单片机 > 单片机程序设计 > 详情
LCD12864液晶显示的SHT11温湿度传感器程序
发布时间:2020-09-01 发布时间:
注意:低版本的keil软件不能编译成功,因为无法处理浮点运算。
#include
#include
#define uint unsigned int
#define uchar unsigned char
#define noACK 0
#define ACK   1
#define STATUS_REG_W 0x06
#define STATUS_REG_R 0x07
#define MEASURE_TEMP 0x03
#define MEASURE_HUMI 0x05
#define RESET        0x1e
enum {TEMP,HUMI};
typedef union //定义共用同类型
unsigned int i;
float f;
} value;
sbit lcdrs=P2^0;
sbit lcdrw=P2^1;
sbit lcden=P2^2;
sbit SCK = P1^0;
sbit DATA = P1^1;
uchar table2[]="SHT11 温湿度检测";
uchar table3[]="温度为:      ℃";
uchar table4[]="湿度为:";
uchar table5[]=".";
uchar wendu[6];
uchar shidu[6];
void delay(int z)
int x,y;
for(x=z;x>0;x--)
for(y=125;y>0;y--);
void delay_50us(uint t)
uint j;
for(;t>0;t--)
for(j=19;j>0;j--);
void delay_50ms(uint t)
uint j;
for(;t>0;t--)
for(j=6245;j>0;j--);
void write_12864com(uchar com)
lcdrs=0;
lcdrw=0;
delay_50us(1);
P0=com;
lcden=1;
delay_50us(10);
lcden=0;
delay_50us(2);
void write_dat(uchar dat)
lcdrs=1;
lcdrw=0;
delay_50us(1);
P0=dat;
lcden=1;
delay_50us(10);
lcden=0;
delay_50us(2);
void init12864lcd(void)
delay_50ms(2);
write_12864com(0x30);
delay_50us(4);
delay_50us(4);
write_12864com(0x0f);
delay_50us(4);
write_12864com(0x01);
delay_50us(240);
write_12864com(0x06);
delay_50us(10);
write_12864com(0x0c);
delay_50us(10);
void display1(void)
uchar i;
write_12864com(0x80);
for(i=0;i<18;i++)
write_dat(table2[i]);
delay_50us(1);
void display2(void)
uchar i;
write_12864com(0x90);
for(i=0;i<18;i++)
write_dat(table3[i]);
delay_50us(1);
void display3(void)
uchar i;
write_12864com(0x88);
for(i=0;i<8;i++)
write_dat(table4[i]);
delay_50us(1);
void displaywendu(void)
uchar i;
write_12864com(0x94);
for(i=0;i<3;i++)
write_dat(wendu[i]);
delay_50us(1);
for(i=0;i<1;i++)
write_dat(table5[i]);
delay_50us(1);
for(i=4;i<5;i++)
delay_50us(1);
void displayshidu(void)
uchar i;
write_12864com(0x8C);
for(i=0;i<3;i++)
write_dat(shidu[i]);
delay_50us(1);
for(i=0;i<1;i++)
delay_50us(1);
for(i=4;i<5;i++)
delay_50us(1);
//写字节程序
char s_write_byte(unsigned char value)
unsigned char i,error=0;
for (i=0x80;i>0;i>>=1)             //高位为1,循环右移
if (i&value) DATA=1;          //和要发送的数相与,结果为发送的位
    else DATA=0;
    SCK=1;
    _nop_();_nop_();_nop_();        //延时3us
    SCK=0;
DATA=1;                           //释放数据线
SCK=1;
error=DATA;                       //检查应答信号,确认通讯正常
SCK=0;
DATA=1;
return error;                     //error=1 通讯错误
//读字节程序
char s_read_byte(unsigned char ack)
unsigned char i,val=0;
DATA=1;                           //释放数据线
for(i=0x80;i>0;i>>=1)             //高位为1,循环右移
SCK=1;
    if(DATA) val=(val|i);             //读一位数据线的值
    SCK=0;
DATA=!ack;                        //如果是校验,读取完后结束通讯;
SCK=1;
SCK=0;
DATA=1;                           //释放数据线
return val;
//启动传输
void s_transstart(void)
    DATA=1; SCK=0;                   //准备
    _nop_();
  SCK=1;
    _nop_();
    DATA=0;
    _nop_();
  SCK=0;
    SCK=1;
    _nop_();
  DATA=1;
  _nop_();
    SCK=0;
//连接复位
void s_connectionreset(void)
unsigned char i;
DATA=1; SCK=0;                    //准备
for(i=0;i<9;i++)                  //DATA保持高,SCK时钟触发9次,发送启动传输,通迅即复位
SCK=1;
    SCK=0;
s_transstart();                   //启动传输
//软复位程序
char s_softreset(void)
unsigned char error=0;
s_connectionreset();              //启动连接复位
error+=s_write_byte(RESET);       //发送复位命令
//温湿度测量
char s_measure(unsigned char *p_value, unsigned char *p_checksum, unsigned char mode)
unsigned error=0;
unsigned int i;
switch(mode)                      //选择发送命令
case TEMP : error+=s_write_byte(MEASURE_TEMP); break;   //测量温度
           case HUMI : error+=s_write_byte(MEASURE_HUMI); break;   //测量湿度
    default     : break;
for (i=0;i<65535;i++) if(DATA==0) break;        //等待测量结束
if(DATA) error+=1;                              // 如果长时间数据线没有拉低,说明测量错误
*(p_value) =s_read_byte(ACK);     //读第一个字节,高字节 (MSB)
*(p_value+1)=s_read_byte(ACK);     //读第二个字节,低字节 (LSB)
*p_checksum =s_read_byte(noACK); //read CRC校验码
return error; // error=1 通讯错误
//温湿度值标度变换及温度补偿
void calc_sth10(float *p_humidity ,float *p_temperature)
const float C1=-4.0;              // 12位湿度精度 修正公式
const float C2=+0.0405;           // 12位湿度精度修正公式
const float C3=-0.0000028;        // 12位湿度精度修正公式
const float T1=+0.01;             // 14位温度精度 5V条件  修正公式
const float T2=+0.00008;          // 14位温度精度 5V条件  修正公式
float rh=*p_humidity;             // rh:      12位 湿度
float t=*p_temperature;           // t:       14位温度
float rh_lin;                     // rh_lin: 湿度 linear值
float rh_true;                    // rh_true: 湿度 ture值
float t_C;                        // t_C   : 温度 ℃
t_C=t*0.01 - 40;                  //补偿温度
rh_lin=C3*rh*rh + C2*rh + C1;     //相对湿度非线性补偿
rh_true=(t_C-25)*(T1+T2*rh)+rh_lin;   //相对湿度对于温度依赖性补偿
if(rh_true>100)rh_true=100;       //湿度最大修正
if(rh_true<0.1)rh_true=0.1;       //湿度最小修正
*p_temperature=t_C;               //返回温度结果
*p_humidity=rh_true;              //返回湿度结果
void main(void)
unsigned int temp,humi;
value humi_val,temp_val; //定义两个共同体,一个用于湿度,一个用于温度
unsigned char error;    //用于检验是否出现错误
unsigned char checksum; //CRC
init12864lcd();
display1();
display2();
display3();
while(1)
error=0;   //初始化error=0,即没有错误
error+=s_measure((unsigned char*)&temp_val.i,&checksum,TEMP); //温度测量
error+=s_measure((unsigned char*)&humi_val.i,&checksum,HUMI); //湿度测量
    if(error!=0) s_connectionreset();                 ////如果发生错误,系统复位
    else
humi_val.f=(float)humi_val.i;                   //转换为浮点数
      temp_val.f=(float)temp_val.i;                   //转换为浮点数
      calc_sth10(&humi_val.f,&temp_val.f);            //修正相对湿度及温度
    temp=temp_val.f*10;
      humi=humi_val.f*10;
      wendu[0]=temp/1000+'0';     //温度百位
      wendu[1]=temp00/100+'0';     //温度十位
    wendu[2]=temp0/10+'0'; //温度个位
      wendu[3]=0x2E; //小数点
    wendu[4]=temp+'0'; //温度小数点后第一位
displaywendu();
shidu[0]=humi/1000+'0';     //湿度百位
      shidu[1]=humi00/100+'0';     //湿度十位
    shidu[2]=humi0/10+'0'; //湿度个位
      shidu[3]=0x2E; //小数点
    shidu[4]=humi+'0'; //湿度小数点后第一位
displayshidu();
delay(800);                             //等待足够长的时间,以现行下一次转换
ATtiny13 复位与中断处理
