硬件平台为微雪BLE400的(将原来的16mhz晶振改为32mhz。两个旁电容改为22pf)
以nRF51_SDK_10.0.0_dc26b5eexamplesble_peripheralble_app_uart项目为例
在main.c中进行修改
#if defined( USB_SYSTEM_CLOCK_32MHZ)
#define DEVICE_NAME "Nordic_UART_32mhz" /**< Name of device. Will be included in the advertising data. */
#else
#define DEVICE_NAME "Nordic_UART" /**< Name of device. Will be included in the advertising data. */
#endif//USB_SYSTEM_CLOCK_32MHZ
#if defined (USB_SYSTEM_CLOCK_32MHZ)
/**@brief Function for Set the external high frequency clock source to 32 MHz .
static void setClock( void )
// Set the external high frequency clock source to 32 MHz
NRF_CLOCK->XTALFREQ = 0xFFFFFF00;
// Start the external high frequency crystal
NRF_CLOCK->EVENTS_HFCLKSTARTED = 0;
NRF_CLOCK->TASKS_HFCLKSTART = 1;
// Wait for the external oscillator to start up
while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0) {}
/**@brief Application main function.
int main(void)
uint32_t err_code;
bool erase_bonds;
uint8_t start_string[] = START_STRING;
setClock();
// Initialize.
APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
uart_init();
buttons_leds_init(&erase_bonds);
ble_stack_init();
gap_params_init();
services_init();
advertising_init();
conn_params_init();
printf("%s",start_string);
err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
APP_ERROR_CHECK(err_code);
// Enter main loop.
for (;;)
power_manage();
修改system_nrf51.C
#define __SYSTEM_CLOCK (32000000UL) /*!< nRF51 devices use a fixed System Clock Frequency of 32MHz */
#else
#define __SYSTEM_CLOCK (16000000UL) /*!< nRF51 devices use a fixed System Clock Frequency of 16MHz */
后面的测试的步骤和16mhz步骤相同。
