19264液晶是一种比12864大一点点的单色液晶,这里我给大家介绍一下用stc系列单片机驱动他显示汉字的原理
效果图
由于网页空间篇幅有限本文只列出了部分代码,完整版本请从 http://www.51hei.com/f/19264.rar 处下载
#include#include #define uchar unsigned char #define uint unsigned int uint ee; uchar f; sbit lcd_cs3=P1^0;//片选信号右 低有效 sbit lcd_cs2=P1^1;//片选信号中 低有效 sbit lcd_cs1=P1^2;//片选信号左 低有效 sbit lcd_e =P1^3;//使能信号 sbit lcd_rw =P1^4;//读写选择 sbit lcd_rs =P1^5;//数据命令选择端 H数据 L命令 sbit lcd_rst=P1^6;// 液晶复位引脚 低有效 低的话 就一直复位了 //P2八位数据线 uchar code cc[]={ /*---------------小----------------*/ 0xFF,0xFF,0xFF,0xFF,0xBF,0xDF,0xEF,0xE7,0xF3,0xF9,0xFB,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFE,0xFE,0xFE,0xF6,0xF2,0xE6,0xEE,0xDE,0xBE,0x7E,0xFE,0xFE,0xFE,0xFA,0xFD, /*---------------鹏----------------*/ 0xEF,0xDF,0x83,0x9B,0xAB,0xAB,0xB3,0xBF,0x81,0xFD,0xFD,0x05,0xFD,0xEB,0xF7,0xFF, 0xFF,0x88,0xAA,0xAA,0x88,0xAA,0xAA,0xAA,0x88,0xAA,0xAA,0xAA,0xAA,0x46,0xEC,0xFF, /*---------------工----------------*/ 0xFF,0xFF,0xFF,0xF7,0xF7,0xF7,0xF7,0x07,0xFB,0xFB,0xFB,0xFB,0xFF,0xFF,0xFF,0xFF, 0xFF,0xEF,0xEF,0xEF,0xEF,0xEF,0xEF,0xF0,0xF7,0xF7,0xF7,0xF7,0xF7,0xF7,0xFF,0xFF, /*---------------作----------------*/ 0x7F,0xBF,0xDF,0x07,0xF8,0xBF,0xCF,0xE3,0x0C,0x6F,0x6F,0xB7,0xB7,0xF7,0xFF,0xFF, 0xFF,0xFF,0xFF,0x80,0xFF,0xFF,0xFF,0xFF,0x80,0xFB,0xFB,0xFD,0xFD,0xFD,0xFF,0xFF, /*---------------室----------------*/ 0xFF,0xFF,0xE7,0xD7,0x57,0x97,0xD6,0xD9,0x6B,0x6B,0x2B,0x73,0xFB,0xFF,0xFF,0xFF, 0xFF,0xBF,0xBF,0xB6,0xB6,0xB6,0xB6,0xC0,0xDB,0xDB,0xDB,0xDE,0xDF,0xFF,0xFF,0xFF, /*---------------开----------------*/ 0xFF,0x7F,0x7F,0x7B,0x7B,0x03,0xBD,0xBD,0xBD,0x01,0xBD,0xBD,0xBF,0xBF,0xFF,0xFF, 0xFF,0xBF,0xDF,0xEF,0xF3,0xFC,0xFF,0xFF,0xFF,0x80,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, /*---------------发----------------*/ 0xFF,0xFF,0xDF,0xC1,0xDF,0x1F,0x60,0x6F,0x6F,0xAD,0x2B,0xEF,0xEF,0xFF,0xFF,0xFF, 0xDF,0xEF,0xB7,0xBB,0xDC,0xDD,0xEB,0xF7,0xF3,0xED,0xDE,0xBF,0xBF,0xBF,0xFF,0xFF, /*-------------------------------*/ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, }; uchar code dd[]={ /*---------------小----------------*/ 0x00,0x00,0x00,0x00,0x40,0x20,0x10,0x18,0x0C,0x06,0x04,0x00,0x00,0x00,0x00,0x00, 0x01,0x01,0x01,0x01,0x09,0x0D,0x19,0x11,0x21,0x41,0x81,0x01,0x01,0x01,0x05,0x02, /*---------------鹏----------------*/ 0x10,0x20,0x7C,0x64,0x54,0x54,0x4C,0x40,0x7E,0x02,0x02,0xFA,0x02,0x14,0x08,0x00, 0x00,0x77,0x55,0x55,0x77,0x55,0x55,0x55,0x77,0x55,0x55,0x55,0x55,0xB9,0x13,0x00, /*---------------工----------------*/ 0x00,0x00,0x00,0x08,0x08,0x08,0x08,0xF8,0x04,0x04,0x04,0x04,0x00,0x00,0x00,0x00, 0x00,0x10,0x10,0x10,0x10,0x10,0x10,0x0F,0x08,0x08,0x08,0x08,0x08,0x08,0x00,0x00, /*---------------作----------------*/ 0x80,0x40,0x20,0xF8,0x07,0x40,0x30,0x1C,0xF3,0x90,0x90,0x48,0x48,0x08,0x00,0x00, 0x00,0x00,0x00,0x7F,0x00,0x00,0x00,0x00,0x7F,0x04,0x04,0x02,0x02,0x02,0x00,0x00, /*---------------室----------------*/ 0x00,0x00,0x18,0x28,0xA8,0x68,0x29,0x26,0x94,0x94,0xD4,0x8C,0x04,0x00,0x00,0x00, 0x00,0x40,0x40,0x49,0x49,0x49,0x49,0x3F,0x24,0x24,0x24,0x21,0x20,0x00,0x00,0x00, /*---------------开----------------*/ 0x00,0x80,0x80,0x84,0x84,0xFC,0x42,0x42,0x42,0xFE,0x42,0x42,0x40,0x40,0x00,0x00, 0x00,0x40,0x20,0x10,0x0C,0x03,0x00,0x00,0x00,0x7F,0x00,0x00,0x00,0x00,0x00,0x00, /*---------------发----------------*/ 0x00,0x00,0x20,0x3E,0x20,0xE0,0x9F,0x90,0x90,0x52,0xD4,0x10,0x10,0x00,0x00,0x00, 0x20,0x10,0x48,0x44,0x23,0x22,0x14,0x08,0x0C,0x12,0x21,0x40,0x40,0x40,0x00,0x00, }; void lcd_init(); void wrile_com(uchar com); void wrile_data(uchar dat); void QPCZ(uchar TT,rg) ; //液晶屏 清屏操作 void XYZ(uchar q1,q2,q3); void delay(uchar d0); void main() { while(1) {lcd_init(); QPCZ(0x11,0xff); delay(250);delay(250);delay(250);delay(250);delay(250);delay(250); delay(250);delay(250);delay(250);delay(250);delay(250);delay(250); QPCZ(0x00,0x00); XYZ(0xc0,0xb8,0x60); lcd_cs1=0; lcd_cs2=1; lcd_cs3=1; for(f=0;f<224;f++) { if(f==64) {lcd_cs1=1; lcd_cs2=0; lcd_cs3=1; } if(f==192) {lcd_cs1=1; lcd_cs2=1; lcd_cs3=0; } switch(f) // 括号里面的语句和 case比较 {case 16:XYZ(0xc0,0xb9,0x60); //比较一样 break; case 32:XYZ(0xc0,0xb8,0x70); //比较一样 break; case 48:XYZ(0xc0,0xb9,0x70); //比较一样 break; case 64:XYZ(0xc0,0xb8,0x40); //比较一样 break; case 80:XYZ(0xc0,0xb9,0x40); //比较一样 break; case 96:XYZ(0xc0,0xb8,0x50); //比较一样 break; case 112:XYZ(0xc0,0xb9,0x50); //比较一样 break; case 128:XYZ(0xc0,0xb8,0x60); //比较一样 break; case 144:XYZ(0xc0,0xb9,0x60); //比较一样 break; case 160:XYZ(0xc0,0xb8,0x70); //比较一样 break; case 176:XYZ(0xc0,0xb9,0x70); //比较一样 break; case 192:XYZ(0xc0,0xb8,0x40); //比较一样 break; case 208:XYZ(0xc0,0xb9,0x40); //比较一样 break; } // delay(250);delay(250);delay(250);delay(250);delay(250);delay(250); wrile_data(cc[f]); } XYZ(0xc0,0xb8,0x60); lcd_cs1=0; lcd_cs2=1; lcd_cs3=1; XYZ(0xc0,0xb8,0x60); lcd_cs1=0; lcd_cs2=1; lcd_cs3=1; for(f=0;f<224;f++) { if(f==64) {lcd_cs1=1; lcd_cs2=0; lcd_cs3=1; } if(f==192) {lcd_cs1=1; lcd_cs2=1; lcd_cs3=0; } switch(f) // 括号里面的语句和 case比较 {case 16:XYZ(0xc0,0xb9,0x60); //比较一样 break; case 32:XYZ(0xc0,0xb8,0x70); //比较一样 break; case 48:XYZ(0xc0,0xb9,0x70); //比较一样 break; case 64:XYZ(0xc0,0xb8,0x40); //比较一样 break; case 80:XYZ(0xc0,0xb9,0x40); //比较一样 break; case 96:XYZ(0xc0,0xb8,0x50); //比较一样 break; case 112:XYZ(0xc0,0xb9,0x50); //比较一样 break; case 128:XYZ(0xc0,0xb8,0x60); //比较一样 break; case 144:XYZ(0xc0,0xb9,0x60); //比较一样 break; case 160:XYZ(0xc0,0xb8,0x70); //比较一样 break; case 176:XYZ(0xc0,0xb9,0x70); //比较一样 break; case 192:XYZ(0xc0,0xb8,0x40); //比较一样 break; case 208:XYZ(0xc0,0xb9,0x40); //比较一样 break; } //delay(250);delay(250);delay(250);delay(250);delay(250);delay(250); wrile_data(dd[f]); } XYZ(0xc0,0xba,0x60); lcd_cs1=0; lcd_cs2=1; lcd_cs3=1; XYZ(0xc0,0xba,0x60); lcd_cs1=0; lcd_cs2=1; lcd_cs3=1; for(f=0;f<224;f++) { if(f==64) {lcd_cs1=1; lcd_cs2=0; lcd_cs3=1; } if(f==192) {lcd_cs1=1; lcd_cs2=1; lcd_cs3=0; } switch(f) // 括号里面的语句和 case比较 {case 16:XYZ(0xc0,0xbb,0x60); //比较一样 break; case 32:XYZ(0xc0,0xba,0x70); //比较一样 break; case 48:XYZ(0xc0,0xbb,0x70); //比较一样 break; case 64:XYZ(0xc0,0xba,0x40); //比较一样 break; case 80:XYZ(0xc0,0xbb,0x40); //比较一样 break; case 96:XYZ(0xc0,0xba,0x50); //比较一样 break; case 112:XYZ(0xc0,0xbb,0x50); //比较一样 break; case 128:XYZ(0xc0,0xba,0x60); //比较一样 break; case 144:XYZ(0xc0,0xbb,0x60); //比较一样 break; case 160:XYZ(0xc0,0xba,0x70); //比较一样 break; case 176:XYZ(0xc0,0xbb,0x70); //比较一样 break; case 192:XYZ(0xc0,0xba,0x40); //比较一样 break; case 208:XYZ(0xc0,0xbb,0x40); //比较一样 break; } // delay(250);delay(250);delay(250);delay(250);delay(250); delay(250); wrile_data(cc[f]); } QPCZ(0xff,0xff); delay(250);delay(250);delay(250); } } void lcd_init() { lcd_rst=0; delay(50); lcd_rst=1; delay(255);//等待复位 lcd_cs1=0; lcd_cs2=0; lcd_cs3=0; wrile_com(0x3f); } void wrile_com(uchar com) { lcd_e=0; // lcd_rw=0;//读写选择 写 lcd_rs=0;//数据命令 命令 lcd_e=1; // P2=com; _nop_(); lcd_e=0; delay(5); } void wrile_data(uchar dat) { lcd_e=0; // lcd_rw=0;//读写选择 写 lcd_rs=1;//数据命令 命令 lcd_e=1; // P2=dat; _nop_(); lcd_e=0; delay(5); } void XYZ(uchar q1,q2,q3) { wrile_com(q1);//显示起始行 wrile_com(q2);//页面地址 wrile_com(q3);//列地址设置 } void QPCZ(uchar TT,rg) //液晶屏 清屏操作 {uchar qw,qe,er; lcd_cs1=0; lcd_cs2=0; lcd_cs3=0; er=0xb8; XYZ(0xc0,0xb8,0x40); for(qw=0;qw<8;qw++) { wrile_com(er);//页面地址 for(qe=0;qe<64;qe++) { wrile_data(TT);delay(rg); } wrile_com(er++);//页面地址 } } void delay(uchar d0) {uchar d1,d2; for(d1=d0;d1>0;d1--) for(d2=110;d2>0;d2--); }
