编译过程:
环境设置:
sudo groupadd arm sudo useradd arm -g arm sudo passwd arm #设置密码 su - arm #切换帐户 export CLFS_HOST="$(echo $MACHTYPE | sed "s/$(echo $MACHTYPE | cut -d- -f2)/cross/")" export CLFS_TARGET="arm-at91-linux" echo export CLFS_HOST=""${CLFS_HOST}"" >> ~/.bashrc echo export CLFS_TARGET=""${CLFS_TARGET}"" >> ~/.bashrc
内核头文件(2.6.35):
make mrproper make headers_check make INSTALL_HDR_PATH=dest headers_install mkdir -p $CLFS/usr/include cp -rv dest/include/* $CLFS/usr/include
Binutils(2.20):
mkdir -v ../binutils-build cd ../binutils-build ../binutils-2.20.1/configure --prefix=${CLFS}/cross-tools --host=${CLFS_HOST} --target=${CLFS_TARGET} --with-sysroot=${CLFS} --disable-nls --enable-shared --disable-multilib ln -sv /usr/bin/ar $CLFS/cross-tools/bin/${CLFS_HOST)-ar make configure-host make make install cp -v ../binutils-2.17/include/libiberty.h ${CLFS}/usr/include
Glibc-Headers(2.11):
tar -xf ../glibc-ports-2.11.tar.bz2 mv glibc-ports-2.11 ports #重要,没它就会说the arm is unsupport mkdir -v ../glibc-build cd ../glibc-build echo "libc_cv_forced_unwind=yes" > config.cache echo "libc_cv_c_cleanup=yes" >> config.cache echo "libc_cv_arm_tls=yes" >> config.cache echo "libc_cv_arm32_tls=yes" >> config.cache echo "libc_cv_arm_machine=yes" > config.cache echo "libc_cv_mlong_double_128=yes" >> config.cache echo "libc_cv_mlong_double_128ibm=yes" >> config.cache echo "install_root=${CLFS}" > configparms CC=gcc ../glibc-2.11/configure --prefix=/usr --host=${CLFS_TARGET} --build=${CLFS_HOST} --with-headers=${CLFS}/usr/include --cache-file=config.cache make install-headers install -dv ${CLFS}/usr/include/bits cp -v bits/stdio_lim.h ${CLFS}/usr/include/bits touch ${CLFS}/usr/include/gnu/stubs.h
Gcc-4.5.1 Pass1:
patch -Np1 -i ../gcc-4.5.1-startfiles_fix-1.patch tar -xf ../gmp-5.0.1.tar.bz2 tar -xf ../mpc-0.8.2.tar.gz tar -xf ../mpfr-3.0.0.tar.bz2 mv gmp-5.0.1 gmp mv mpc-0.8.2.tar.gz mpc mv mpfr-3.0.0 mpfr mkdir -v ../gcc-build cd ../gcc-build ../gcc-4.5.1/configure --prefix=${CLFS}/cross-tools --host=${CLFS_HOST} --target=${CLFS_TARGET} --disable-multilib --with-sysroot=${CLFS} --disable-nls --disable-shared --enable-languages=c --with-gmp-include=$(pwd)/gmp --with-gmp-lib=$(pwd)/gmp/.libs #相当重要! make all-gcc make install-gcc ln -sv $CLFS/cross-tools/bin/arm-at91-linux-gcc FS/cross-tools/bin/arm-at91-linux-cc rm $CLFS/cross-tools/bin/i486-cross-linux-gnu-ar ln -vs libgcc.a `$CLFS_TARGET-gcc -print-libgcc-file-name | sed 's/libgcc/&_eh/'` #相当重要,没有这个符号连接就别想编译glibc
Glibc 2.11 Pass2
tar -xf ../glibc-ports-2.11.tar.bz2 mv glibc-ports-2.11 ports mkdir -v ../glibc-build cd ../glibc-build echo "libc_cv_forced_unwind=yes" > config.cache echo "libc_cv_c_cleanup=yes" >> config.cache echo "install_root=${CLFS}" > configparms BUILD_CC="gcc" CC="${CLFS_TARGET}-gcc" AR="${CLFS_TARGET}-ar" RANLIB="${CLFS_TARGET}-ranlib" ../glibc-2.4/configure --prefix=/usr --libexecdir=/usr/lib/glibc --host=${CLFS_TARGET} --build=${CLFS_HOST} --disable-profile --enable-add-ons --with-tls --enable-kernel=2.6.0 --with-__thread --with-binutils=${CLFS}/cross-tools/bin --with-headers=${CLFS}/usr/include --cache-file=config.cache make make install cat > ${CLFS}/etc/nsswitch.conf << "EOF" # Begin /etc/nsswitch.conf passwd: files group: files shadow: files hosts: files dns networks: files protocols: files services: files ethers: files rpc: files # End /etc/nsswitch.conf EOF TZDIR="${CLFS}/usr/share/zoneinfo" ${CLFS}/usr/bin/tzselect cp -v --remove-destination ${CLFS}/usr/share/zoneinfo/[xxx] ${CLFS}/etc/localtime cat > ${CLFS}/etc/ld.so.conf << "EOF" # Begin /etc/ld.so.conf /usr/local/lib /opt/lib # End /etc/ld.so.conf EOF
GCC-Pass3
patch -Np1 -i ../gcc-4.5.1-startfiles_fix-1.patch tar -xf ../gmp-5.0.1.tar.bz2 tar -xf ../mpc-0.8.2.tar.gz tar -xf ../mpfr-3.0.0.tar.bz2 mv gmp-5.0.1 gmp mv mpc-0.8.2.tar.gz mpc mv mpfr-3.0.0 mpfr mkdir -v ../gcc-build cd ../gcc-build ../gcc-4.5.1/configure --prefix=${CLFS}/cross-tools --host=${CLFS_HOST} --target=${CLFS_TARGET} --disable-multilib --with-sysroot=${CLFS} --disable-nls --enable-shared --enable-languages=c,c++ --enable-__cxa_atexit --enable-c99 --enable-long-long --enable-threads=posix make all-gcc make install-gcc #重要! make make install ln -vs libgcc.a `$LFS_TGT-gcc -print-libgcc-file-name | sed 's/libgcc/&_eh/'` #相当重要,没有这个符号连接就别想编译glibc
如果一步一步按着这个作的,那么告诉你:工具链完成了!
