#include
void IO_Init();
void InitADC();
unsigned int GetAD(char channel);
void light_Compare(int templight);
int counter=0; //中断计数器参数,单位秒
* main.c
int main(void)
IO_Init(); //IO初始化
InitADC(); //初始化ADC模块
int voice = 0; //缓存声音响度
int light = 0; //缓存环境亮度
WDTCTL = WDT_ADLY_1000; //设置中断定时1s
SFRIE1 |= WDTIE; //使能WDT中断 WDTIE=(0x0001)/* WDT Interrupt Enable */
_EINT(); // 使能全局中断
while(1){
voice = GetAD(0); //读取声音缓存
while(voice>3000){ //声音与阈值比较
counter=0; //定时器置零
do{
light = GetAD(1); //亮度读取
light_Compare(light);
if(voice>3000){
break;
if(counter >=10) //判断计数时间,如果大于20s,关闭LED,并退出
P1OUT &= ~BIT5;
P8OUT &= ~BIT1;
P3OUT &= ~BIT7;
P7OUT &= ~BIT4;
P6OUT &= ~BIT3;
P6OUT &= ~BIT4;
P3OUT &= ~BIT5;
break;
}while(counter<10);
void light_Compare(int templight){ //LED发亮的个数与光敏电阻测出亮度成反比
P2OUT |= BIT5; //2.5置高
P2OUT &= ~BIT4; //2.4置低
P1OUT |= BIT5; //打开Nsleep,开大LED灯
if(templight >=700)
P8OUT |= BIT1;
else
P8OUT &= ~BIT1;
if(templight >= 1200)
P3OUT |= BIT7;
else
P3OUT &= ~BIT7;
if(templight >= 1500)
P7OUT |= BIT4;
else
P7OUT &= ~BIT4;
if(templight >= 2000)
P6OUT |= BIT3;
else
P6OUT &= ~BIT3;
if(templight >= 2500)
P6OUT |= BIT4;
else
P6OUT &= ~BIT4;
if(templight >= 3000)
P3OUT |= BIT5;
else
P3OUT &= ~BIT5;
void IO_Init(){ //六盏灯初始化,并全置零
P1DIR|= BIT0; //六盏灯初始化,并全置零
P8DIR|= BIT1;
P3DIR|= BIT7;
P7DIR|= BIT4;
P6DIR|= BIT3;
P6DIR|= BIT4;
P3DIR|= BIT5;
P8OUT&=~BIT1;
P3OUT&=~BIT7;
P7OUT&=~BIT4;
P6OUT&=~BIT3;
P6OUT&=~BIT4;
P3OUT&=~BIT5;
P2DIR|= BIT4; //2.4,2.5初始化
P2DIR|= BIT5;
P2OUT|= BIT5;
P2OUT&= ~BIT4;
P1DIR|= BIT5; //大LED灯的驱动的电路开关方向
#pragma vector= WDT_VECTOR
__interrupt void watchdog_timer (void)
counter ++; //计时器加一
P1OUT^=BIT0; //信号灯
unsigned int temp = 0; //设置变量
ADC12CTL0 |= ADC12SC; //开始采样转换
temp= ADC12MEM0; //把结果赋给变量
switch (channel)
case 0:temp= ADC12MEM0; break; //选择通道0,P6.0
case 1:temp= ADC12MEM1; break; //选择通道1,P6.1
case 2:temp= ADC12MEM2; break; //选择通道2,P6.2
case 3:temp= ADC12MEM3; break; //选择通道3,P6.3
case 4:temp= ADC12MEM4; break; //选择通道4,P6.4
case 5:temp= ADC12MEM5; break; //选择通道5,P6.5 连接拨码电位器
case 6:temp= ADC12MEM6; break; //选择通道6,P6.6
case 12:temp= ADC12MEM12; break; //选择通道12,P7.0
default: ;break;
return temp;
void InitADC()
ADC12CTL0 |= ADC12MSC; //自动循环采样转换
ADC12CTL0 |= ADC12ON; //启动ADC12模块
ADC12CTL1 |= ADC12CONSEQ_3 ; //选择序列通道多次循环采样转换
ADC12CTL1 |= ADC12SHP; //采样保持模式
ADC12CTL1 |= ADC12CSTARTADD_0;
ADC12MCTL0 |=ADC12INCH_0; //通道选择
ADC12MCTL1 |=ADC12INCH_1;
ADC12MCTL2 |=ADC12INCH_2;
ADC12MCTL3 |=ADC12INCH_3;
ADC12MCTL4 |=ADC12INCH_4;
ADC12MCTL5 |=ADC12INCH_5+ADC12EOS;
ADC12CTL0 |= ADC12ENC;
关键字:MSP430F5529 智能灯『本文转载自网络,版权归原作者所有,如有侵权请联系删除』
