header
单片机 > 单片机程序设计 > 详情
0802LCD 4位显示程序 PIC单片机C语言程序
发布时间:2020-06-17 发布时间:
#include
#include
//#include"head.h"
#define uchar unsigned char
#define uint unsigned int
#pragma config FOSC = XT        // Oscillator Selection bits (XT oscillator)
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = ON       // Power-up Timer Enable bit (PWRT enabled)
#pragma config BOREN = OFF      // Brown-out Reset Enable bit (BOR disabled)
#pragma config LVP = ON        // Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit (RB3 is digital I/O, HV on MCLR must be used for programming)
#pragma config CPD = OFF        // Data EEPROM Memory Code Protection bit (Data EEPROM code protection off)
#pragma config WRT = OFF        // Flash Program Memory Write Enable bits (Write protection off; all program memory may be written to by EECON control)
#pragma config CP = OFF         // Flash Program Memory Code Protection bit (Code protection off)
//char tab[]="0123456789";
void LCD_write_cmd(uchar command);
void LCD_write_command(uchar command);
void LCD_en_write(void);
void LCD_set_xy( unsigned char x, unsigned char y );
void LCD_write_string(unsigned char X,unsigned char Y,unsigned char *s);
void LCD_write_data(unsigned char data);
void delay_nus(unsigned int n);
void delay_nms(unsigned int n);
#define RS RC2
#define EN RC3
#define DB7 RC7
#define DB6 RC6
#define DB5 RC5
#define DB4 RC4
#define LCD_DATA_PORT PORTC
#define LCD_DATA_TRIS TRISC
    函数说明
void LCD_init()
    TRISD=0x00; //数据口方向为输出
    PORTD=0x00;
    TRISC=0x00; //数据口方向为输出
    PORTC=0x00;//设置EN、RS/数据为输出
    LCD_write_cmd(0x30);//4位的指令
    delay_nms(5);
    delay_nus(200);
    delay_nms(1);
    LCD_write_cmd(0x20);
    LCD_write_cmd(0x20); //4位显示
    LCD_write_cmd(0x80);
    LCD_write_cmd(0x00); //显示开 游标、闪烁不显示
    LCD_write_cmd(0x00); //清屏
    LCD_write_cmd(0x01);
    LCD_write_cmd(0x00); //两行 5*7
    LCD_write_cmd(0xc0);
void LCD_write_cmd(uchar command) //写指令
    delay_nus(10);
    RS=0;
    EN=0;//使能清零
    LCD_DATA_PORT&=0x0f; //清除端口
    delay_nus(2);
    EN=1;
    LCD_DATA_PORT |= (command & 0xf0);//高4位不用改
    delay_nus(2);
    EN=0;
void LCD_write_command(uchar command) //写指令
    LCD_write_cmd(command);
    LCD_write_cmd(command<<4);
void LCD_write_data(unsigned char data) //写数据
    delay_nus(10);
    RS=1;
    EN=0;//使能清零
    EN=1;
    LCD_DATA_PORT |= (data & 0xf0);//高4位不用改
    delay_nus(2);
    EN=0;
    delay_nus(2);
    LCD_DATA_PORT&=0x0F; //清低四位
    EN=1;
    LCD_DATA_PORT |= ((data << 4) & 0xf0);//发送低4位
    delay_nus(2);
    EN=0;
void LCD_write_string(unsigned char X,unsigned char Y,unsigned char *s) //列x=0~15,行y=0,1
    LCD_set_xy( X, Y ); //写地址
    while (*s) // 写显示字符
        LCD_write_data( *s );
        s ++;
void LCD_set_xy( unsigned char x, unsigned char y )  //写地址函数
    unsigned char address;
    if (y == 0) address = 0x80 + x;
    else        address = 0xc0 + x;
    LCD_write_command( address);
void delay_nms(unsigned int n) //N ms延时函数
    uint a,b;
    for(a=n;a>0;a--)
        for(b=80;b>0;b--);
void delay_nus(unsigned int n) //N us延时函数
    unsigned int i;
    for (i=0;i
void main()
     LCD_init();
//    LCD_write_command(0x0d); //光标开
     while(1)
         RD0=1;
         delay_nms(1000);
         RD0=0;
         delay_nms(1000);
        LCD_write_string(0,0,"ceshiLCD");
        LCD_write_string(0,1,"hahahaha");
        delay_nms(2000);
关键字:0802LCD  显示程序  PIC单片机
Keil(C51)介绍.下载.安装与注册
footer
