程序的头文件
#include
#include
#include
sbit CS=P1^0;
sbit SCK=P1^2;
sbit SID=P1^1;
sbit Key=P1^3;
sbit DQ = P2 ^ 7; //定义端口DQ
unsigned char code AC_TABLE[]={
0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,
0x90,0x91,0x92,0x93,0x94,0x95,0x96,0x97,
0x88,0x89,0x8a,0x8b,0x8c,0x8d,0x8e,0x8f,
0x98,0x99,0x9a,0x9b,0x9c,0x9d,0x9e,0x9f,
void delay(unsigned int x)
while(x--);
void SendByte(unsigned char Dbyte)
unsigned char i;
for(i=0;i<8;i++)
SCK = 0;
Dbyte=Dbyte<<1;
SID = CY;
SCK = 1;
SCK = 0;
unsigned char ReceiveByte(void)
unsigned char i,temp1,temp2;
temp1=temp2=0;
for(i=0;i<8;i++)
temp1=temp1<<1;
SCK = 0;
SCK = 1;
SCK = 0;
if(SID) temp1++;
for(i=0;i<8;i++)
temp2=temp2<<1;
SCK = 0;
SCK = 1;
SCK = 0;
if(SID) temp2++;
return ((0xf0&temp1)+(0x0f&temp2));
void CheckBusy( void )
do SendByte(0xfc); //11111,RW(1),RS(0),0
while(0x80&ReceiveByte());
void WriteCommand( unsigned char Cbyte )
CS = 1;
CheckBusy();
SendByte(0xf8); //11111,RW(0),RS(0),0
SendByte(0xf0&Cbyte);
SendByte(0xf0&Cbyte<<4);
CS = 0;
void WriteData( unsigned char Dbyte )
CS = 1;
CheckBusy();
SendByte(0xfa); //11111,RW(0),RS(1),0
SendByte(0xf0&Dbyte);
SendByte(0xf0&Dbyte<<4);
CS = 0;
unsigned char ReadData( void )
CheckBusy();
SendByte(0xfe); //11111,RW(1),RS(1),0
return ReceiveByte();
void LcmInit( void )
WriteCommand(0x30);
WriteCommand(0x03);
WriteCommand(0x0C);
WriteCommand(0x01);
WriteCommand(0x06);
void LcmClearTXT( void )
unsigned char i;
WriteCommand(0x30);
WriteCommand(0x80);
for(i=0;i<64;i++)
WriteData(0x20);
void LcmClearBMP( void )
unsigned char i,j;
WriteCommand(0x34);
WriteCommand(0x36);
for(i=0;i<32;i++)
WriteCommand(0x80|i);
WriteCommand(0x80);
for(j=0;j<32;j++)
WriteData(0);
void PutStr(unsigned char row,unsigned char col,unsigned char *puts)
WriteCommand(0x30);
WriteCommand(AC_TABLE[8*row+col]);
while(*puts != '/0')
if(col==8)
col=0;
row++;
if(row==4) row=0;
WriteData(*puts);
puts++;
WriteData(*puts);
puts++;
col++;
Init_DS18B20(void)//初始化ds1820
unsigned char x = 0;
DQ = 1; //DQ复位
delay(8); //稍做延时
DQ = 0; //单片机将DQ拉低
delay(80); //精确延时 大于 480us
//Delay(400); //精确延时 大于 480us
DQ = 1; //拉高总线
delay(14);
x = DQ; //稍做延时后 如果x=0则初始化成功 x=1则初始化失败
delay(20);
ReadOneChar(void)//读一个字节
unsigned char i = 0;
unsigned char dat = 0;
for (i = 8; i > 0; i--)
DQ = 0; // 给脉冲信号
dat >>= 1;
DQ = 1; // 给脉冲信号
if(DQ)
dat |= 0x80;
delay(15);
return (dat);
WriteOneChar(unsigned char dat)//写一个字节
DQ = 0;
DQ = dat&0x01;
delay(5);
DQ = 1;
dat>>=1;
Read_Disp_Temperature(void)//读取并显示温度
unsigned int a = 0, b = 0, c = 0, t = 0;
float tt = 0;
Init_DS18B20();
WriteOneChar(0xCC); // 跳过读序号列号的操作
WriteOneChar(0x44); // 启动温度转换
Init_DS18B20();
WriteOneChar(0xCC); //跳过读序号列号的操作
WriteOneChar(0xBE);
a = ReadOneChar(); //读取温度寄存器
b = ReadOneChar();
t = b;
t <<= 8;
t = t | a;
tt = t * 0.0625;
t = tt * 10 + 0.5; //放大10倍输出并四舍五入
a = t / 100; //十位
b = t / 10 - a * 10; //个位
c = t - a * 100 - b * 10; //小数位
// LcmInit();
// LcmClearTXT();
//LcmClearBMP();
WriteCommand(0x30);
PutStr(0,0,"当前温度为");
delay(100);
WriteCommand(AC_TABLE[8*1+0]);
WriteData(a+0x30);
WriteCommand(AC_TABLE[8*1+1]);
WriteData(b+0x30);
PutStr(1,2,". ");
WriteCommand(AC_TABLE[8*1+3]);
WriteData(c+0x30);
PutStr(1,4,"度");
delay(1000);
