单片机 > 单片机程序设计 > 详情
51单片机读写RC522卡(LCD12864)RFID开发程序与原理图
发布时间:2021-01-22 发布时间:
RFID RC522程序及原理
单片机源程序如下:
#include "reg52.h"
#include "main.h"
#include "mfrc522.h"
#include "LCD12864.h"
#include
#include
sbit BEEP=P0^1        ;
#define SET_BEEP  BEEP = 0
#define CLR_BEEP         BEEP = 1
//M1卡的某一块写为如下格式,则该块为钱包,可接收扣款和充值命令
//4字节金额(低字节在前)+4字节金额取反+4字节金额+1字节块地址+1字节块地址取反+1字节块地址+1字节块地址取反
unsigned char code data2[4]  = {0x12,0,0,0};
unsigned char code DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
//unsigned char g_ucTempbuf[20];
unsigned char idata MLastSelectedSnr[4];
unsigned char idata RevBuffer[30];
//unsigned char data SerBuffer[20];
bit CmdValid;
unsigned char code ASCII_NUM[]={'0','1','2','3','4','5','6','7','8','9','A','B','C','D','E','F'};
unsigned char idata LastKeyA[6]={0xFF,0xFF,0xFF,0xFF,0xFF,0xFF};//NO.2卡
unsigned char idata NewKeyA[6]={0x19,0x84,0x07,0x15,0x76,0x14};//NO.2卡
unsigned char idata NewKey[16]={0x19,0x84,0x07,0x15,0x76,0x14,
                                0xff,0x07,0x80,0x69,
unsigned char idata Read_Data[16]={0x00};
//unsigned char idata RevBuffer[30];
//unsigned char idata MLastSelectedSnr[4];
unsigned char data OperationCard;
uchar data bWarn,bPass;
#define        REGCARD                        0xa1
#define        CONSUME                        0xa2
#define READCARD                0xa3
#define ADDMONEY                0xa4
void KeyScan(void)
                if(REGCARDBTN == 0)//注册
                                delay_10ms(1);
                                if(REGCARDBTN == 0 )
                                                OperationCard = REGCARD;
                                LCD_PutString(0,3,"注册:");
                if(CONSUMEBTN == 0)//消费
                                delay_10ms(1);
                                if(CONSUMEBTN == 0 )
                                                OperationCard = CONSUME;
                                LCD_PutString(0,3,"消费:      ");
                if(ADDMONEYBTN == 0)//充值
                                delay_10ms(1);
                                if(ADDMONEYBTN == 0 )
                                                OperationCard = ADDMONEY;
                                LCD_PutString(0,3,"充值:      ");
                if(READCARDBTN == 0)//读卡信息
                                delay_10ms(1);
                                if(READCARDBTN == 0 )
                                                OperationCard = READCARD;
                                LCD_PutString(0,3,"查询:      ");
void delay(void)
        uint i ;
        for(i=0;i++;i<100)
void ShortBeep(void)
        uint i;
        for(i=0;i<3;i++)
                SET_BEEP;
                delay_10ms(3);
                CLR_BEEP;
                delay();
void LongBeep(void)
        uint i;
        for(i=0;i<20;i++)
                SET_BEEP;
                delay_10ms(5);
                CLR_BEEP;
                delay();
void Warn(void)
  uchar data ii;
  for(ii=0;ii<3;ii++)
    SET_BEEP;//ShortBeep();如果是有源蜂鸣器就一句SET_BEEP就ok了
    delay_10ms(5);
    CLR_BEEP;
    delay_10ms(5);
void Pass(void)
  SET_BEEP;//LongBeep();如果是有源蜂鸣器就一句SET_BEEP就ok了
  delay_10ms(30);
  CLR_BEEP;
void CtrlProcess(void)
        //        unsigned char idata Write_First_Data[16];
          char string[]="           ";
                unsigned char idata Write_Consume_Data[16];
                signed long money_value;
          float f_money_value;
          unsigned char ii;
          char status;
          status=PcdRequest(PICC_REQIDL,&RevBuffer[0]);//寻天线区内未进入休眠状态的卡,返回卡片类型 2字节
          if(status!=MI_OK)
                          return;
                for(ii=0;ii<2;ii++)
                                string[2*ii]   = ASCII_NUM[(RevBuffer[ii]>>4)&0x0f];
                                string[2*ii+1] = ASCII_NUM[RevBuffer[ii]&0x0f];
                string[4] = '';
                LCD_PutString(3,1,string);//LCD显示卡类型
                status=PcdAnticoll(&RevBuffer[2]);//防冲撞,返回卡的序列号 4字节
                if(status!=MI_OK)
              return;
          memcpy(MLastSelectedSnr,&RevBuffer[2],4);//4字节序列号 放到MLastSelectedSnr
                for(ii=0;ii<4;ii++)
                                string[2*ii]   = ASCII_NUM[(MLastSelectedSnr[ii]>>4)&0x0f];
                                string[2*ii+1] = ASCII_NUM[MLastSelectedSnr[ii]&0x0f];
基于STM32单片机秒中断源和闹钟中断源的解决方案
