就这么几步,
第一步: 检查STM8s.h头文件配置
* @brief In the following line adjust the value of External High Speed oscillator (HSE)
used in your application
Tip: To avoid modifying this file each time you need to use different HSE, you
can define the HSE value in your toolchain compiler preprocessor.
#if !defined HSE_Value
#if defined (STM8S208) || defined (STM8S207) || defined (STM8S007) || defined (STM8AF52Ax) ||
defined (STM8AF62Ax) || defined (STM8AF622x)
#define HSE_VALUE ((uint32_t)24000000) /* Value of the External oscillator in Hz*/
#else
#define HSE_VALUE ((uint32_t)16000000) /* Value of the External oscillator in Hz*/
#endif /* STM8S208 || STM8S207 || STM8S007 || STM8AF62Ax || STM8AF52Ax || STM8AF622x */
#endif /* HSE_Value */
第二步:代码配置外部时钟
CLK_DeInit();
CLK_HSICmd(DISABLE); //禁止内部高速晶振
CLK_ClockSwitchCmd(ENABLE); //使能时钟切换
CLK_ClockSwitchConfig(CLK_SWITCHMODE_AUTO, CLK_SOURCE_HSE, DISABLE, CLK_CURRENTCLOCKSTATE_DISABLE); //时钟切换(自动切换模式,切换到外部时钟,禁止切换中断,当前钟状态为)
CLK_SYSCLKConfig(CLK_PRESCALER_CPUDIV1); //配置CPU的分频器
CLK_ClockSecuritySystemEnable();
CLK_HSECmd(ENABLE);
第三步:非常重要!!检查Options配置位打开WaitState,等待时钟启动稳定。
这一步在生产烧录时不能忘了,多少有点蛋疼。。。
最后,16M到24M超频性能并不是2->3的提升,,,
详见这位大牛的分析:
/zixunimg/eeworldimg/bbs.elecfans.com/jishu_805711_1_1.html
