void ADC_ChannelSelect(uint32_t ADChannel)
// ADC_ChannelConfTypeDef sConfig;
sConfig.Channel = ADChannel;
sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;//ADC_RANK_CHANNEL_NUMBER;//1;//ADC_RANK_CHANNEL_NUMBER;
sConfig.SamplingTime = ADC_SAMPLETIME_13CYCLES_5;
if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK)
_Error_Handler(__FILE__, __LINE__);
HAL_StatusTypeDef HAL_ADC_ConfigChannel(ADC_HandleTypeDef* hadc, ADC_ChannelConfTypeDef* sConfig)
HAL_StatusTypeDef tmp_hal_status = HAL_OK;
__IO uint32_t wait_loop_index = 0U;
/* Check the parameters */
assert_param(IS_ADC_ALL_INSTANCE(hadc->Instance));
assert_param(IS_ADC_CHANNEL(sConfig->Channel));
assert_param(IS_ADC_RANK(sConfig->Rank));
if (! IS_ADC_SAMPLE_TIME(hadc->Init.SamplingTimeCommon))
assert_param(IS_ADC_SAMPLE_TIME(sConfig->SamplingTime));
/* Process locked */
__HAL_LOCK(hadc);
/* Parameters update conditioned to ADC state: */
/* Parameters that can be updated when ADC is disabled or enabled without */
/* conversion on going on regular group: */
/* - Channel number */
/* - Channel sampling time */
/* - Management of internal measurement channels: VrefInt/TempSensor/Vbat */
if (ADC_IS_CONVERSION_ONGOING_REGULAR(hadc) == RESET)
/* Configure channel: depending on rank setting, add it or remove it from */
/* ADC conversion sequencer. */
if (sConfig->Rank != ADC_RANK_NONE)
/* Regular sequence configuration */
/* Set the channel selection register from the selected channel */
if (sConfig->Channel == 0)
hadc->Instance->CHSELR = 0x01;
else if (sConfig->Channel == 4)
hadc->Instance->CHSELR = 0x10;
else if (sConfig->Channel == 6)
hadc->Instance->CHSELR = 0x40;
// hadc->Instance->CHSELR |= ADC_CHSELR_CHANNEL(sConfig->Channel);
/* Channel sampling time configuration */
/* Management of parameters "SamplingTimeCommon" and "SamplingTime" */
/* (obsolete): sampling time set in this function with */
/* parameter "SamplingTime" (obsolete) only if not already set into */
/* ADC initialization structure with parameter "SamplingTimeCommon". */
/* Modify sampling time if needed (not needed in case of reoccurrence */
/* for several channels programmed consecutively into the sequencer) */
if (sConfig->SamplingTime != ADC_GET_SAMPLINGTIME(hadc))
/* Clear the old sample time */
hadc->Instance->SMPR &= ~(ADC_SMPR_SMP);
/* Set the new sample time */
hadc->Instance->SMPR |= ADC_SMPR_SET(sConfig->SamplingTime);
/* Management of internal measurement channels: VrefInt/TempSensor/Vbat */
/* internal measurement paths enable: If internal channel selected, */
/* enable dedicated internal buffers and path. */
/* Note: these internal measurement paths can be disabled using */
/* HAL_ADC_DeInit() or removing the channel from sequencer with */
/* channel configuration parameter "Rank". */
if(ADC_IS_CHANNEL_INTERNAL(sConfig->Channel))
/* If Channel_16 is selected, enable Temp. sensor measurement path. */
/* If Channel_17 is selected, enable VREFINT measurement path. */
/* If Channel_18 is selected, enable VBAT measurement path. */
ADC->CCR |= ADC_CHANNEL_INTERNAL_PATH(sConfig->Channel);
/* If Temp. sensor is selected, wait for stabilization delay */
if (sConfig->Channel == ADC_CHANNEL_TEMPSENSOR)
/* Delay for temperature sensor stabilization time */
/* Compute number of CPU cycles to wait for */
wait_loop_index = (ADC_TEMPSENSOR_DELAY_US * (SystemCoreClock / 1000000U));
while(wait_loop_index != 0U)
wait_loop_index--;
else
/* Reset the channel selection register from the selected channel */
hadc->Instance->CHSELR &= ~ADC_CHSELR_CHANNEL(sConfig->Channel);
/* internal measurement paths disable: If internal channel selected, */
/* disable dedicated internal buffers and path. */
/* If Channel_16 is selected, disable Temp. sensor measurement path. */
/* If Channel_17 is selected, disable VREFINT measurement path. */
/* If Channel_18 is selected, disable VBAT measurement path. */
ADC->CCR &= ~ADC_CHANNEL_INTERNAL_PATH(sConfig->Channel);
/* If a conversion is on going on regular group, no update on regular */
/* channel could be done on neither of the channel configuration structure */
/* parameters. */
else
/* Update ADC state machine to error */
SET_BIT(hadc->State, HAL_ADC_STATE_ERROR_CONFIG);
tmp_hal_status = HAL_ERROR;
/* Process unlocked */
__HAL_UNLOCK(hadc);
/* Return function status */
return tmp_hal_status;
