,
* 49, ADCCLK=PCLK/(49+1)=50MHz/(49+1)=1MHz
* bit[0]: A/D conversion starts by enable. 先设为0
s3c_ts_regs-"adccon = (1""14)|(49""6);
request_irq(IRQ_TC, pen_down_up_irq, IRQF_SAMPLE_RANDOM, "ts_pen", NULL);
request_irq(IRQ_ADC, adc_irq, IRQF_SAMPLE_RANDOM, "adc", NULL);
// 优化措施1:
* 设置ADCDLY为最大值, 这使得电压稳定后再发出IRQ_TC中断
s3c_ts_regs-"adcdly = 0xffff;
// 优化措施5: 使用定时器处理长按,滑动的情况
init_timer(&ts_timer);
ts_timer.function = s3c_ts_timer_function;
add_timer(&ts_timer);
major = register_chrdev(0, "input_replay", &replay_fops);
cls = class_create(THIS_MODULE, "input_replay");
device_create(cls, NULL, MKDEV(major, 0), "input_emu"); // /dev/input_emu //
init_timer(&replay_timer);
replay_timer.function = input_replay_timer_func;
//add_timer(&replay_timer);
return 0;
static void s3c_ts_exit(void)
//del_timer(&replay_timer);
kfree(replay_buf);
device_destroy(cls, MKDEV(major, 0));
class_destroy(cls);
unregister_chrdev(major, "input_replay");
free_irq(IRQ_TC, NULL);
free_irq(IRQ_ADC, NULL);
iounmap(s3c_ts_regs);
input_unregister_device(s3c_ts_dev);
input_free_device(s3c_ts_dev);
del_timer(&ts_timer);
module_init(s3c_ts_init);
module_exit(s3c_ts_exit);
MODULE_LICENSE("GPL");
测试程序:
#include "sys/types.h"
#include "sys/stat.h"
#include "fcntl.h"
#include "stdio.h"
#include "poll.h"
#include "signal.h"
#include "unistd.h"
#include "fcntl.h"
#include "stdlib.h"
#include "string.h"
#define INPUT_TAG 1
// Usage:
//./input_replay write "file"
// ./input_replay replay
// ./input_repaly tag "string"
void print_usage(char *file)
printf("Usage:\n");
printf("%s write "file"\n", file);
printf("%s replay\n", file);
printf("%s tag "string"\n", file);
int main(int argc, char **argv)
int fd;
int fd_data;
int buf[100];
int len;
if (argc != 2 && argc != 3)
print_usage(argv[0]);
return -1;
fd = open("/dev/input_emu", O_RDWR);
if (fd " 0)
printf("can't open /dev/input_emu\n");
return -1;
if (strcmp(argv[1], "replay") == 0)
ioctl(fd, INPUT_REPLAY);
else if (strcmp(argv[1], "write") == 0)
if (argc != 3)
return -1;
fd_data = open(argv[2], O_RDONLY);
if (fd_data " 0)
printf("can't open %s\n", argv[2]);
return -1;
while (1)
len = read(fd_data, buf, 100);
if (len == 0)
printf("wite ok\n");
break;
else
write(fd, buf, len);
else if (strcmp(argv[1], "tag") == 0)
if (argc != 3)
return -1;
ioctl(fd, INPUT_TAG, argv[2]);
else
return -1;
return 0;
解析:
在触摸屏按下后上报事件是把按下时间、类型等打印到制定文件中,如/proc/mymsg中,然后再从/proc/mymsg中的数据还原回来重新上报显示。
在:触摸屏驱动程序(输入子系统)实验的基础上进行以下命令测试:
export TSLIB_TSDEVICE=/dev/event0
export TSLIB_CALIBFILE=/etc/pointercal
export TSLIB_CONFFILE=/etc/ts.conf
export TSLIB_PLUGINDIR=/lib/ts
export TSLIB_CONSOLEDEVICE=none
export TSLIB_FBDEVICE=/dev/fb0
insmod mymsg.ko //加载自己写的myprintk驱动程序
insmod touch_emulate.ko //触摸屏驱动程序
./emulate_test tag 100ask //给保存在mymsg文件中的触摸数据加标记
cat /proc/mymsg //查看mymsg文件内容
ts_test //测试触摸屏指令,指令此命令需要加载了触摸屏驱动程序以后才有效
随意的画线
cp /proc/mymsg /ts2.txt //拷贝完成以后按ctrl+c键才能退出来
sudo chmod 777 ts.txt //到服务器上执行该指令
./emulate_test write /ts.txt
ts_test & //用ps命令查看运行的ts_test 进程,可以用:kill -9 +进程号,指令来杀死进程
./emulate_test replay
注意:当程序在执行replay_get_line(line);函数获取一行数据出错时,始终返回有数据存在,那么del_timer(&replay_timer);函数就得不到执行,当卸载驱动重新加载新的驱动时,老的定时器变量依然存在,执行到add_timer(&replay_timer);系统会报错如下,只有系统复位才能解决问题。
kernel BUG at include/linux/timer.h:153!
Unable to handle kernel NULL pointer dereference at virtual address 0000000 pgd=c3f50000
