1.首先一定要保证硬件正确,包括接线,工具正常;
2.其次基本配置一定要正确,例如此次配置485的时候,可以实现DMA发送,却不能实现接收。而同样的串口参数配置使用中断方式和232接口都能实现发送接收,个人判断是是接收DMA部分配置有问题,结果卡了很久才发现是基本的管脚配置有误。485的三根引脚要配置成推挽输出,复用,复用模式。
3.最后,还是要多总结经验,多看看源代码。
硬件如下:
其实本质上还是串口通信,只不过多了一个开关控制(485-DIR),用来控制是发送数据还是接收数据,因此是半双工模式。
配置流程:时钟使能,引脚配置,串口配置(波特率,校验位等),DMA配置(需要配置串口中断)。
void USART2_UART_Init(uint32_t bound)
__HAL_RCC_GPIOD_CLK_ENABLE();
__HAL_RCC_USART2_CLK_ENABLE();
GPIO_InitTypeDef GPIO_Init2;
GPIO_Init2.Pin = GPIO_PIN_4; //485_RTS
GPIO_Init2.Mode =GPIO_MODE_OUTPUT_PP;
GPIO_Init2.Pull = GPIO_NOPULL;
GPIO_Init2.Speed = GPIO_SPEED_FREQ_HIGH;
GPIO_Init2.Alternate = GPIO_AF7_USART2;
HAL_GPIO_Init(GPIOD,&GPIO_Init2);
GPIO_Init2.Pin = GPIO_PIN_5; //485 TX config
GPIO_Init2.Mode = GPIO_MODE_AF_PP;
GPIO_Init2.Pin = GPIO_PIN_6; //485 RX config
HAL_GPIO_Init(GPIOD,&GPIO_Init2); //USART2_GPIO配置
__HAL_RCC_DMA1_CLK_ENABLE();
huart2_dma_rx.Instance=DMA1_Stream5; //USART2RX_ DMA1数据流5,通道4
huart2_dma_rx.Init.Channel=DMA_CHANNEL_4;
huart2_dma_rx.Init.Direction=DMA_PERIPH_TO_MEMORY;
huart2_dma_rx.Init.PeriphInc=DMA_PINC_DISABLE;
huart2_dma_rx.Init.MemInc=DMA_MINC_ENABLE;
huart2_dma_rx.Init.MemDataAlignment= DMA_MDATAALIGN_BYTE;
huart2_dma_rx.Init.PeriphDataAlignment=DMA_PDATAALIGN_BYTE;
huart2_dma_rx.Init.Mode=DMA_NORMAL;
huart2_dma_rx.Init.Priority=DMA_PRIORITY_LOW;
huart2_dma_rx.Init.FIFOMode=DMA_FIFOMODE_DISABLE;
HAL_DMA_Init(&huart2_dma_rx);
huart2_dma_tx.Instance=DMA1_Stream6; //USART2TX_ DMA1数据流6,通道4
huart2_dma_tx.Init.Channel=DMA_CHANNEL_4;
huart2_dma_tx.Init.Direction=DMA_MEMORY_TO_PERIPH;
huart2_dma_tx.Init.PeriphInc=DMA_PINC_DISABLE;
huart2_dma_tx.Init.MemInc=DMA_MINC_ENABLE;
huart2_dma_tx.Init.MemDataAlignment= DMA_MDATAALIGN_BYTE;
huart2_dma_tx.Init.PeriphDataAlignment=DMA_PDATAALIGN_BYTE;
huart2_dma_tx.Init.Mode=DMA_NORMAL;
huart2_dma_tx.Init.Priority=DMA_PRIORITY_HIGH;
huart2_dma_tx.Init.FIFOMode=DMA_FIFOMODE_DISABLE;
HAL_DMA_Init(&huart2_dma_tx);
__HAL_LINKDMA(&huart2,hdmarx,huart2_dma_rx); //关联USART2和DMA
__HAL_LINKDMA(&huart2,hdmatx,huart2_dma_tx);
HAL_NVIC_SetPriority(DMA1_Stream5_IRQn,1,1); //配置DMA通道的中断并使能
HAL_NVIC_EnableIRQ(DMA1_Stream5_IRQn);
HAL_NVIC_SetPriority(DMA1_Stream6_IRQn,1,1);
HAL_NVIC_EnableIRQ(DMA1_Stream6_IRQn);
huart2.Instance =USART2;
huart2.Init.BaudRate =bound;
huart2.Init.WordLength =UART_WORDLENGTH_8B;
huart2.Init.StopBits =UART_STOPBITS_1;
huart2.Init.Parity =UART_PARITY_NONE;
huart2.Init.Mode = UART_MODE_TX_RX;
huart2.Init.HwFlowCtl=UART_HWCONTROL_NONE;
huart2.Init.OverSampling = UART_OVERSAMPLING_16;
huart2.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
huart2.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
HAL_UART_Init(&huart2); //串口2配置
HAL_NVIC_SetPriority(USART2_IRQn,1,1); //配置USART2的中断并使能
HAL_NVIC_EnableIRQ(USART2_IRQn);
RS485_R;
void delay485(uint32_t num)
while(num--);
void RS485_Send_data(uint8_t *pdata,uint16_t data_size)
RS485_T;
delay485(4);
while(HAL_UART_GetState(&huart2)!=HAL_UART_STATE_READY);
HAL_UART_Transmit_DMA(&huart2,pdata,data_size);
RS485_R;
delay485(4);
void RS485_Receive_data(uint8_t *pdata,uint16_t data_size)
HAL_UART_Receive_DMA(&huart2,pdata,data_size);
主程序测试:
int main(void)
HAL_Init();
Sysclk_config();
USART2_UART_Init(38400);
RS485_Send_data(buffer1,data_length);
HAL_UART_Receive_DMA(&huart2,buffer2,data_length); //打开DMA接收
while(1)
if(flag==1)
HAL_Delay(200);
RS485_Send_data(buffer2,data_length);
flag=0;
HAL_UART_Receive_DMA(&huart2,buffer2,data_length);//打开DMA接收
void USART2_IRQHandler(void)
HAL_UART_IRQHandler(&huart2);
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)
if(huart==&huart2)
flag=1;
void DMA1_Stream6_IRQHandler(void)
HAL_DMA_IRQHandler(&huart2_dma_tx);
void DMA1_Stream5_IRQHandler(void)
HAL_DMA_IRQHandler(&huart2_dma_rx);
