#i nclude
#i nclude
#i nclude
#i nclude
#i nclude
#pragma NOAREGS
//STC ISP_V2.0 PCB的晶振为18.432MHz
#define WdtTime_71_1mS0x30 //71.1mS
#define WdtTime_141_2mS0x31 //141.2mS
#define WdtTime_284_4mS0x32 //284.4mS
#define WdtTime_568_8mS0x33 //568.8mS
#define WdtTime_1_1377S0x34 //1.1377S
#define WdtTime_2_755S0x35 //2.755S
#define T2_5mS -1536*5//5ms 18.432MHz
sfrAUXR= 0x8e;
sfrWDTRST= 0xa6;
sfr16 TIMEER2= 0xcc;
sfr16 RCAP= 0xca;
sfrWDT_CONTR = 0x0e1;
//全局变量定义
typedef struct Systemstruct{//系统数据结构
unsigned char TimeCount;
unsigned intRamTest;
unsigned char SioTxCount;
unsigned char SioTxSum;
unsigned char SioRxCount;
unsigned char SioTxBuff[32];
//unsigned char SioRxBuff[32];
}SystemData;
data SystemData SystemBuffers;//申请系统数据结构
void MainInit(void);//系统初始化
void SystemInit(void);//系统初始化
void SystemSetup(void);//系统设置
void SystemIoInit(void);//系统接口初始化
void TimeInit(void);//定时器定时参数设置
void UserSetup(void);//用户运行环境设置
void ClrWdt(void);//喂狗
void IoPinTest(void);
unsigned char Port0Test(void);
unsigned char Port1Test(void);
unsigned char Port2Test(void);
unsigned char Port3Test(void);
void main(void)
MainInit();//系统初始化
while (1) {//主循环
IE|= 0xb2;//保证中断可靠EA,ET2,ES,ET0
TCON |= 0x55;//保证定时器开
PCON |= SMOD_ + GF0_ + IDL_;//进入空闲状态并喂软件狗
_nop_();
_nop_();
void MainInit(void) using 0//系统初始化
ClrWdt();//清除看门狗计数器
SystemIoInit();//系统接口初始化
SystemInit();//系统上电初始化
SystemSetup();//系统运行环境设置
UserSetup();//用户运行环境设置
void SystemInit(void) using 0//系统初始化
if (SystemBuffers.RamTest != 0x55aa) {//内存初始化
SystemBuffers.RamTest = 0x55aa;
else {
void SystemSetup(void) using 0//系统设置
TimeInit();
void SystemIoInit(void) using 0
IE = 0x00;//关闭中断
P2 = 0xff;//P2口初始化
P0 = 0xff;//P0口初始化
P1 = 0xff;//P1口初始化
P3 = 0xff;//P3口初始化
void TimeInit() using 0
//TCON = 0x55;//启动定时器
TL0 = 0;
TH0 = 0;
TR0 = 1;//启动定时器0
TMOD = 0x20;
TH1 =0xfb;//Fosc=18.432MHzth1=tl1=0xfb bps=9600
TL1 =TH1;
SCON = 0x58;
PCON = 0x80;//2*bps=9600*2=19200
TR1 = 1;//启动定时器1
TIMEER2 = T2_5mS;
RCAP= T2_5mS;
TR2= 1;//启动定时器2
void UserSetup(void) using 0//用户运行环境设置
SystemBuffers.SioTxCount = 0;
void ClrWdt(void)using 0//喂狗
WDT_CONTR = WdtTime_1_1377S;//1.1377S喂狗
unsigned char testval;
P0 = 0x55;//奇数管脚发低电平
_nop_();//延时
testval = P0 ^ 0x55;//比较发送及接收结果
P0 = 0xaa;//偶数管脚发低电平
_nop_();//延时
testval |= P0 ^ 0xaa;//比较发送及接收结果(2次的)
P0 = 0xff;//释放P0口,防止外部接入电源
return testval;//测试成功返回0
P1 = 0x55;//奇数管脚发低电平
_nop_();//延时
testval = P1 ^ 0x55;//比较发送及接收结果
P1 = 0xaa;//偶数管脚发低电平
_nop_();//延时
testval |= P1 ^ 0xaa;//比较发送及接收结果(2次的)
P1 = 0xff;//释放P1口,防止外部接入电源
P2 = 0x55;//奇数管脚发低电平
_nop_();//延时
testval = P2 ^ 0x55;//比较发送及接收结果
P2 = 0xaa;//偶数管脚发低电平
_nop_();//延时
P2 = 0xff;//释放P2口,防止外部接入电源
P3 = 0x55;//奇数管脚发低电平
_nop_();//延时
testval = P3 ^ 0x55;//比较发送及接收结果
P3 = 0xaa;//偶数管脚发低电平
_nop_();//延时
testval |= P3 ^ 0xaa;//比较发送及接收结果(2次的)
P3 = 0xff;//释放P1口,防止外部接入电源
unsigned char i, err = 0, pin = 0;
//if (pin = Port0Test()) err = 1;//如果P0口上拉可开放此行
if (pin = Port1Test()) err = 2;
if (pin = Port2Test()) err = 3;
if (pin = Port3Test()) err = 4;
if (err) {
