--十进制计数器(count10.vhd)--
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY COUNT10 IS
PORT(CLK,CLR,ENA:IN STD_LOGIC;
QOUT:OUT STD_LOGIC_VECTOR(3 DOWNTO 0)
END COUNT10;
ARCHITECTURE BEHAV PROCESS.html" target="_blank" title="PROCESS">PROCESS(CLK,CLR,ENA)
VARIABLE TMP:INTEGER RANGE 0 TO 10;
BEGIN
IF CLR='1' THEN
TMP:=0;
ELSIF CLK'EVENT AND CLK='1' THEN
IF ENA='1' THEN
TMP:=TMP+1;
IF TMP=10 THEN
TMP:=0;
END IF;
END IF;
END IF;
QOUT<=CONV_STD_LOGIC_VECTOR(TMP,4);
END process;
END BEHAV;
--扫描信号发生器(count8.vhd)--
LIBRARY IEEE;
ENTITY COUNT8 IS
port(CLK:IN STD_LOGIC;
QOUT:OUT STD_LOGIC_VECTOR(2 DOWNTO 0)
END COUNT8;
ARCHITECTURE BEHAV THEN
TMP<=TMP+1;
IF TMP=8 THEN
TMP<=0;
END IF;
END IF;
QOUT<=CONV_STD_LOGIC_VECTOR(TMP,3);
END PROCESS.html" target="_blank" title="PROCESS">PROCESS;
END BEHAV;
--七段译码器(deLED.vhd)--
library ieee;
use ieee.std_logic_1164.all;
entity deled is
port(
datain:in std_logic_vector(3 downto 0);
qout:out std_logic_vector(6 downto 0)
end deled;
architecture func;
elsif datain= "0001" then qout<="0110000";
elsif datain= "0010" then qout<="1101101";
elsif datain= "0011" then qout<="1111001";
elsif datain= "0100" then qout<="0110011";
elsif datain= "0101" then qout<="1011011";
elsif datain= "0110" then qout<="1011111";
elsif datain= "0111" then qout<="1110000";
elsif datain= "1000" then qout<="1111111";
elsif datain= "1001" then qout<="1111011";
else null;
end if;
end process;
end func;
--===========顶层文件描述=============
--scan.vhd--
LIBRARY IEEE;
ENTITY SCAN IS
PORT(CLKK,CLK_SEL,CLRR,ENAA:IN STD_LOGIC;
SELOUT:OUT STD_LOGIC_VECTOR(2 DOWNTO 0);
END SCAN;
ARCHITECTURE BEHAV 发生器的调用;
PORT(CLK:IN STD_LOGIC;
END COMPONENT;
--定义第三个元件--
COMPONENT DELED --定义第三个元件:七段通用译码器的调用;
port(
END COMPONENT;
--定义信号--
SIGNAL S1:STD_LOGIC_VECTOR(3 DOWNTO 0);
--元件例化体开始--
BEGIN
U1:COUNT10 PORT MAP(CLKK,CLRR,ENAA,S1); --例化第一个元件;
U2:DELED PORT MAP(S1,QOUT); --例化第二个元件;
U3:COUNT8 PORT MAP(CLK_SEL,SELOUT); --例化第三个元件;
END BEHAV;
--程序结束××--
