电路介绍:
1.此项目采用51单片机实现音乐盒的功能,同时电路中采用模拟示波器,可以实时查看波形的变动。
2.通过一个可调电阻实现音频信号的音量大小
3.基于8欧姆/1w的喇叭作为音频输出部件
proteus仿真原理图:
源代码:
#include
#include
#define uchar unsigned char
#define uint unsigned int
sbit SPK = P2^7;
uchar tone_h; //高音
uchar tone_l; //低音
uint note = 1; //音符
uchar beat; //节拍
uchar code chuzhi[3][16]={ //音调对应的计数初值
0xff,0xff,//占0位
0xf8,0x8c,//低1
0xf9,0x5b,// 2
0xfa,0x15,// 3
0xfa,0x67,// 4
0xfb,0x04,// 5
0xfb,0x90,// 6
0xfc,0x0c,//低7
0xff,0xff,//占0位
0xfc,0x44,//中1
0xfc,0xac,// 2
0xfd,0x09,// 3
0xfd,0x34,// 4
0xfd,0x82,// 5
0xfd,0xc8,// 6
0xfe,0x06,//中7
0xff,0xff,//占0位
0xfe,0x22,//高1
0xfe,0x56,// 2
0xfe,0x85,// 3
0xfe,0x9a,// 4
0xfe,0xc1,// 5
0xfe,0xe4,// 6
0xff,0x03 //高7
//****** 测试曲谱 ****** 个位:音调 ,十位:低中高音 对应 0 1 2,千百位:节拍 1~16
uint code test2[] = { 120, //曲速 暂时未用到
401,402,403,404,405,406,407,
611,612,613,614,615,616,617,
821,822,823,824,825,826,827,
0xffff //0xffff表示结尾
//****** 生日快乐 ******
uint code test[] = { 120,
205,205,406,405,411,807,
205,205,406,405,412,811,
205,205,415,413,411,407,406,
314,114,413,411,413,812,
305,105,406,405,411,807,
305,105,406,405,412,811,
305,105,415,413,411,
407,406,314,114,413,411,412,811,410,
0xffff
void delayms(uint ms) /*ms 等于1时,延时1ms 等于2时,延时2ms,以此类推*/
uchar a,b,c; //+3
while(ms--)
for(c=1;c>0;c--) // 1+2 = 3
for(b=142;b>0;b--) // 1*( 1+142*2)) = 285
for(a=2;a>0;a--); // 142*(1+2*2) = 710
void delay125ms(uint pai) //延时 ?*125ms 即?个节拍
uchar a,b,c;
while(pai--)
for(c=239;c>0;c--)
for(b=104;b>0;b--)
for(a=1;a>0;a--);
void timer0() interrupt 1
TH0 = tone_h;
TL0 = tone_l;
SPK = ~SPK;
void timer_init()
EA = 1;
ET0 = 1;
PT0 = 1;
TMOD = 0x11;
TH0 = 255;
TL0 = 255;
void main()
timer_init();
note = 1;
while(1)
if(test[note] == 0xffff)
note = 1;
if(test[note]%10 != 0) //音调不为0 【音调为0时表示不发声,但有节拍】
tone_h = TH0 = chuzhi[test[note]%100/10][(test[note]%10)*2 ]; //音调高位 【二维数组 第1维表示低中高音,第二维表示音调】
tone_l = TL0 = chuzhi[test[note]%100/10][(test[note]%10)*2 + 1]; //音调低位
TR0 = 1;
delay125ms(test[note]/100); //节拍
TR0 = 0;
delayms(30);
note++; //下一个音符
