#include "Msp430X14X.h"
#define CE BIT0
#define CS BIT1
#define PWR_UP BIT3
#define ADDR_INDEX 8
#define ADDR_COUNT 4
void CE_HI(void);
void CE_LO(void);
void CS_HI(void);
void CS_LO(void);
void PWR_UP_HI(void);
void PWR_UP_LO(void);
void Init_CLK(void);
void Port_Init(void);
void Init_SPI (void);
void Delay_us(unsigned long nValue);
void Delay_ms(unsigned long nValue);
void Init_RF2401(void);
char ReceivePacket(void);
void TransmitPacket(unsigned char nVal);
//定义串口操作变量
unsigned char UART0_TX_BUF[25]; // 串口 0 的发送缓冲区
int nTX0_Len;
char nTX0_Flag;
int nSend_TX0;
int nDR;
unsigned char rxConfig[15] = {
0x08, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x87, 0x65, 0x43, 0x21, 0x83, 0x6c, 0x05
unsigned char txConfig[15] = {
0x87, 0x65, 0x43, 0x21, 0x83, 0x6c, 0x04
void main(void)
char n;
WDTCTL = WDTPW + WDTHOLD; // 关闭看门狗
_DINT(); // 关闭中断
Init_CLK();
Port_Init();
Init_SPI();
_EINT(); // 打开中断
Init_RF2401();
while(1)
TransmitPacket(3);
Delay_ms(3);
n = ReceivePacket();
P1DIR = 0;
//设置CE为输出管脚
P1DIR |= BIT0;
//设置CS为输出管脚
P1DIR |= BIT1;
//设置PWR_UP为输出管脚
P1DIR |= BIT3;
//将中断寄存器清零
P1IE = 0;
P1IES = 0;
P1IFG = 0;
//管脚 P1.2 使能中断
P1IE |= BIT2;
//对应的管脚由低到高电平跳变使相应的标志置位
P1IES &= ~(BIT2);
//将P3口所有的管脚设置为一般I/O口
P3SEL = 0;
//P3.1 P3.2 P3.3被分配为SPI口
P3SEL = BIT3 + BIT2 + BIT1;
//P3.3作为输出管脚
P3DIR |= BIT3;
//P3.1作为输出管脚
P3DIR |= BIT1;
return;
//SPI0模块允许
ME1 |= USPIE0;
//将寄存器的内容清零
U0CTL = 0X00;
//数据为8比特,选择SPI模式,单片机为主机模式
U0CTL |= CHAR + SYNC + MM;
//将寄存器的内容清零
U0TCTL = 0X00;
// 时钟源为SMCLK,选择3线模式
U0TCTL = CKPH + SSEL1 + SSEL0 + STC;
//传输时钟为SMCLK / 800
UBR0_0 = 0X20;
UBR1_0 = 0X03;
//调整寄存器,没有调整
UMCTL_0 = 0X00; //The modulation control register is not used for SPI mode and should be set to 000h.
//发送中断允许
IE1 |= UTXIE0;
void CE_HI(void) //CE高电平
P1OUT |= BIT0;
return;
void CE_LO(void) //ce低
P1OUT &= ~(BIT0);
return;
void CS_HI(void)
P1OUT |= BIT1;
return;
void CS_LO(void)
P1OUT &= ~(BIT1);
return;
P1OUT |= BIT3;
return;
P1OUT &= ~(BIT3);
return;
void Init_CLK(void)
unsigned int i;
BCSCTL1 = 0X00; //将Basic Clock System Control Register 1寄存器的内容清零
//XT2震荡器开启
//LFTX1工作在低频模式
//ACLK的分频因子为1
do
IFG1 &= ~OFIFG; // 清除OSCFault标志
for (i = 0x20; i > 0; i--);
while ((IFG1 & OFIFG) == OFIFG); // 如果OSCFault =1
BCSCTL2 = 0X00; //将寄存器的内容清零
BCSCTL2 += SELM1; //MCLK的时钟源为TX2CLK,分频因子为1
BCSCTL2 += SELS; //SMCLK的时钟源为TX2CLK,分频因子为1
interrupt [UART0TX_VECTOR] void UART0_TX_ISR(void)
if(nTX0_Len != 0)
// 表示缓冲区里的数据没有发送完
nTX0_Flag = 0;
TXBUF0 = UART0_TX_BUF[nSend_TX0];
nSend_TX0 += 1;
if(nSend_TX0 >= nTX0_Len)
nSend_TX0 = 0;
nTX0_Len = 0;
nTX0_Flag = 1;
interrupt [PORT1_VECTOR] void DR_ISR(void)
if(P1IFG & BIT2)
nDR = 1;
// 清除中断标志位
P1IFG &= ~(BIT2);
void Delay_ms(unsigned long nValue)//毫秒为单位,8MHz为主时钟
unsigned long nCount;
int i;
unsigned long j;
nCount = 2667;
for(i = nValue;i > 0;i--)
for(j = nCount;j > 0;j--);
return;
void Delay_us(unsigned long nValue)//微秒为单位,8MHz为主时钟
int nCount;
int i;
int j;
nCount = 3;
return;
int i;
nDR = 0;
//激活nRF2401
PWR_UP_HI();
//延迟
Delay_ms(4);
CS_HI();
Delay_us(100);
CE_LO();
Delay_us(100); //进入配置模式
//发送配置信息
for(i = 0;i < 15;i++)
UART0_TX_BUF[i] = rxConfig[i];
nTX0_Len = 15;
// 设置中断标志,进入发送中断程序
IFG1 |= UTXIFG0;
unsigned char i;
CS_HI();
Delay_us(10);
TXBUF0 = 0x05;
CS_LO();
Delay_us(300);
CE_HI();
Delay_us(10);
for(i = 0;i < ADDR_COUNT;i++)
UART0_TX_BUF[i] = rxConfig[ADDR_INDEX + i];
UART0_TX_BUF[i] = nVal;
nTX0_Len = ADDR_COUNT + 1;
// 设置中断标志,进入发送中断程序
IFG1 |= UTXIFG0;
CE_LO();
//延迟
Delay_us(300);
char nVal;
CS_HI();
Delay_us(10);
TXBUF0 = 0x04;
CS_LO();
Delay_us(300);
CE_HI();
while(1)
if(nDR == 1)
break;
TXBUF0 = 0x0;
while ((IFG1 & UTXIFG0) == 0) ;
nVal = RXBUF0;
CE_LO();
//延迟
Delay_us(300);
return nVal;
