//定时器用普通模式,溢出中断,加1计数
//定时器初值计算,定时10ms,1024分频为例,(FF-X)*F_CPU/1024=0.01s
//秒表在数码管上显示
//编译环境 AVR Studio 4.17/AVR GCC,优化度-0s
//系统时钟7.3728MHZ,设置熔丝位为外部高频石英晶体振荡,启动时间4.1ms
//包含文件
#include
#include
#define F_CPU7372800// 单片机主频为7.3728MHz,用于延时子程序和计算定时器初始值
#include
#include
#include
#include //中断信号头文件
//定义变量区
#define f_count 183 //定时器初值,定时器加一计数
#define timer_clk 0x07//时钟1024分频
#define delay_us(x) _delay_us(x) //AVR GCC延时函数 x(us)
#define delay_ms(x) _delay_ms(x) //AVR GCC延时函数 x(ms)
#define uchar unsigned char
#define uint unsigned int
#define ulong unsigned long
#define Data_IO PORTA //数码管数据口
#define Data_DDR DDRA //数码管数据口方向寄存器
#define D_LE0 PORTD &= ~(1 << PD4) //数码管段控制位为0,锁存端口数据
#define D_LE1 PORTD |= (1 << PD4) //数码管段控制位为1,锁存器输出与端口一致
#define W_LE0 PORTD &= ~(1 << PD5) //数码管位控制位为0
#define W_LE1 PORTD |= (1 << PD5) //数码管位控制位为1
//共阴数码管显示的断码表0~F
uchar table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
uchar time_1s_count=0;
//volatile uchar time_1s_flag;
uint second;
uint A1,A2,A3;
//IO端口初始化
void system_init()
Data_IO=0xFF; //数据口为输出
Data_DDR=0xFF;
PORTD=0xFF; //74HC573的控制口,设置为输出
DDRD=0xFF;
PORTB=0XFF;
DDRB=0XFF;
//定时器0初始化子程序
void timer0_init() //定时器初始化
TCCR0=0x07; //普通模式,OC0不输出,1024分频
TCNT0=f_count; //初值,定时为10ms
TIFR=0x01; //清中断标志位
TIMSK=0x01; //使能定时器0溢出中断
//数据处理函数
void data_do(uint temp_d)
uchar A2t;
A1=temp_d/100; //分出百,十,和个位
A2t=temp_d%100;
A2=A2t/10;
A3=A2t%10;
//74HC573控制数码管动态扫描显示函数,显示采集到的温度
void Display_Timer0(void)
uchar i,j;
system_init();
j=0x01; //此数据用来控制位选
for(i=0;i<5;i++) //用后3位数码管来显示
D_LE1;
W_LE1;
Data_IO=~j;
W_LE0;
j=(j<<1);
Data_IO=0x00;
D_LE0;
delay_ms(1);
D_LE1;
W_LE1;
Data_IO=~j;
W_LE0;
j=(j<<1);
Data_IO=table[A1];
D_LE0;
delay_ms(1);
D_LE1;
W_LE1;
Data_IO=~j;
W_LE0;
j=(j<<1);
Data_IO=table[A2];
D_LE0;
delay_ms(1);
D_LE1;
W_LE1;
Data_IO=~j;
W_LE0;
j=(j<<1);
Data_IO=table[A3];
D_LE0;
delay_ms(1);
D_LE1;
W_LE1;
Data_IO=0xff;
W_LE0;
//定时器0中断服务子程序
ISR(SIG_OVERFLOW0) //中断服务程序
TCNT0=f_count; //定时器赋初值,非自动重装模式
if(time_1s_count!=100)
time_1s_count++; //定时器定时10ms,计数100次为1s
// time_1s_flag=0; //未到1s,标志位为0
else
if(second!=999) //最大计时999s
second++;
else
second=0; //到999s则清0
time_1s_count=0;
// time_1s_flag=1;
data_do(second); //将秒转化为BCD码,供显示
//主程序
int main(void)
system_init(); //系统初始化
timer0_init(); //定时器0初始化,完成定时器相关配置
time_1s_count=0; //计数值清0
SREG|=0x80; //开启全局中断
while(1)
Display_Timer0(); //显示计数值
