通过宏定义设置段选位选
#include
typedef unsigned char uchar;
#define wei_h P5OUT |= BIT5
#define wei_l P5OUT &= BIT5
#define duan_l P6OUT &= ~BIT6
#define duan_h P6OUT |= BIT6
uchar table[16] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
uchar num = 0;
void main( void )
P1DIR = 0XFF;P1OUT = 0XFF;
P2DIR = 0XFF;P2OUT = 0XFF;
P3DIR = 0XFF;P3OUT = 0XFF;
P4DIR = 0XFF;P4OUT = 0XFF;
P5DIR = 0XFF;P5OUT = 0XFF;
P6DIR = 0XFF;P6OUT = 0XFF;
// Stop watchdog timer to prevent time out reset
WDTCTL = WDT_ADLY_1000;
IE1 |= WDTIE;
P6DIR |= BIT2;P6OUT |= BIT2;
P4OUT = 0X00;
_BIS_SR(LPM3_bits + GIE);
#pragma vector = WDT_VECTOR
__interrupt void watchdog_timer(void)
P4OUT = table[num];
duan_h;
duan_l;
P4OUT = 0x00;
wei_h;
wei_l;
num++;
if(num == 16)
num = 0;
