Function : TriangleWave_GPIO_Init
Description: 三角波对应的引脚初始化
Input : none
return : none
static void TriangleWave_GPIO_Init(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);//初始化引脚时钟
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5;//初始化DAC的CH1与CH2对应的引脚
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;//模拟输入
GPIO_Init(GPIOA, &GPIO_InitStructure);
Function : TriangleWave_TIM_Init
Description: 三脚波需要的定时器初始化
Input : none
return : none
static void TriangleWave_TIM_Init(void)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);//初始化TIM2的时钟
TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);//初始化时基结构体
TIM_TimeBaseStructure.TIM_Period = 100;//周期值为100
TIM_TimeBaseStructure.TIM_Prescaler = 0;//不预分频
TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;//时钟不分频
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//增计数
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);//初始化TIM2
TIM_SelectOutputTrigger(TIM2, TIM_TRGOSource_Update);//设置触发源为更新触发,更新周期一次,则触发一次DAC转换
TIM_Cmd(TIM2, ENABLE);//打开定时器
Function : TriangleWave_DAC_Init
Description: 三角波需要的DAC初始化
Input : none
return : none
static void TriangleWave_DAC_Init(void)
DAC_InitTypeDef DAC_InitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);//初始化DAC时钟
DAC_InitStructure.DAC_Trigger = DAC_Trigger_T2_TRGO;//DAC的触发源为TIM2
DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_Triangle;//输出三角波
DAC_InitStructure.DAC_LFSRUnmask_TriangleAmplitude = DAC_TriangleAmplitude_2047;//三角波的幅值对应的数字量为2047,即1.65V,频率为72M/100/2048/2=175Hz左右(与实际输出频率有一点出入)
DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Disable;//不适用DAC输出缓冲
DAC_Init(DAC_Channel_1, &DAC_InitStructure);//初始化DAC的CH1
DAC_InitStructure.DAC_LFSRUnmask_TriangleAmplitude = DAC_TriangleAmplitude_1023;//三角波的幅值对应的数字量为1023,即0.825V,频率为72M/100/1024/2=252Hz左右(与实价输出频率有一点出入)
DAC_Init(DAC_Channel_2, &DAC_InitStructure);//初始化DAC的CH2
DAC_Cmd(DAC_Channel_1, ENABLE);//打开DAC的CH1
DAC_Cmd(DAC_Channel_2, ENABLE);//打开DAC的CH2
DAC_SetDualChannelData(DAC_Align_12b_R, 0x00, 0x00);//设置DAC两个通道的数据右对齐,波谷对应的数字量风别为0,0
Function : TriangleWave_Init
Description: 三角波初始化
Input : none
return : none
void TriangleWave_Init(void)
TriangleWave_GPIO_Init();
TriangleWave_TIM_Init();
TriangleWave_DAC_Init();
#ifndef __TRIANGLEWAVE_H__
#define __TRIABGLEWAVE_H__
#include "stm32f10x.h"
void TriangleWave_Init(void);
#endif
Function : main
Description: main入口
Input : none
return : none
int main(void)
BSP_Init();
TriangleWave_Init();
PRINTF("\nmain() is running!\r\n");
while(1)
LED1_Toggle();
Delay_ms(1000);
