本时钟有些功能还未完全实现,仅实现一部分功能,年月日星期功能还未实现 还可以加上整点报时和断电记忆的功能
#include
#define uchar unsigned char
sbit rd=P2^6;
sbit wr=P2^5;
sbit lcde=P2^7;
sbit k1=P1^0;
sbit k2=P1^1;
sbit k4=P1^3;
sbit k8=P1^7;
uchar code table1[]=" 2011-10-01 SAT";
uchar code table2[]="00:00:00";
uchar t,s1num;
char shi,fen,miao;
void delay(uchar z) //延迟zms函数
uchar x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void write_com(uchar com) //液晶写指令操作
rd=0;
wr=0;
delay(5);
lcde=1;
P0=com;
lcde=0;
void write_date(uchar date) //液晶写数据操作
rd=1;
wr=0;
delay(5);
lcde=1;
P0=date;
lcde=0;
void write_sfm(uchar add,uchar date) //更新时分秒
uchar shi,ge;
shi=date/10;
ge=date;
write_com(0x80+0x40+add);
write_date(0x30+shi);
write_date(0x30+ge);
void init() //初始化函数
uchar i;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80+0x00);
for(i=0;i<15;i++)
write_date(table1[i]);
write_com(0x80+0x46);
for(i=0;i<8;i++)
write_date(table2[i]);
TMOD=0x01; //定时器工作方式
TH0=(65536-50000)/256; //设定定时器初值
TL0=(65536-50000)%6; //12M晶振时ms数为
EA=1;
ET0=1;
TR0=1;
void keyscan() //键盘扫描函数
if(k1==0) //按下k1键确定调时分秒
delay(5);
if(k1==0)
s1num++;
while(!k1)
delay(5);
while(!k1);
if(s1num==1)
TR0=0; //暂停计时器
write_com(0x80+0x4d); //光标在秒的位置闪烁
write_com(0x0f);
if(s1num==2) //光标在分的位置
TR0=0;
write_com(0x80+0x4a);
write_com(0x0f);
if(s1num==3)
TR0=0;
write_com(0x80+0x47);
write_com(0x0f);
if(s1num==4) //按下第四下时接着走时
s1num=0;
write_com(0x0c);
TR0=1;
if(s1num!=0)
if(s1num==1)
if(k2==0) //按k2键秒加
delay(5);
if(k2==0)
while(!k2);
delay(5);
while(!k2);
miao++;
if(miao==60)
miao=0;
write_sfm(0x0c,miao);
if(s1num==2)
if(k2==0) //分加
delay(5);
if(k2==0)
while(!k2);
delay(5);
while(!k2);
fen++;
if(fen==60)
fen=0;
write_sfm(0x09,fen);
if(s1num==3)
if(k2==0) //时加
delay(5);
if(k2==0)
while(!k2);
delay(5);
while(!k2);
shi++;
if(shi==24)
shi=0;
write_sfm(0x06,shi);
if(k4==0) //判断k3是否被按下
delay(5);
if(k4==0)
while(!k4);
delay(5);
while(!k4);
if(s1num==1)
miao--; //秒减
if(miao==-1)
miao=59;
if(s1num==2)
fen--; //分减
if(fen==-1)
fen=59;
if(s1num==3)
shi--; //时减
if(shi==-1)
shi=23;
if(k8==0) // 按下k8退出调时
delay(5);
if(k8==0)
while(!k8);
delay(5);
while(!k8);
s1num=0;
write_com(0x0c);
TR0=1;
void main()
init();
while(1)
keyscan();
void timer0() interrupt 1 //中断服务程序
TL0=(65536-50000)%6; //重新设定定时器初值
t++;
if(t==20) //定时器中断次为秒
t=0;
miao++;
if(miao==60)
miao=0;
fen++;
if(fen==60)
fen=0;
shi++;
if(shi==24)
shi=0;
write_sfm(0x06,shi); //显示时
write_sfm(0x09,fen); //显示分
write_sfm(0x0c,miao); //显示秒
