嵌入式 > 技术百科 > 详情
STM8 TIM2 定时器的问题
发布时间:2020-12-15 发布时间:
所用的芯片为STM8S103F3P6,编译器为IAR  ,程序代码如下:
// #include "iostm8s105c6.h"
#include "iostm8s103F3.h"      // Very importtant
void DelayMS(unsigned int ms)
  unsigned char i;
  while(ms != 0)
    for(i=0;i<250;i++)
    for(i=0;i<75;i++)
    ms--;
////GPIO口初始化
void GPIO_init(void)
  PA_DDR = 0x08;  // 配置PD端口的方向寄存器PD0输出
  PA_CR1 = 0x08;  // 设置PD0为推挽输出
  PA_CR2 = 0x00;
  PC_DDR = 0x18;  // 配置PD端口的方向寄存器PD0输出
  PC_CR1 = 0x18;  // 设置PD0为推挽输出
  PC_CR2 = 0x00;
void ADC_init(void)
  CLK_PCKENR2 =0x08;           // Enable the f(MASTER) Clock to ADC;
  ADC_CR1 = 0x40;             // ADC Clock: SPSEL[2:0]=100; fADC = f(MASTER)/8=1M; Single conversion mode ; ADON=0;
  ADC_CR2 = 0x20;             // Data Left alignment ;Scan mode disabled
  ADC_CSR = 0x03;             // Select Channel AIN3; EOC interrupt disabled  ; (ECO:End of conversion)
  ADC_TDRL = 0x03;            // Channel AIN3 Schmitt trigger disabled
void TIM2_init(void)
    CLK_PCKENR1=0x20;           //  Enable the f(MASTER) Clock to Time2;
    TIM2_PSCR  =0x03;          //  Time2 Clock Frequency:1M ;  prescaler :8; Fck_psc/ 2^(PSC[3:0]); 0011; //Fck_psc=f(MASTER)=8M;
    TIM2_EGR = 0x01;           // Re-initializes the counter and generates an update of the registers
    TIM2_CNTRH = 0x0;          // Counter Starting Value;
    TIM2_CNTRL = 0x0;
   TIM2_ARRH = 0xC3;          // TIM2_ARRH  Must be Loaded Value First ,then to TIM2_ARRL; Auto-reload// register high (TIMx_ARRH);
   TIM2_ARRL = 0x50;         //  0xC350 = 50000 ;Time = 1us x 50000 = 50 ms;
   TIM2_IER   =0x01;          //  Time2 Update interrupt Enabled;
   TIM2_CR1  =0x01;         // Counter enable;
void CLK_init(void)
  CLK_SWR = 0xE1;               //  0xE1: HSI selected as master clock source ; f(HSI)RC =16M ;
  CLK_CKDIVR = 0x09;           //  f(HSI)RC =16M ; f(HSI)=[f(HSI)RC]/2 = 8M = f(MASTER) ; f(CPU)=f(MASTER)/2= 4M ;
int i=0;
unsigned int ADdata;
unsigned int ADlow;
main()
  GPIO_init();
  CLK_init();
  TIM2_init();
  ADC_init();
  asm("rim");           //Enable Global interrupt;
  while(1)
       PC_ODR = 0x00;
    // PA_ODR = 0x00;
       PA_ODR = 0x08;
      // DelayMS(100);
    if(i%20==0)
      //PC_ODR = 0x00;
      //PA_ODR = 0x08;
      //DelayMS(200);
      PA_ODR = 0x00;
      DelayMS(50);
        // i=0;
        //PC_ODR = 0x08;
       // DelayMS(100);
       // PC_ODR = 0x10;
       // DelayMS(100);
    if(i==40)
     //  ADC_CR1 |=0x01;   //启动转换
       //while((ADC_CSR&0x80) == 0); // 等待ADC结束
      //PC_ODR = 0x00;
        PA_ODR = 0x00;
        DelayMS(300);
     // PA_ODR = 0x08;
      //DelayMS(100);
        i=0;
        PC_ODR = 0x08;
         DelayMS(30);
     // PC_ODR = 0x10;
     // DelayMS(30);
    //for(i=0;i<10;i++)
      //PC_ODR = 0x08;
     // DelayMS(30);
     /// PC_ODR = 0x10;
    //  DelayMS(30);
#pragma vector=TIM2_OVR_UIF_vector
 __interrupt void TIM2_OVR_UIF(void)
    TIM2_SR1 = 0x00;          //     Clear  UIF: Update interrupt flag
    i++;
   if(i>200)  i=0;
上述代码为仍在调试的代码,定时器可以正常工作了,AD还在调试。现对定时器调试关键点说明如下:
1、头文件.// #include "iostm8s105c6.h" 要改为      #include "iostm8s103F3.h"      // Very importtant
2、STM8S .h 文件中的#define STM8S105     注释掉,将#define STM8S103  定义,去掉注释。
馈通滤波器的运用指南
