移植环境
1,主机环境:VMare下CentOS 5.5 ,1G内存。
2,集成开发环境:Elipse IDE
3,编译编译环境:arm-linux-gcc v4.4.3,arm-none-linux-gnueabi-gcc v4.5.1。
4,开发板:mini2440,2M nor flash,128M nand flash。
5,u-boot版本:u-boot-2009.08
6,linux 版本:linux-2.6.32.2
7,参考文章:
【1】嵌入式linux应用开发完全手册,韦东山,编著。
【2】Mini2440 之Linux 移植开发实战指南
【3】http://linux.chinaunix.net/techdoc/system/2009/08/24/1131864.shtml
3.1,移植DM9000 网卡驱动
【1】设备资源初始化
Linux-2..6.32.2 已经自带了完善的DM9000 网卡驱动驱动(源代码位置:linux-2.6.32.2/drivers/net/dm9000.c),它也是一个平台设备,因此在目标平台初始化代码中,只要填写好相应的结构表即可,具体步骤如下:
(1)确认已经添加了驱动所需的头文件 dm9000.h:
用gedit打开linux-2.6.32.2/arch/arm/mach-mini2440.c,定位到55行附近,加入dm9000.h,如下所示:
#include
#include
#include
#include
#include
#include
#include
(2)填充该平台设备的资源设置
定位到210行附近,如入下面代码:
tatic struct s3c2410_platform_nand mini2440_nand_info = {
.tacls = 20,
.twrph0 = 60,
.twrph1 = 20,
.nr_sets = ARRAY_SIZE(mini2440_nand_sets),
.sets = mini2440_nand_sets,
.ignore_unset_ecc = 1,
/* DM9000AEP 10/100 ethernet controller */ //定义DM9000 网卡设备的物理基地址,以便后面用到
#define MACH_MINI2440_DM9K_BASE (S3C2410_CS4 + 0x300)
//再填充该平台设备的资源设置,以便和 DM9000 网卡驱动接口配合起来
static struct resource mini2440_dm9k_resource[] = {
[0] = {
.start = MACH_MINI2440_DM9K_BASE,
.end = MACH_MINI2440_DM9K_BASE + 3,
.flags = IORESOURCE_MEM
[1] = {
.start = MACH_MINI2440_DM9K_BASE + 4,
.end = MACH_MINI2440_DM9K_BASE + 7,
[2] = {
.start = IRQ_EINT7,
.end = IRQ_EINT7,
.flags = IORESOURCE_IRQ | IORESOURCE_IRQ_HIGHEDGE,
* * The DM9000 has no eeprom, and it's MAC address is set by
* * the bootloader before starting the kernel.
static struct dm9000_plat_data mini2440_dm9k_pdata = {
.flags = (DM9000_PLATF_16BITONLY | DM9000_PLATF_NO_EEPROM),
static struct platform_device mini2440_device_eth = {
.name = "dm9000",
.id = -1,
.num_resources = ARRAY_SIZE(mini2440_dm9k_resource),
.resource = mini2440_dm9k_resource,
.dev = {
.platform_data = &mini2440_dm9k_pdata,
static struct platform_device *mini2440_devices[] __initdata = {
&s3c_device_usb,
&s3c_device_lcd,
&s3c_device_wdt,
&s3c_device_i2c0,
&s3c_device_iis,
&s3c_device_nand, //;把nand flash 设备添加到开发板的设备列表结构
&mini2440_device_eth, //;把网卡平台设备添加到开发板的设备列表结构
static void __init mini2440_map_io(void)
【2】调整DM9000 所用的位宽寄存器
因为 Linux-2.6.32.2 的DM9000 网卡驱动并不是专门为mini2440 准备的,所以还要在其源代码中做一些移植工作,如下步骤。
(1)打开linux-2.6.32.2/drivers/net/dm9000.c,定位到41行附近,添加2410 相关的配置定义,如下红色部分:
#include
#include
#include
#include "dm9000.h"
#if defined(CONFIG_ARCH_S3C2410)
#include
#endif
(2) 在dm9000 设备的初始化函数中添加如下红色部分,这里是配置DM9000 所用片选总线的时序,因为mini2440 目前只有一个通过总线外扩的设备,在此设备驱动中直接修改相关的寄存器配置会更加容易理解一些,当然这部分也可以放到mach-mini2440.c 中。
打开linux-2.6.32.2/drivers/net/dm9000.c,定位到1555行附近,加入下面代码:
static int __init
dm9000_init(void)
unsigned int oldval_bwscon = *(volatile unsigned int *)S3C2410_BWSCON;
unsigned int oldval_bankcon4 = *(volatile unsigned int *)S3C2410_BANKCON4;
*((volatile unsigned int *)S3C2410_BWSCON) =
(oldval_bwscon & ~(3<<16)) | S3C2410_BWSCON_DW4_16 | S3C2410_BWSCON_WS4 | S3C2410_BWSCON_ST4;
*((volatile unsigned int *)S3C2410_BANKCON4) = 0x1f7c;
#endif
printk(KERN_INFO "%s Ethernet Driver, V%s\n", CARDNAME, DRV_VERSION);
return platform_driver_register(&dm9000_driver);
【3】需要注意的是,本开发板所用的DM9000 网卡并没有外接EEPROM 用以存储MAC 地址,因此系统中的MAC 地址是一个“软”地址,也就是可以通过软件进行修改,可以随意改为其他值。
打开linux-2.6.32.2/drivers/net/dm9000.c,定位到1461行附近,加入下面一行代码:
static int __devinit
dm9000_probe(struct platform_device *pdev)
/* try reading the node address from the attached EEPROM */
//;尝试从EEPROM 读取MAC 地址
for (i = 0; i < 6; i += 2)
dm9000_read_eeprom(db, i / 2, ndev->dev_addr+i);
if (!is_valid_ether_addr(ndev->dev_addr) && pdata != NULL) {
mac_src = "platform data";
memcpy(ndev->dev_addr, pdata->dev_addr, 6);
if (!is_valid_ether_addr(ndev->dev_addr)) {
/* try reading from mac */
mac_src = "chip";
for (i = 0; i < 6; i++)
ndev->dev_addr[i] = ior(db, i+DM9000_PAR);
//;使用“软”MAC 地址: 08:90:90:90:90:90
memcpy(ndev->dev_addr, "\x08\x90\x90\x90\x90\x90", 6);
dev_warn(db->dev, "%s: Invalid ethernet MAC address. Please "
"set using ifconfig\n", ndev->name);
platform_set_drvdata(pdev, ndev);
ret = register_netdev(ndev);
if (ret == 0)
printk(KERN_INFO "%s: dm9000%c at %p,%p IRQ %d MAC: %pM (%s)\n",
ndev->name, dm9000_type_to_char(db->type),
db->io_addr, db->io_data, ndev->irq,
ndev->dev_addr, mac_src);
return 0;
out:
dev_err(db->dev, "not found (%d).\n", ret);
dm9000_release_board(pdev, db);
free_netdev(ndev);
return ret;
实际上到此为止 DM9000 就已经移植结束了。
3.2,编译测试
【1】在编译之前,需要确认在内核中已经配置了网卡驱动
在内核目录下执行:
[root@localhost linux-2.6.32.2]# make menuconfig
在打开的配置菜单Device Drivers --->Network device support ---> Ethernet (10 or 100Mbit) --->,可以看到如下图
DM9000 已经被选中,这是因为Linux-2.6.32.2默认的内核配置已经加入了DM9000 的支持。
【2】编译
[root@localhost linux-2.6.32.2]# make clean
[root@localhost linux-2.6.32.2]# make uImage
编译完成后生成zImage 和 uImage
【3】进行网卡驱动测试
(1)采用友善官方已经移植好的根文件系统,可以从其提供的光盘映像/linux目录下直接复制过来。
[root@localhost ~]# cd linux-test
[root@localhost linux-test]# ls
busybox-1.13.3 mkyaffs2image.tgz
busybox-1.13.3-mini2440.tgz myrootfs
busybox-1.18.4 rootfs_qtopia_qt4
busybox-1.18.4.tar.bz2 rootfs_qtopia_qt4-20110304.tar.gz
linux-2.6.32.2 usr
linux-2.6.39 yaffs2
(2)将其复制到宿主机/nfsboot目录下并命名为roorfs
[root@localhost linux-test]# cp -rf rootfs_qtopia_qt4 /nfsboot/rootfs
并确保rootfs目录可读写
[root@localhost linux-test]# cd /nfsboot
[root@localhost nfsboot]# ls -l
总计 65280
drwxr-xr-x 18 root root 4096 06-01 19:06 rootfs
-rwxrw-rw- 1 root root 58487616 2009-07-18 root_qtopia-128M.img
-rw-r--r-- 1 root root 2110720 06-01 13:31 uImage
-rwxr-xr-x 1 root root 2022412 05-12 11:37 uImage_T35
-rwxr-xr-x 1 root root 2110656 06-01 13:31 zImage
-rwxrw-rw- 1 root root 2022348 2009-07-08 zImage_T35
(3)修改/etc/exports配置文件将rootfs默认的共享目录
[root@localhost ~]# vim /etc/exports
打开的配置文件将共享目录修改成如下所示:
/nfsboot/rootfs 10.1.0.*(rw,sync,no_root_squash)
/nfsboot/kernel 10.1.0.*(rw,sync,no_root_squash)
/nfsboot/nfs 10.1.0.*(rw,sync,no_root_squash)
# /nfsboot/rootfs 是共享目录,存放跟文件系统(使用绝对路径)
# /nfsboot/kernel 是共享目录,存放跟文件系统(使用绝对路径)
# /nfsboot/nfs 是共享目录,存放应用程序(使用绝对路径)
# 10.1.0.*表示客户端所在网段10.1.0.0/24
# 10.1.0.0/24表示10.1.0.1~10.1.0.254网段,子网掩码是255.255.255.0。
# 子网掩码是怎么来的呢?其实关键就在“24”上。我们知道IP地址是四个十进制数
# 组成的,相当于32位二进制。用CIDR表示形式,后一个数字将这32位进行了间隔
#(以24为例):前24位用"1"表示,后面8位用0表示,得到一个二进制数:
# 11111111 11111111 11111111 00000000
# 将其转化为十进制,就是:255.255.255.0了。
# rw:可读写
# sync:同步写入磁盘。
# no_root_squash:允许非root用户操作改文件夹
然后保存退出,重新启动nfs服务:
[root@localhost ~]# service nfs restart
关闭 NFS mountd: [确定]
关闭 NFS 守护进程: [确定]
关闭 NFS quotas: [确定]
关闭 NFS 服务: [确定]
启动 NFS 服务: [确定]
关掉 NFS 配额: [确定]
启动 NFS 守护进程: [确定]
启动 NFS mountd: [确定]
[root@localhost ~]#
(4)修改u-boot内核引导参数
在u-boot启动并进入命令行状态下
A,确保bootargs ="noinitrd console=ttySAC0,115200 init=/linuxrc mem=64M \
root=/dev/nfs rw nfsroot=10.1.0.128:/nfsboot \
ip=10.1.0.129:10.1.128:10.1.0.1:255.255.255.0::eth0:off"
B,确保bootcmd="nfs 0x30008000 10.1.0.128:/nfsboot/uImage;bootm"
先查看u-boot的环境变量
Environment size: 405/131068 bytes
[u-boot@MINI2440]#
这里的u-boot内核引导参数bootargs和bootcmd显然与我们要求的不一致,要重新设置此参数:
[u-boot@MINI2440]# setenv bootargs 'noinitrd console=ttySAC0,115200 init=/linux'
rc mem=64M root=/dev/nfs rw nfsroot=10.1.0.128:/nfsboot/rootfs ip=10.1.0.129:10'
.1.0.128:10.1.0.1:255.255.255.0::eht0:off'
[u-boot@MINI2440]# setenv bootcmd 'nfs 0x31000000 10.1.0.128:/uImage;bootm 0x31000000'
然后保存此变量到nand flash
[u-boot@MINI2440]# saveenv
Saving Environment to NAND...
Erasing Nand...
Erasing at 0x4000000000002 -- 0% complete.
Writing to Nand... done
有关内核引导参数的含义请参照u-boot-2009.08在mini2440上的移植(六)---增加引导内核功能。
(5)确认内核的命令行参数
如果编译内核生成的是zImage映像文件,那么CONFIG_CMDLINE需要
CONFIG_CMDLINE="root=/dev/nfs rw nfsroot=10.1.0.128:/nfsboot/rootfs ip=10.1.0.129 console=ttySAC0 mem=64M"
如果编译内核生成的是uImage映像文件,那么CONFIG_CMDLINE可以为空,因为uImage的文件头中的参数会被传进这个地方来。
(6)将编译生成zImage和uImage文件复制到宿主机/nfsboot/目录下
rootfs root_qtopia-128M.img uImage uImage_T35 zImage zImage_T35
(7)给开发板上电,启动u-boot
I2C: ready
DRAM: 64 MB
Flash: 2 MB
NAND: 128 MiB
Video: 240x320x16 20kHz 62Hz
In: serial
Out: serial
Err: serial
Net: dm9000
U-Boot 2009.08
modified by singleboy(singleboy@163.com)
Love Linux forever!!!
Hit any key to stop autoboot: 0
dm9000 i/o: 0x20000300, id: 0x90000a46
DM9000: running in 16 bit mode
MAC: 08:00:3e:26:0a:5b
operating at 100M full duplex mode
Using dm9000 device
File transfer via NFS from server 10.1.0.128; our IP address is 10.1.0.129
Filename '/nfsboot/uImage'.
Load address: 0x31000000
Loading: #################################################################
done
Bytes transferred = 2110772 (203534 hex)
## Booting kernel from Legacy Image at 31000000 ...
Image Name: Linux-2.6.32.2
Created: 2011-06-01 11:10:24 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2110708 Bytes = 2 MB
Load Address: 30008000
Entry Point: 30008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux.............................................................
...................................................................... done, boo
ting the kernel.
Linux version 2.6.32.2 (root@localhost.localdomain) (gcc version 4.4.3 (ctng-1.6
.1) ) #11 Wed Jun 1 19:10:07 CST 2011
CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=00007177
CPU: VIVT data cache, VIVT instruction cache
Machine: my mini2440 devolopment board singleboy@163.com
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
s3c24xx-nand s3c2440-nand: Tacls=3, 29ns Twrph0=7 69ns, Twrph1=3 29ns
s3c24xx-nand s3c2440-nand: NAND soft ECC
NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bi
t)
Scanning device for bad blocks
Creating 5 MTD partitions on "NAND 128MiB 3,3V 8-bit":
0x000000000000-0x000000040000 : "boot"
0x000000040000-0x000000060000 : "param"
0x000000060000-0x000000560000 : "kernel"
0x000000560000-0x000008000000 : "rootfs"
0x000000000000-0x000008000000 : "nand"
dm9000 Ethernet Driver, V1.31
eth0: dm9000e at c486e300,c4872304 IRQ 51 MAC: 08:90:90:90:90:90 (chip)
eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
IP-Config: Complete:
device=eth0, addr=10.1.0.129, mask=255.255.255.0, gw=10.1.0.1,
host=10.1.0.129, domain=, nis-domain=(none),
bootserver=10.1.0.128, rootserver=10.1.0.128, rootpath=
Looking up port of RPC 100003/2 on 10.1.0.128
Looking up port of RPC 100005/1 on 10.1.0.128
VFS: Mounted root (nfs filesystem) on device 0:14.
Freeing init memory: 132K
----------munt all----------------
************booting to mini2440 *****************
Kernel version:linux-2.6.32.2
the fans:singelboy
Date:2011.5.30
Please press Enter to activate this console.
根据内核启动信息,可以看到dm9000网卡驱动移植成功。
接下来,将为内核建立根文件系统。
