0. 准备
先用st-link连接stm32核心板与PC,用于烧录
St-link | Stm32 |
3.3V | 3.3V |
GND | GND |
SWDIO | DIO |
SWCLK | DCLK |
再用USB串口板连接,用于查看串口输出
USB | Stm32 |
RX | TX(A9) |
TX | RX(A10) |
安装完成驱动并连接好以后,进入设备管理器可以看到它们都已被识别。
打开putty.exe,选择串口连接,用于查看之后的串口输出。
void UART0_Init(UART_HandleTypeDef* UartHandle){
UartHandle->Instance = USART1;
UartHandle->Init.BaudRate = 9600;
UartHandle->Init.WordLength = UART_WORDLENGTH_8B;
UartHandle->Init.StopBits = UART_STOPBITS_1;
UartHandle->Init.Parity = UART_PARITY_NONE;
UartHandle->Init.HwFlowCtl = UART_HWCONTROL_NONE;
UartHandle->Init.Mode = UART_MODE_TX_RX;
HAL_UART_Init(UartHandle);
在main函数中填上下面两行代码
UART_HandleTypeDef UartHandle;
UART0_Init(&UartHandle);
以及输出hello的代码
HAL_UART_Transmit(&UartHandle, (uint8_t*)”hello\r\n”, 7, 500);
完成代码后,准备编译。选择flash-设置,进入Utilities标签,选择settings,配置如下:
void MX_GPIO_Init(void)
GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
GPIO_InitStruct.Pull = GPIO_PULLUP;
在while(1)中添加代码,循环检测并输出
if(!HAL_GPIO_ReadPin(GPIOA,GPIO_PIN_11))
HAL_UART_Transmit(&UartHandle, (uint8_t*)”Pressed\r\n”, 9, 500);
else
HAL_UART_Transmit(&UartHandle, (uint8_t*)”Not pressed\r\n”, 13, 500);
输出如图
GPIO_InitStruct.Pin = GPIO_PIN_12;
GPIO_InitStruct.Mode = GPIO_MODE_IT_FALLING;
HAL_NVIC_SetPriority(EXTI15_10_IRQn,0,0);
HAL_NVIC_EnableIRQ(EXTI15_10_IRQn);
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
PA12引脚的下降沿触发将会触发中断,进入函数EXTI15_10_IRQHandler,此时在函数中调用HAL_GPIO_EXTI_IRQHandler(GPIO_PIN_12)表示查看PA12的值,如果符合条件,则触发HAL_GPIO_EXTI_Callback函数。代码如下
void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin){
if (GPIO_Pin == GPIO_PIN_12){
PA12flag = 1;
PA12cnt++;
}else{
UNUSED(GPIO_Pin);
在main函数的while循环中添加代码:
if(PA12flag == 1){
PA12flag = 0;
size = sprint(str, ”Count: %d\r\n”,PA12cnt);
HAL_UART_Transmit(&UartHandle, (uint8_t*)str, size, 500);
void TIM_Init(){
TIM_Handle.Instance = TIM3;
TIM_Handle.Init.Prescaler = 8000;
TIM_Handle.Init.CounterMode = TIM_COUNTERMODE_UP;
TIM_Handle.Init.Period = 199;
TIM_Handle.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
HAL_TIM_Base_Init(&TIM_Handle);
sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL; //设置时钟源为内部时钟
HAL_TIM_ConfigClockSource(&TIM_Handle, &sClockSourceConfig);
sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;//设置复位模式,发生触发输入事件时计数器和预分频器能重新初始化
sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
HAL_TIMEx_MasterConfigSynchronization(&TIM_Handle, &sMasterConfig);
HAL_NVIC_SetPriority(TIM3_IRQn, 0, 0);//设置优先级
HAL_NVIC_EnableIRQ(TIM3_IRQn);enable中断向量表处理
和之前设置的中断一样需要覆写中断触发函数TIM3_IRQHandler,而后在其中对时钟进行判断后触发HAL_TIM_PeriodElapsedCallback。并在callback中实现操作。
TIM_HandleTypeDef TIM_Handle;
TIM_ClockConfigTypeDef sClockSourceConfig;
TIM_MasterConfigTypeDef sMasterConfig;
int TIMflag = 0, PA12flag = 0;
int TIMcnt = 0, PA12cnt = 0, totalcnt = 0;
void TIM3_IRQHandler(void){
HAL_TIM_IRQHandler(&TIM_Handle);
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim){
TIMflag = 1;
TIMcnt++;
6. 编写完整的码表程序,PA12的按钮表示车轮转了一圈,通过计数器可以得到里程,通过定时器中断得到的时间可以计算出速度;PA11的按钮切换模式,模式一在串口输出里程,模式二在串口输出速度。
在main函数中实现码表程序:
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
if(TIMflag == 1){
TIMflag = 0;
if(TIMcnt == 5){每五个周期输出一次
speed = 2 * PA12cnt / 1;//五个周期为1秒,车轮周长2米
TIMcnt = 0;
mode = 1 - mode;//PA11按钮负责模式切换
switch(mode){
case 0:
size = sprintf(str, "Speed : %f \r\n",speed);//输出速度
break;
case 1:
size = sprintf(str, "Mileage: %d \r\n", 2 * totalcnt);//输出里程
break;
default:break;
PA12cnt = 0;
