#include#include #define uchar unsigned char #define uint unsigned int #define TimeDelay 60000 void delay(uint n); void Flash0a(void); void Flash0b(void); void Flash1a(void); void Flash1b(void); void Flash2a(void); void Flash2b(void); void Flash3a(void); void Flash3b(void); /************************************************************ *Function: 主函数 *parameter: *Return: *Modify: *************************************************************/ void main(void) { while(1) { Flash1b(); Flash1a(); delay(TimeDelay); delay(TimeDelay); Flash0b(); Flash0a(); Flash2b(); Flash2a(); Flash1b(); Flash1a(); Flash3b(); Flash3a(); } } /************************************************************ *Function: 延时 *parameter: *Return: *Modify: *************************************************************/ void delay(uint n) { while(n!=0) { n--; } } void Flash0a(void) { uchar i; uchar Temp; Temp = 0x80; for(i=0;i<8;i++) { P0 = ~Temp; delay(TimeDelay); Temp = Temp >> 1; } P0 = 0xff; } void Flash0b(void) { uchar i; uchar Temp; Temp = 0x80; for(i=0;i<8;i++) { P0 = Temp; delay(TimeDelay); Temp = Temp >> 1; } P0 = 0; } void Flash1a(void) { uchar i; uchar Temp; P1 = 1; Temp = 0x80; for(i=0;i<8;i++) { P1 = ~Temp; delay(TimeDelay); Temp = Temp >> 1; } P1 = 0xff; } void Flash1b(void) { uchar i; uchar Temp; P1 = 1; Temp = 0x80; for(i=0;i<8;i++) { P1 = Temp; delay(TimeDelay); Temp = Temp >> 1; } P1 = 0; } void Flash2a(void) { uchar i; uchar Temp; P2 = 1; Temp = 0x80; for(i=0;i<8;i++) { P2 = ~Temp; delay(TimeDelay); Temp = Temp >> 1; } P2 = 0xff; } void Flash2b(void) { uchar i; uchar Temp; P2 = 1; Temp = 0x80; for(i=0;i<8;i++) { P2 = Temp; delay(TimeDelay); Temp = Temp >> 1; } P2 = 0; } void Flash3a(void) { uchar i; uchar Temp; P3 = 1; Temp = 0x80; for(i=0;i<8;i++) { P3 = ~Temp; delay(TimeDelay); Temp = Temp >> 1; } P3 = 0xff; } void Flash3b(void) { uchar i; uchar Temp; P3 = 1; Temp = 0x80; for(i=0;i<8;i++) { P3 = Temp; delay(TimeDelay); Temp = Temp >> 1; } P3 = 0; }
