一.GUIConf.C文件的修改 修改emwin内存
* Defines
// Define the available number of bytes available for the GUI
#define USE_EXRAM 0//不支持外部SRAM
#define GUI_NUMBYTES (30*1024) //EMWIN 内存
#define GUI_BLOCKSIZE 0X80 //快大小
* Public code
* GUI_X_Config
* Purpose:
* Called during the initialization process in order to set up the
* available memory for the GUI.
void GUI_X_Config(void)
if(USE_EXRAM) //使用外部 RAM
//从外部 SRAM 中分配 GUI_NUMBYTES 字节的内存
U32 *aMemory = mymalloc(SRAMEX,GUI_NUMBYTES);
//为存储管理系统分配一个存储块
GUI_ALLOC_AssignMemory((U32 *)aMemory, GUI_NUMBYTES);
else //使用内部 RAM
//从内部 RAM 中分配 GUI_NUMBYTES 字节的内存
U32 *aMemory = mymalloc(SRAMIN,GUI_NUMBYTES);
//为存储管理系统分配一个存储块
//设置存储快的平均尺寸,该区越大,可用的存储快数量越少
GUI_ALLOC_SetAvBlockSize(GUI_BLOCKSIZE);
GUI_SetDefaultFont(GUI_FONT_6X8); //设置默认字体
// GUI_DEVICE_CreateAndLink(DISPLAY_DRIVER, COLOR_CONVERSION, 0, 0);
// LCD_SetSizeEx(0, 128, 64);
// LCD_SetVSizeEx(0, 128, 64);
二.修改GUIConf.H
1. #define GUI_OS (1) // Compile with multitasking support 这里使用FREERTOS
2. #define GUI_SUPPORT_TOUCH (0) // Support touchscreen dans单色屏不支持触摸
3.其余xuan选项默认
#define GUI_DEFAULT_FONT &GUI_Font6x8
#define GUI_NUM_LAYERS 10 // Maximum number of available layers
#define GUI_SUPPORT_MOUSE (1) /* Support a mouse */
#define GUI_WINSUPPORT (1) /* Use window manager */
#define GUI_SUPPORT_MEMDEV (1) /* Memory device package available */
#define GUI_SUPPORT_DEVICES (1) /* Enable use of device pointers */
三.GUIDRV_Template.c 修改
1.static void _SetPixelIndex(GUI_DEVICE * pDevice, int x, int y, int PixelIndex)函数的修改 添加单色屏打点函数如下
static void _SetPixelIndex(GUI_DEVICE * pDevice, int x, int y, int PixelIndex) {
// Convert logical into physical coordinates (Dep. on LCDConf.h)
#if (LCD_MIRROR_X == 1) || (LCD_MIRROR_Y == 1) || (LCD_SWAP_XY == 1)
int xPhys, yPhys;
xPhys = LOG2PHYS_X(x, y);
yPhys = LOG2PHYS_Y(x, y);
#else
#define xPhys x
#define yPhys y
#endif
GUI_USE_PARA(pDevice);
GUI_USE_PARA(x);
GUI_USE_PARA(y);
GUI_USE_PARA(PixelIndex);
// Write into hardware ... Adapt to your system
// TBD by customer...
LCD_DrawDots(xPhys, yPhys, PixelIndex);
#if (LCD_MIRROR_X == 0) && (LCD_MIRROR_Y == 0) && (LCD_SWAP_XY == 0)
#undef xPhys
#undef yPhys
#endif
2.static unsigned int _GetPixelIndex(GUI_DEVICE * pDevice, int x, int y) 添加 单色屏获取某一点的颜色的函数 如下
static unsigned int _GetPixelIndex(GUI_DEVICE * pDevice, int x, int y) {
unsigned int PixelIndex;
int xPhys, yPhys;
#else
#define xPhys x
#define yPhys y
#endif
GUI_USE_PARA(x);
GUI_USE_PARA(y);
PixelIndex = LCD_GetDots(xPhys, yPhys);
#undef xPhys
#undef yPhys
#endif
return PixelIndex;
3.static void * _GetDevData(GUI_DEVICE * pDevice, int Index)的修改 如下
static void * _GetDevData(GUI_DEVICE * pDevice, int Index) {
#if GUI_SUPPORT_MEMDEV
switch (Index) {
case LCD_DEVDATA_MEMDEV:
//return (void *)&GUI_MEMDEV_DEVICE_16; // TBD: Has to be adapted to the right memory device depending on the used color depth!
/* µ¥É«ÆÁ ·µ»Ø1 */
return (void *)&GUI_MEMDEV_DEVICE_1; // TBD: Has to be adapted to the right memory device depending on the used color depth! }
#else
GUI_USE_PARA(Index);
#endif
return NULL;
四.LCDConf_FlexColor_Template.c文件修改
1.修改lcd X Y的尺寸,固定调色板模式为单色
// Physical display size
#define XSIZE_PHYS 192 // To be adapted to x-screen size
#define YSIZE_PHYS 64 // To be adapted to y-screen size
#define VXSIZE_PHYS 192 //给定层虚拟区的X尺寸 (单位像素)
#define VYSIZE_PHYS 64 //给定层虚拟区的Y尺寸 (单位像素)
#define LCD_CONTROLLER UC1604
#define LCD_BITSPERPIXEL 1
#define LCD_USE_PARALLEL_16 0
// Color conversion
#define COLOR_CONVERSION GUICC_1 //单色屏
// Display driver
#define DISPLAY_DRIVER &GUIDRV_Template_API
2. LCD_X_Config()函数
* LCD_X_Config
* Function description:
* display driver configuration.
void LCD_X_Config(void) {
GUI_DEVICE * pDevice;
CONFIG_FLEXCOLOR Config = {0};
GUI_PORT_API PortAPI = {0};
// Set display driver and color conversion
//pDevice = GUI_DEVICE_CreateAndLink(GUIDRV_FLEXCOLOR, COLOR_CONVERSION, 0, 0);
GUI_DEVICE_CreateAndLink(GUIDRV_TEMPLATE, GUICC_1, 0, 0);//
// Display driver configuration, required for Lin-driver
LCD_SetSizeEx (0, XSIZE_PHYS , YSIZE_PHYS);
LCD_SetVSizeEx(0, VXSIZE_PHYS, VYSIZE_PHYS);
// // Orientation
// Config.Orientation = GUI_SWAP_XY | GUI_MIRROR_Y;
// GUIDRV_FlexColor_Config(pDevice, &Config);
// // Set controller and operation mode
// PortAPI.pfWrite16_A0 = LcdWriteReg;
// PortAPI.pfWrite16_A1 = LcdWriteData;
// PortAPI.pfWriteM16_A1 = LcdWriteDataMultiple;
// PortAPI.pfReadM16_A1 = LcdReadDataMultiple;
// GUIDRV_FlexColor_SetFunc(pDevice, &PortAPI, GUIDRV_FLEXCOLOR_F66708, GUIDRV_FLEXCOLOR_M16C0B16);
五.添加 GUI_X_FreeRTOS.C
因为使用的freertos 所以需要添加STemWinLibrary522OS目录下的GUI_X_FreeRTOS.C
六.添加stemwin库 STemWin522_CM4_OS_Keil.lib
我是用的STM32F407 支持操作系统 su 所以添加STemWin522_CM4_OS_Keil.lib
至此编译然后修改就可以了
