单片机 > 单片机程序设计 > 详情
SD卡接口程序(AVR)
发布时间:2024-10-23 发布时间:
SD卡接口程序/******************************************/
/*           SD Code for   M32L             */
/*       By   pasyong        */
/*       2006-4         */
/*       Base ICC6.31A             */
#include
#include
#include "1011.h"
#define uchar unsigned char
#define uint unsigned int
#define MMC_CS_PIN     BIT(4)    //PORTB.4
#define MMC_PORT       PORTB
 uchar reading=0,a=0,pointer=0;
void sd_port_init()
MMC_PORT =MMC_CS_PIN;
uchar BUFFER[512];                   //扇区缓冲区
uint i=0;
void delay_nus(uint n)
 unsigned char  b;
  for (b = 1; b   ;
//Send a Command to MMC/SD-Card
//Return: the second byte of response register of MMC/SD-Card
uchar SD_Write_Command(uchar cmd,unsigned long arg)
   uchar tmp;
   uchar retry=0;
   //MMC_PORT =MMC_CS_PIN;       //SD卡关闭
   //send 8 CLOCk Impulse
   Write_Byte_SPI(0xFF);
   //set MMC_Chip_Select to low (MMC/SD-Card active)
  MMC_PORT&=~MMC_CS_PIN;       //SD卡使能
   Write_Byte_SPI(cmd 0x40);   //送头命令
   Write_Byte_SPI(arg>>24);
   Write_Byte_SPI(arg>>16);     //send 6 Byte Command to MMC/SD-Card
   Write_Byte_SPI(arg>>8);
   Write_Byte_SPI(arg&0xff);
   Write_Byte_SPI(0x95);       //仅仅对RESET有效的CRC效验码
   //get 8 bit response
   //Read_Byte_MMC(); //read the first byte,ignore it.
   do
   {  //Only last 8 bit is used here.Read it out.
      tmp = Read_Byte_SPI();
      retry++;
   while((tmp==0xff)&&(retry<100));  //当没有收到有效的命令的时候
   if(reading==0)
   MMC_PORT =MMC_CS_PIN;            //MMC_CS_PIN=1;
   else MMC_PORT&=~MMC_CS_PIN;      //MMC_CS_PIN=0;
   return(tmp);
//SD卡初始化(SPI-MODE)
uchar SD_Init(void)
   uchar retry,temp;
   uchar i;
  delay_nus(250);  //Wait MMC/SD ready...
   for (i=0;i<0x0f;i++)
      Write_Byte_SPI(0xff); //send 74 clock at least!!!
   //Send Command CMD0 to MMC/SD Card
   retry=0;
   do
   { //retry 200 times to send CMD0 command
     temp=SD_Write_Command(0,0);
     retry++;
     if(retry==100)
      ;//CMD0 Error!
   while(temp!=1);
   //Send Command CMD1 to MMC/SD-Card
   retry=0;
   do
   { //retry 100 times to send CMD1 command
     temp=SD_Write_Command(1,0);
     retry++;
     if(retry==100)
   while(temp!=0);
   retry=0;
    SD_Write_Command(16,512);     //设置一次读写BLOCK的长度为512个字节
   MMC_PORT =MMC_CS_PIN;   //MMC_CS_PIN=1;  //set MMC_Chip_Select to high
   return(0); //All commands have been taken.
//从SD卡读一个扇区  Return 0 if no Error.
uchar SD_Read_Block(unsigned long address)
   uchar temp=0;uint i=0;
   reading=1;
   temp=SD_Write_Command(17,address);     //读出RESPONSE
   while (Read_Byte_SPI()!= 0xfe)
   {;}  //直到读取到了数据的开始头0XFE,才继续
   for(i=0; i<512; i++)
 BUFFER[i]=Read_Byte_SPI();
   Read_Byte_SPI();//CRC - Byte
   reading=0;
   MMC_PORT =MMC_CS_PIN;        //关闭SD卡
   return(temp);
51单片机仿真实例
