# include
typedef unsigned char uint8;
typedef unsigned int uint16;
uint8 num = 0;
void delay(uint16 n) //延时函数
while(n--);
void UART_init(void)
SCON = 0x50; //串口控制寄存器在方式1条件下,M1 = 1;M0 = 0 REN = 1,打开允许串口接收数
TMOD = 0x20; //将定时器1置为自动重装模式。即方式2
TH1 = 0xFD; //TH1 = TL1 = 256 - 11059200/(12 * 32 * 9600) (12为12个时钟周期)
TL1 = 0xFD;
TR1 = 1; //允许串口接收数据
void UART_send_byte(uint8 dat)
SBUF = dat;
while(!TI); //发送停止位时由硬件置1必须软件清零
TI = 0;
main()
UART_init(); //串口初始化
while(1)
UART_send_byte(num++);
delay(20000);
