制作出来的LCD12864万年历实物图如下:
LCD12864万年历仿真原理图如下(proteus仿真工程文件可到本帖附件中下载)
电路原理图如下:
单片机源程序如下:
名称:12864字库液晶显示
内容:通过显示字符、数字、汉字和图片测试液晶基本功能
#include
#include
#include "delay.h"
sbit RS = P3^5;
sbit RW = P3^6;
sbit E = P3^4;
sbit RES = P1^7;
sbit PSB = P1^6;
sbit beep = P2^3;
#define DataPort P0 //MCU P0 LCM
typedef unsigned char U8; /* defined for unsigned 8-bits integer variable 无符号8位整型变量 */
typedef signed char S8; /* defined for signed 8-bits integer variable 有符号8位整型变量 */
typedef unsigned int U16; /* defined for unsigned 16-bits integer variable 无符号16位整型变量 */
typedef signed int S16; /* defined for signed 16-bits integer variable 有符号16位整型变量 */
typedef unsigned long U32; /* defined for unsigned 32-bits integer variable 无符号32位整型变量 */
typedef signed long S32; /* defined for signed 32-bits integer variable 有符号32位整型变量 */
typedef float F32; /* single precision floating point variable (32bits) 单精度浮点数(32位长度) */
typedef double F64; /* double precision floating point variable (64bits) 双精度浮点数(64位长度) */
#define uchar unsigned char
#define uint unsigned int
#define Data_0_time 4
//----------------IO口定义区--------------------//
sbit P2_0 = P2^0 ;
//----------------定义区--------------------//
U8 U8FLAG,k;
U8 U8count,U8temp;
U8 U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
U8 U8comdata;
U8 count;
U8 flag;
U8 jishi_flag = 0,count_up = 0;
unsigned char count=0,ss=0,sg=0,fs=0,fg=0,ms=0,mg=0,m=0,f=0,s=0,yue=1,ri=1;
unsigned char str1[]={"温度:00 "},str2[2],str3[]={"湿度:00%"},str4[2],dat=1,cal[10]={"0001-01-01"};
//DS1302引脚定义
sbit RST=P1^0;
sbit IO=P1^1;
sbit SCK=P1^2;
//DS1302地址定义
#define ds1302_sec_add 0x80 //秒数据地址
#define ds1302_min_add 0x82 //分数据地址
#define ds1302_hr_add 0x84 //时数据地址
#define ds1302_date_add 0x86 //日数据地址
#define ds1302_month_add 0x88 //月数据地址
#define ds1302_day_add 0x8a //星期数据地址
#define ds1302_year_add 0x8c //年数据地址
#define ds1302_control_add 0x8e //控制数据地址
#define ds1302_charger_add 0x90
#define ds1302_clkburst_add 0xbe
//初始时间定义
uchar time_buf[8] = {0x20,0x16,0x12,0x31,0x22,0x16,0x00,0x06};
void Delay18ms() //@11.0592MHz
unsigned char i, j, k;
_nop_();
_nop_();
i = 1;
j = 194;
k = 159;
do
do
while (--k);
} while (--j);
} while (--i);
void Delay10us() //@11.0592MHz
unsigned char i;
_nop_();
_nop_();
_nop_();
i = 24;
while (--i);
//DS1302初始化函数
void ds1302_init(void)
RST=0; //RST脚置低
SCK=0; //SCK脚置低
//向DS1302写入一字节数据
void ds1302_write_byte(uchar addr, uchar d)
uchar i;
RST=1; //启动DS1302总线
//写入目标地址:addr
addr = addr & 0xFE; //最低位置零,寄存器0位为0时写,为1时读
for (i = 0; i < 8; i ++) {
if (addr & 0x01) {
IO=1;
else {
IO=0;
SCK=1; //产生时钟
SCK=0;
addr = addr >> 1;
//写入数据:d
if (d & 0x01) {
IO=1;
else {
IO=0;
SCK=1; //产生时钟
SCK=0;
d = d >> 1;
RST=0; //停止DS1302总线
//从DS1302读出一字节数据
uchar ds1302_read_byte(uchar addr) {
uchar i,temp;
RST=1; //启动DS1302总线
//写入目标地址:addr
addr = addr | 0x01; //最低位置高,寄存器0位为0时写,为1时读
if (addr & 0x01) {
IO=1;
_nop_();
_nop_();
else {
IO=0;
_nop_();
_nop_();
SCK=1;
SCK=0;
addr = addr >> 1;
//输出数据:temp
temp = temp >> 1;
if (IO) {
temp |= 0x80;
else {
temp &= 0x7F;
SCK=1;
_nop_();
_nop_();
SCK=0;
_nop_();
_nop_();
RST=0; //停止DS1302总线
_nop_();
_nop_();
return temp;
//向DS302写入时钟数据
void ds1302_write_time(void)
ds1302_write_byte(ds1302_control_add,0x00); //关闭写保护
ds1302_write_byte(ds1302_sec_add,0x80); //暂停时钟
//ds1302_write_byte(ds1302_charger_add,0xa9); //涓流充电
ds1302_write_byte(ds1302_year_add,time_buf[1]); //年
ds1302_write_byte(ds1302_month_add,time_buf[2]); //月
ds1302_write_byte(ds1302_date_add,time_buf[3]); //日
ds1302_write_byte(ds1302_hr_add,time_buf[4]); //时
ds1302_write_byte(ds1302_min_add,time_buf[5]); //分
ds1302_write_byte(ds1302_sec_add,time_buf[6]); //秒
ds1302_write_byte(ds1302_day_add,time_buf[7]); //周
ds1302_write_byte(0xc0,0xaa);
ds1302_write_byte(ds1302_control_add,0x80); //打开写保护
//从DS302读出时钟数据
void ds1302_read_time(void)
time_buf[1]=ds1302_read_byte(ds1302_year_add); //年
time_buf[2]=ds1302_read_byte(ds1302_month_add); //月
time_buf[3]=ds1302_read_byte(ds1302_date_add); //日
time_buf[4]=ds1302_read_byte(ds1302_hr_add); //时
time_buf[5]=(ds1302_read_byte(ds1302_min_add)); //分
time_buf[6]=(ds1302_read_byte(ds1302_sec_add))&0x3f;//秒,屏蔽秒的第7位,避免超出59
time_buf[7]=ds1302_read_byte(ds1302_day_add); //周
void COM(void)
U8 i;
for(i=0;i<8;i++)
U8FLAG=2;
while((!P2_0)&&U8FLAG++);
Delay10us();
Delay10us();
Delay10us();
U8temp=0;
if(P2_0)U8temp=1;
U8FLAG=2;
while((P2_0)&&U8FLAG++);
//超时则跳出for循环
if(U8FLAG==1)break;
//判断数据位是0还是1
// 如果高电平高过预定0高电平值则数据位为 1
U8comdata<<=1;
U8comdata|=U8temp; //0
}//rof
//-----湿度读取子程序 ------------
//----以下变量均为全局变量--------
//----温度高8位== U8T_data_H------
//----温度低8位== U8T_data_L------
//----湿度高8位== U8RH_data_H-----
//----湿度低8位== U8RH_data_L-----
//----校验 8位 == U8checkdata-----
//----调用相关子程序如下----------
//---- Delay();, Delay_10us();,COM();
void RH(void)
//主机拉低18ms
P2_0=0;
Delay18ms();
P2_0=1;
//总线由上拉电阻拉高 主机延时20us
Delay10us();
Delay10us();
Delay10us();
Delay10us();
//主机设为输入 判断从机响应信号
P2_0=1;
//判断从机是否有低电平响应信号 如不响应则跳出,响应则向下运行
if(!P2_0) //T !
U8FLAG=2;
//判断从机是否发出 80us 的低电平响应信号是否结束
U8FLAG=2;
//判断从机是否发出 80us 的高电平,如发出则进入数据接收状态
//数据接收状态
COM();
U8RH_data_H=U8comdata;
COM();
U8RH_data_L=U8comdata;
COM();
U8T_data_H=U8comdata;
COM();
U8T_data_L=U8comdata;
COM();
U8checkdata=U8comdata;
P2_0=1;
}//fi
unsigned char code user16x16[]={ //笑脸图片
0x0F,0xF0,0x10,0x08,0x20,0x04,0x40,0x02,0x9C,0x39,0xBE,0x7D,0x80,0x01,0x80,0x01,
0x80,0x01,0x88,0x11,0x84,0x21,0x43,0xC2,0x20,0x04,0x10,0x08,0x0F,0xF0,0x00,0x00,
unsigned char code pic1[]= // 图片代码
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x
